M103 Rough idle and vacuum leak - Page 18 - Mercedes-Benz Forum
post #171 of 174 (permalink) Old 12-16-2018, 08:03 AM
Strassenkreuzer's Avatar
Date registered: Feb 2015
Vehicle: 1989 300SE (Mitzi); 2003 CLK 430 cabrio (Clifford)
Quoted: 129 Post(s)
Originally Posted by wooky_chew_bacca View Post
Yes, use it kinda like a "sealer" to keep moisture in the air out and it helps seal the rubber to the cap without it getting stuck (we've all had to deal with that)
Thanks, wooky. And interesting. I figured any grease of any sort would impeded conduction, but I guess that's they call it "dielectric". Does it make sense to put the grease on the metal contacts of both ends of the wire—the cap end and the spark plug end?
Strassenkreuzer is offline
post #172 of 174 (permalink) Old 12-16-2018, 09:29 AM
wooky_chew_bacca's Avatar
Date registered: Oct 2009
Vehicle: '91 560SEC, '91 300SE (sold), '98 Yota, '02 S-10 Hauler
Quoted: 1275 Post(s)
I've been using it more and more lately to prevent / cut down on corrosion of contacts and such. Used on battery terminals there is almost none of the white crap build up that eventually causes electrical problems and "no starts"
I've also been using dielectric in switches I "rebuild", greases and cuts down on corrosion inside
Some days it's just not worth chewing through the restraints
My Stable:
'91 560SEC "Ursula"
'91 300SE (sold) "Sadie"
'11 Suzuki SX4 Sport Sedan
'02 S-10 Truck
'72 SeaBird boat, "Riff Raft", overhaul restarted
Dif-tor heh smusma
I'm surprised that NOBODY has asked me what this is / means
LOL
wooky_chew_bacca is offline
post #173 of 174 (permalink) Old 04-15-2019, 06:01 PM Thread Starter
Date registered: Jun 2013
Vehicle: '89 300 SE
Quoted: 44 Post(s)
Another eBay EZL and another return..
codycool55 is offline
post #174 of 174 (permalink) Old 04-15-2019, 10:33 PM
Date registered: Feb 2008
Vehicle: Too many to list
Quoted: 1508 Post(s)
Originally Posted by codycool55 View Post
Definitely the Bosch Distributor. I had an off brand that wore out very quickly.
So far this winter my car has been much more reliable than previous years. I've had no problems with cold starts or stalling. I only drive it once or twice a week around town. Being a college student money has been tight and I haven't been able to afford to try another eBay EZL, but I will when I can.
Ebay offers free returns even if the seller doesn’t . You should never lose a penny by buying in ebay if the part doesn’t work . Ebay will refund you in full as long as you mail it back and will usually even give a prepaid return label
tusabes is offline
