SEL Euro Lights, Protective Covers, Modified U.S. Wipers - Mercedes-Benz Forum
post #1 of 16 (permalink) Old 04-05-2016, 03:41 PM Thread Starter
luckymike's Avatar
Date registered: Mar 2010
Vehicle: 1989 560SEC, 1989 560SEL, 1995 E420
Quoted: 548 Post(s)
I absolutely love the look and light output of euro lights. After finally finding a pair, I recently installed them on our 1989 560SEL. Transforms the car, in my opinion. The US lights don't look as bad on the SEL as they do on the SEC but I'm still glad to finally get the euros installed. I included a before pic at the bottom.
This pair was used but the lenses are in remarkable condition. To prevent rock chips and sandblasting, I made covers for them. They are almost invisible until you're right up to them. Super easy to make. The 1/16" polycarbonate cuts easily with a heavy pair of shears. Drill one hole for the upper mount, install six rubber bumpers to keep the poly off the glass, and rotate into place. The upper mount is the wire from a binder clip.
About the only problem with converting to euro headlights is how high the US wiper sits on the lens. Not a huge deal but not aesthetically ideal. My solution is to cut an 11/16" section out of the vertical portion of the wiper so that the blade sits that much lower on the lens. It's not as elegant looking as euro wipers but I feel the mighty Benz must have wipers and for the budget-minded, this isn't a bad alternative. The front shot of the car shows an original and a modified wiper installed.
The cut out section becomes a splint for the joint. I used JB weld to smooth the transition at the joint. The washer system remains intact.
Not a huge project but very rewarding. I did this on our SEC, as well, and am pleased that both came out so well.
ID:	1836674   Click image for larger version
ID:	1836682   Click image for larger version
ID:	1836690   Click image for larger version
ID:	1836698   Click image for larger version
ID:	1836714   Click image for larger version
ID:	1836722   Click image for larger version
ID:	1836730   Click image for larger version
ID:	1836738   Click image for larger version
roadhouse and gwg like this.
luckymike is offline
post #2 of 16 (permalink) Old 04-05-2016, 05:47 PM
lowphat's Avatar
Date registered: Feb 2005
Vehicle: Daily: 2000 Kleemann Supercharged CLK 430. Seductress: 1988 Jap AMG SEC Widebody
Location: Northern Virginia @ Mount Vernon, the original Ground Zero
Quoted: 17 Post(s)
Damn that wiper mod is super creative and absolutely looks so much cleaner than the original design. Congratulations on your Ingenuity! The Euro lights and that wiper mod really do transform the look of your sweet sweet ride!
Enjoy yourself, Marco.
lowphat is offline
post #3 of 16 (permalink) Old 04-05-2016, 06:02 PM Thread Starter
luckymike's Avatar
Quoted: 548 Post(s)
Thanks, lowphat! High praise, indeed. And much appreciated.
post #4 of 16 (permalink) Old 04-05-2016, 06:36 PM
mramay's Avatar
Vehicle: Two '87 570SECs, one '87 560SEL
Quoted: 247 Post(s)
Yes, a really great addition to the headlights and if it saves just one lens from dying of road debris kicked up, then marvelous!!
On plastic sheets that we cut, we'd use a propane torch to melt the edges smooth. It was very easy and quick. Try that on some scraps to see if it smooths the edge for polycarbonate because a sawed edge can crack *much* easier than a smooth one.
Blasphemous Mike
US '87 560SEC with Euro headlights, clear markers, H&Rs, 17x8.5/Nitto's, ATE slotted rotors with ceramic pads, BergWerks FGS, 3.07 Limited Slip. '87 560SEL with Euro Headlights, lowered, 235/40/17's
mramay is online now
post #5 of 16 (permalink) Old 04-05-2016, 06:57 PM
281lxm's Avatar
Date registered: Dec 2011
Vehicle: 1991 560 SEC 1994 E500 2014 E350 Cab
Quoted: 435 Post(s)
Very good Mike!
luckymike likes this.
_____________________________________________
1991 560SEC 199 /268, 17" RS90'S, Eibach springs, Bilstein HD shocks, Custom rear sway bar, Euro Headlights, Custom ceramic coated headers and down pipes with stainless dual exhaust, W140 glass sunroof, dog ear trunk spoiler, OEM Skid Plate, Euro bumpers, wood refinish and restored.
281lxm is offline
post #6 of 16 (permalink) Old 04-05-2016, 09:26 PM
GreenT's Avatar
Date registered: Mar 2013
Vehicle: 1995 S500 - 1986 420SEL
Quoted: 10418 Post(s)
Mike, what kind of paint did you use on the wipers? Any clear coat?
GreenT is online now
post #7 of 16 (permalink) Old 04-05-2016, 09:43 PM Thread Starter
luckymike's Avatar
Quoted: 548 Post(s)
Mike, in the old days I fiddled with Plexiglas and found that melting the edge with a torch really helped. Now that I'm using polycarbonate, it simply isn't needed, at least not in this application. I've had these covers on my SEC for quite a while and the edges show no cracking at all.
The poly really is a superior material. So easy to cut and shape. Not brittle like the Plexiglas.
mramay likes this.
post #8 of 16 (permalink) Old 04-05-2016, 09:44 PM Thread Starter
luckymike's Avatar
Quoted: 548 Post(s)
I used Dupli-Color primer and paint. No clear coat.
post #9 of 16 (permalink) Old 04-05-2016, 10:55 PM
bondavi's Avatar
Date registered: Sep 2004
Vehicle: 1983-2007 MB's
Quoted: 832 Post(s)
I'm sure you could do some good business marketing these polycarbonate headlight covers, not only for the W126 but other Benzes/car makes. I'd love a SEC/SEL set myself if you ever produce em...
bondavi is offline
post #10 of 16 (permalink) Old 04-06-2016, 02:15 AM
ianrandom's Avatar
Date registered: Jul 2008
Vehicle: 1986/1990 W126
Quoted: 1154 Post(s)
That is a very pretty car.
roadhouse and luckymike like this.
ianrandom is offline
