Cloud of smoke after sudden stop in 1986 560SEC - Mercedes-Benz Forum
post #1 of 13 (permalink) Old 10-15-2017, 12:41 PM Thread Starter
Date registered: Oct 2017
Vehicle: 1986 560SEC Past Cars (all from the 80's) 5 cyl 300D, 6 cyl 300SE, 8 cyl 560SEL
Quoted: 6 Post(s)
Hi everyone,
Just joined after reading this forum for the past few weeks.
Have a 1986 560SEC that I am not currently using because of this problem. First noticed problem after going down a steep hill. Now happens after stopping as well. It seems like oil is being forced into the cylinders and then burning. Thought it might be the rings?
Any ideas? Fixes? Estimates?
Kayak9
Kayak9 is offline
post #2 of 13 (permalink) Old 10-15-2017, 04:06 PM
humblejoe's Avatar
Date registered: Feb 2007
Vehicle: 04 odyssey (265k) 1995 E320 wagon (295k)
Quoted: 312 Post(s)
Had an m110 that I could "James bond"'someone at will. Hard deceleration oil would slip past valve guides and burn. Came in handy when some tool in a 3 series convertible flew up my ass when I was doing 75, and flashed his lights at me. I accelerated up to 90, then let off the gas hard. Dusted him and the blonde with him with a huge blue smoke cloud. He gave me.room after that.
Might just be valve seals, does it normally use oil?
Dikdaan likes this.
"alte Schulqualität"
W124, One of the last great gifts of West Germany
humblejoe is offline
post #3 of 13 (permalink) Old 10-15-2017, 04:22 PM
MBL87560SEC's Avatar
Date registered: Jul 2004
Vehicle: 1991 500SEC sub 50K mi. 1987 560SEC Now 150K mi. 2018
Quoted: 396 Post(s)
In addition to above suggestions, have you noticed then brake fluid reservoir level dropping?
Just a thought, perhaps out of a box or two, but a bad master cylinder will puke fluid into the booster vacuum... HUUUUGE smoke on braking can ensue.....
Good Luck man,
MBL
MBL87560SEC is offline
post #4 of 13 (permalink) Old 10-15-2017, 06:27 PM Thread Starter
Quoted: 6 Post(s)
Yes it had started to consume oil. Was running heavier oil to cut down on smoking. Also had used an additive for older engines.
It is such a fine looking car it is a shame for it to sit. Thinking about reviving her. Not very mechanical but have lots of time on my hands so researching what it could be. Trying to befriend a mechanic here so it doesn't cost me a fortune. Willing to try and get my hands dirty and undertake a project and do it myself but feel this will be way beyond my ability.
As my old mechanic would say "I'm sure it's nothing a wallet can't fix".
Kayak9
Kayak9 is offline
post #5 of 13 (permalink) Old 10-16-2017, 01:53 AM
Evilaseq's Avatar
Date registered: Jun 2016
Vehicle: 1988 500 SEC
Quoted: 5 Post(s)
This is one of the best "golden thoughts" I've ever heard.
Mine '88 560 SEL also has the oil smoking problem, after the engine gets it operating temperature when you floor it the car leaves behind a fume of blueish smoke. Almost every car mechanic I asked about this problem said - check the valve seals, their're probably gone after 29 yrs and 360 kkm. I don't have to say that it consumes oil - consumption increases with higher revs so that's probably it.
I'm waiting for a good opportunity to change the seals, you can do that without removing the camshafts so it shouldn't be a high risk job, although it requires some mechanical skills.
MBL87560SEC likes this.
Evilaseq is offline
post #6 of 13 (permalink) Old 10-16-2017, 05:47 AM
xlimodriver's Avatar
Date registered: Sep 2006
Vehicle: '84 SEC EuroCoupe, '85 200T EuroWagon, 2012 Nissan Maxima SV Sport
Quoted: 506 Post(s)
If you could pinpoint exactly what cold part you're in I might be able to help.
____________________
.... Don't mess with old farts - - age and treachery will always overcome youth and skill! Bullshit and brilliance only come with age and experience!
Gone and almost forgotten......
'96 E320
'79 450 SEL
'78 300 CD
xlimodriver is offline
post #7 of 13 (permalink) Old 10-16-2017, 09:36 AM
John350's Avatar
Date registered: Nov 2014
Vehicle: 1990 350SDL, "Grandpa's Roadster" Project Car
Quoted: 800 Post(s)
Smoking under heavy acceleration is usually piston rings. Smoking under heavy engine braking is usually valve guides.
How much oil does it use between oil changes?
John
"Real engines don't have spark plugs!"
John350 is offline
post #8 of 13 (permalink) Old 10-16-2017, 11:38 AM Thread Starter
Quoted: 6 Post(s)
Smoking Q/A
Smoking was after stopping only. When idling wasn't smoking or on acceleration as I recall. Car has been sitting unused. Wasn't using a lot of oil. Started problem while on vacation after going down steep hill and hasn't been used much since. I haven't checked the brake fluid yet as another user suggested. It was a lot of smoke and didn't want to be driving the car not knowing what was wrong in the engine.
Kayak9
Kayak9 is offline
post #9 of 13 (permalink) Old 10-16-2017, 11:42 AM Thread Starter
Quoted: 6 Post(s)
What isn't the cold part of Canada
I am in Manitoba in the interlake region. Watched a video an changing the valve seals. Don't think I would attempt that.
Here is another important question. I think the car might have its original timing chain still (192k). Was unable to determine if previous owner had replaced it. Is this something that should be getting changed as well if the engine is coming apart?
Kayak9
Kayak9 is offline
post #10 of 13 (permalink) Old 10-16-2017, 04:08 PM
Date registered: Oct 2013
Vehicle: Mercedes-Benz 190E 2.6, 300E, Volkswagen Jetta 1.4T
Quoted: 247 Post(s)
Kayak9
Absolutely, no questions asked, change that stuff
I know enough to be dangerous...
1992 190E 2.6 (Supreme) - 242,000 miles
2019 VW Jetta 1.4T (Jellybean) - 2560 miles
1988 300E (Jutter/Junker) - 140,000 miles
Past MBs:
1986 420SEL (Bismark) - Scrapped
REPLACE YOUR FUEL FILTERS
A.Cabral is offline
