Head light intermittent issues - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 11-13-2015, 03:57 PM Thread Starter
anthonywclark's Avatar
Date registered: Aug 2015
Vehicle: 2000 E320 and 1989 300SEL
Quoted: 11 Post(s)
Send a message via AIM to anthonywclark Send a message via MSN to anthonywclark
Hello everyone,
My daughter has a 1989 300sel Inline 6. It appears she has an intermittent problem with her head lights on one side going out. I examined the bulbs(with gloves) and found no problems. When tracing the wiring I found something interesting. At a spliced connection point it appeared to be burnt and when i wiggled them the lights would work again. The wires also felt warm to the touch. Is this normal? I will send picks tomorrow morning of the burnt sections.
PS: I am missing the internal round cover for one of the bulbs. Where can I find one of these? All the ones I see on Ebay are square.
Anthony Clark, BSEE
anthonywclark is offline
post #2 of 7 (permalink) Old 11-13-2015, 05:09 PM
wooky_chew_bacca's Avatar
Date registered: Oct 2009
Vehicle: '91 560SEC, '91 300SE (sold), '98 Yota, '02 S-10 Hauler
Quoted: 1282 Post(s)
Redo and solder the wires (you didn't say what kind of connection was there)
Some days it's just not worth chewing through the restraints
My Stable:
'91 560SEC "Ursula"
'91 300SE (sold) "Sadie"
'11 Suzuki SX4 Sport Sedan
'02 S-10 Truck
'72 SeaBird boat, "Riff Raft", overhaul restarted
Dif-tor heh smusma
I'm surprised that NOBODY has asked me what this is / means
LOL
wooky_chew_bacca is offline
post #3 of 7 (permalink) Old 11-13-2015, 06:06 PM Thread Starter
Quoted: 11 Post(s)
Its 4 wires with molex terminals with shrink tube on them
Anthony Clark, BSEE
post #4 of 7 (permalink) Old 11-14-2015, 07:00 AM
mramay's Avatar
Date registered: Feb 2005
Vehicle: Two '87 570SECs, one '87 560SEL
Quoted: 256 Post(s)
Also, there are four white fuses in the fuse box for each headlight filament. Make sure they are brass fuses, not the white metal (e.g., aluminum, lead) ones. That won't fix your wiring problem, but *will* alleviate problems later.
Blasphemous Mike
US '87 560SEC with Euro headlights, clear markers, H&Rs, 17x8.5/Nitto's, ATE slotted rotors with ceramic pads, BergWerks FGS, 3.07 Limited Slip. '87 560SEL with Euro Headlights, lowered, 235/40/17's
mramay is offline
post #5 of 7 (permalink) Old 11-22-2015, 08:19 AM Thread Starter
Quoted: 11 Post(s)
I replaced all fuses with new ones a year ago. They looked pretty rough and it was a cheap item to replace. But I still am wondering about the wires being hot. Is this normal??
Anthony Clark, BSEE
post #6 of 7 (permalink) Old 11-22-2015, 11:11 PM
Date registered: Feb 2013
Vehicle: 1972 280 SEL 4.5 (sold) 1971 280 114 Coupe (sold) 1988 300 SE 2005 jag XK8
Quoted: 301 Post(s)
They'll be warm because you have a poor connection. Fix it and I believe the heat will lessen.
carnut62 is offline
post #7 of 7 (permalink) Old 11-23-2015, 01:15 PM
luckymike's Avatar
Date registered: Mar 2010
Vehicle: 1989 560SEC, 1989 560SEL, 1995 E420
Quoted: 574 Post(s)
I'd also remove, clean, and reattach the ground at that headlight. I believe it's right there near the radiator next to the headlight.
luckymike is offline
