Help with W126 Scoop Air Flap Vacuum Pod - Page 7 - Mercedes-Benz Forum
post #61 of 108 (permalink) Old 07-24-2017, 03:11 PM Thread Starter
Strassenkreuzer's Avatar
Date registered: Feb 2015
Vehicle: 1989 300SE (Mitzi); 2003 CLK 430 cabrio (Clifford)
Quoted: 129 Post(s)
I previously reported that I was finally able to replace all six vacuum pods on my 300SE. What a ton of work, but I'm glad I did it; I resolved the major problem of no air through the front center vents, but I have not yet been able to fully resolve the matter of A/C air coming through the defrost vents at the windshield.
On two separate occasions—I'll call them both flukes—the system somehow managed to close the defrost flap while I was driving, but that turned out to be an exception; most of the time the defrost vents still blow air while the system is set to Auto (center button).
So I decided to check the lines coming from the solenoid switchover valves. I removed each one from the valve and then, with my MightyVac, tested the line from the switch to the respective actuator pod. The good news is all but one held tight during a two-minute vacuum test of each (please see attached photo). You may recall that I did the pod replacement without removing the dash cover, and now that I've buttoned everything back up it's difficult to tell which line goes to which pod. (Yes, I've learned the hard way not to clean up my mess until I know everything is working correctly!)
My problem is that in all the places I've looked online, I can't find a diagram that tells me which of the switchover lines attaches to which pod, and in this case switch outlet #5 in particular. Which raises my question: Can anyone provide me with information on what pod is controlled by each of these seven valves? There are these colored circles on the switchover valve, but I'm not smart enough to deduce what they mean.
I'm kind of excited to know that I have a leak in only one line, and I suspect it's likely the rubber nipple that attaches to the pod. But which pod connects to switchover value #5?! I'm guessing it's either Recirc or one of the two fresh air pods, but I can't be sure.
Once I solve for that leak, I'm hoping my system will work as designed—at least until I have to replace something like my monovalve or the auxiliary water pump.
As always, thanks, gents.
Name:	Solenoid switch.jpg
Strassenkreuzer is offline
post #62 of 108 (permalink) Old 07-25-2017, 05:01 AM
281lxm's Avatar
Date registered: Dec 2011
Vehicle: 1991 560 SEC 1994 E500 2014 E350 Cab
Quoted: 435 Post(s)
OK here is the numbering system for you top to bottom:
Pos 1 - Fresh/Recirc Short Stroke
Pos 2 - Fresh/Recirc Long Stroke
Pos 3 - Legroom Flaps
Pos 4 - Center Outlet Flap (Use a Y combine lines 4 and 7 to Pos 4 to prevent windscreen frost on Auto)
Pos 5 - Defroster, Long Stroke
Pos 6 - Diverter
Pos 7 - Defroster, Short Stroke (cap this off)
Strassenkreuzer likes this.
_____________________________________________
1991 560SEC 199 /268, 17" RS90'S, Eibach springs, Bilstein HD shocks, Custom rear sway bar, Euro Headlights, Custom ceramic coated headers and down pipes with stainless dual exhaust, W140 glass sunroof, dog ear trunk spoiler, OEM Skid Plate, Euro bumpers, wood refinish and restored.
281lxm is offline
post #63 of 108 (permalink) Old 07-25-2017, 08:34 AM Thread Starter
Quoted: 129 Post(s)
Pos 6 - Diverter
Perfect. Thanks for this! I can now go replace the rubber connectors on this pod and re-test. Will probably be a few days because I have to determine which connector it needs and then order accordingly. But I'll post results when I'm done.
One other question about Pos 6 - Diverter: Is this aka the "scoop air" pod near the accelerator pedal?
post #64 of 108 (permalink) Old 07-25-2017, 10:03 AM
281lxm's Avatar
Quoted: 435 Post(s)
I believe that to be true. That's why I said very early on that if you mightyvac that pod, you may get a sandstorm of debris flowing out the center vents at a high rate of speed!
281lxm is offline
post #65 of 108 (permalink) Old 07-25-2017, 10:10 AM Thread Starter
Quoted: 129 Post(s)
Well, when I did my tests yesterday—MightyVac'ing each line/pod by removing the nipple from the solenoid switch—I did them with the engine/HVAC off, and it was only Pod 5, the defrost pod, that failed to hold vacuum for my two-minute tests. Matter of fact, its vacuum fell off precipitously and was back at zero in mere seconds.
Given that all the other pods are holding vacuum, and given that the failed pod is a defrost pod, I'm hesitant to think that I'm gonna get a bunch of debris flowing through the center when I replace 5's connector...assuming, of course, that it's the source of the leak. But we'll see. I'm kind of excited to get this repair done. The good news is that I don't have to tear apart the under-dash and glove box assemblies, as the defrost pod is behind the center console. Less work.
post #66 of 108 (permalink) Old 07-25-2017, 11:35 AM Thread Starter
Quoted: 129 Post(s)
No matter where I looked on the Interwebz I couldn't find a simple diagram that showed me which solenoid switch outputs go to which vacuum pods. @281lxm pulled through with an explanation of what each pod does, so I took that a step further and I've created the attached diagram that hopefully serves as a reference for anyone else who's undertaking a dive into the wooly world of W126 HVAC. Yes, there's a multi-page explanation of what each pod does under the differing HVAC circumstances, but I wanted something that was succinct and easily referenced.
Thanks to @281lxm , @KRH , @mclare , @MBL87560SEC , and @wooky_chew_bacca for all your technical input with this project of mine. Once I get the vacuum leak associated with Pod 5 resolved, I hope I'm in good shape—until the next thing.
post #67 of 108 (permalink) Old 07-25-2017, 01:24 PM Thread Starter
Quoted: 129 Post(s)
Can anyone give me a link to a place where I can buy two elbow connectors for the defroster pod—or alternatively, a length of hose of the right dimensions that will fit these pods. I seem to recall seeing a link somewhere, but for the life of me I can't find it now.
Will this work—does anyone know? http://www.autohausaz.com/pn/0079976182
Thanks.
post #68 of 108 (permalink) Old 07-25-2017, 08:33 PM
281lxm's Avatar
Quoted: 435 Post(s)
Answered your other post but here you go 201-805-01-03 for elbows and there are 12
281lxm is offline
post #69 of 108 (permalink) Old 07-25-2017, 08:49 PM Thread Starter
Quoted: 129 Post(s)
Muchas gracias!
post #70 of 108 (permalink) Old 07-26-2017, 04:14 AM
MBL87560SEC's Avatar
Date registered: Jul 2004
Vehicle: 1991 500SEC sub 50K mi. 1987 560SEC Now 150K mi. 2018
Quoted: 396 Post(s)
Thanks.
Hi there,
If not yet answered, here is the source I have researched & used for this..
Vacuum Line: 1990 Mercedes-Benz 560SEC Base Coupe 126.045 5.6L V8 - Parts Search
Rubber Vacuum Connectors: 1990 Mercedes-Benz 560SEC Base Coupe 126.045 5.6L V8 - Parts Search
Cheers & good luck,
MBL
MBL87560SEC is offline
