A High Cold/Warm Idle Problem - Mercedes-Benz Forum
post #1 of 70 (permalink) Old 11-26-2015, 10:05 AM Thread Starter
Vizezeul's Avatar
Date registered: Sep 2015
Vehicle: 1987 Mercedes-Benz 560SEL
Quoted: 73 Post(s)
So I'm back again with a new problem.
My 1987 560SEL seems to have a high idle problem that gets worse as the car warms up. Here are the symptoms:
  • Cold start neutral/park RPM at 900
    Revving the car in neutral or park will cause the idle to move up to 1,500
    Cold start drive/reverse RPM at about 550-600
    Warm neutral/park idle RPM at 1100-1200
    Warm drive/reverse rpm at 700-800
I tried cleaning out the idle air control valve last night and today using a bit of carburettor cleaner, but to no avail.
The vacuum needle economy gauge doesn't move when I'm not pushing the pedal, so I'm assuming a vacuum leak isn't the issue (or at least, not a major one). Based on what I described above, what do you guys think the problem is? The car operates fine otherwise.
Vizezeul is offline
post #2 of 70 (permalink) Old 11-26-2015, 10:07 AM
281lxm's Avatar
Date registered: Dec 2011
Vehicle: 1991 560 SEC 1994 E500 2014 E350 Cab
Quoted: 436 Post(s)
Does the idle change when you remove the electrical connection to the ICV when the car is running?
_____________________________________________
1991 560SEC 199 /268, 17" RS90'S, Eibach springs, Bilstein HD shocks, Custom rear sway bar, Euro Headlights, Custom ceramic coated headers and down pipes with stainless dual exhaust, W140 glass sunroof, dog ear trunk spoiler, OEM Skid Plate, Euro bumpers, wood refinish and restored.
281lxm is offline
post #3 of 70 (permalink) Old 11-26-2015, 10:11 AM
281lxm's Avatar
Quoted: 436 Post(s)
https://www.google.com/search?q=w126...&client=safari
281lxm is offline
post #4 of 70 (permalink) Old 11-26-2015, 10:13 AM
281lxm's Avatar
Quoted: 436 Post(s)
If you have no change in idle after removing the electrical plug, shut off car and carefully open that plug and ensure the puny wires are secured by solder to their caps. If they are good, then get the relay.
281lxm is offline
post #5 of 70 (permalink) Old 11-26-2015, 10:13 AM Thread Starter
Vizezeul's Avatar
Quoted: 73 Post(s)
Yes! It goes up to about 1,650.
Vizezeul is offline
post #6 of 70 (permalink) Old 11-26-2015, 10:18 AM
281lxm's Avatar
Quoted: 436 Post(s)
Answered then above, get new relay. Pull up right side front carpet to expose the plastic foot cover(if not there get one at a yard). IIRC 10mm plastic socket needed then the relay is to the right and high. Most likely hard to get out, been there 25 years. Could flow some solder but get a new one. You must get a 560 SEC or SEL relay, not from a 420
281lxm is offline
post #7 of 70 (permalink) Old 11-26-2015, 10:19 AM Thread Starter
Vizezeul's Avatar
Quoted: 73 Post(s)
Oh yeah, I saw that post after I refreshed the page. Thanks for your help!
Out of curiosity, what makes you think it's the relay?
Vizezeul is offline
post #8 of 70 (permalink) Old 11-26-2015, 10:22 AM
281lxm's Avatar
Quoted: 436 Post(s)
Experience. You have a gen II and the idle went up without the valve. If you pulled the relay most likely no change in idle, meaning cold solder joints are rendering it in op. It's one or the other, if you go to a pick a part yard, get a few spares.
281lxm is offline
post #9 of 70 (permalink) Old 11-26-2015, 10:25 AM Thread Starter
Vizezeul's Avatar
Quoted: 73 Post(s)
That's interesting. I'll follow your advice then and get a new relay.
Thanks again! I'll keep this thread updated to let you and everyone else know how it went.
Vizezeul is offline
post #10 of 70 (permalink) Old 11-26-2015, 10:27 AM
281lxm's Avatar
Quoted: 436 Post(s)
There must be 18-20 hours of reading on the subject, search high idle and you will see.
281lxm is offline
