M103 Rough idle and vacuum leak - Page 15 - Mercedes-Benz Forum
post #141 of 174 (permalink) Old 04-19-2018, 02:32 AM
panzernacker's Avatar
Date registered: May 2016
Vehicle: 1989 W124 260E Saloon. M103 lump.
Quoted: 318 Post(s)
Yes i understand , and knock taken .
panzernacker is offline
post #142 of 174 (permalink) Old 04-19-2018, 02:45 PM Thread Starter
Date registered: Jun 2013
Vehicle: '89 300 SE
Quoted: 44 Post(s)
Just to make sure we're on the same page before I hit the junk yard, the circled plug in the attached picture is the CPS coaxial correct? And the inner pin each the outer cylinder each count as a separate terminal towards that 10? So pin 31 and this outer cylindrical terminal in the CPS plug connector should be the only combination of terminals with connection, but how low of resistance is considered full continuity? When you say the mounting surface, that is the surface that will be in contact with the car correct? Will any heat sink paste do?
codycool55 is offline
post #143 of 174 (permalink) Old 04-20-2018, 12:07 AM
H.D.'s Avatar
Date registered: May 2014
Vehicle: 1988 300CE
Quoted: 511 Post(s)
Originally Posted by codycool55 View Post
... the circled plug in the attached picture is the CPS coaxial correct? And the inner pin each the outer cylinder each count as a separate terminal towards that 10? So pin 31 and this outer cylindrical terminal in the CPS plug connector should be the only combination of terminals with connection, but how low of resistance is considered full continuity? ...
That‘s all correct. The resistance between pin 31 and this outer cylindrical terminal should be below 1 Ω.
... When you say the mounting surface, that is the surface that will be in contact with the car correct? Will any heat sink paste do?
Correct. You could, for instance, use heat sink paste that‘s used for CPU coolers in computers.
H.D. is offline
post #144 of 174 (permalink) Old 05-03-2018, 01:38 PM Thread Starter
Vehicle: '89 300 SE
Quoted: 44 Post(s)
I'm starting to exhaust the junkyards near me with no luck yet. How similar do the part numbers need to be? If I purchase one from eBay is there any way to tell if it is fully functional other than asking for all the resistances?
post #145 of 174 (permalink) Old 05-04-2018, 03:43 AM
H.D.'s Avatar
Vehicle: 1988 300CE
Quoted: 511 Post(s)
... How similar do the part numbers need to be? ...
Should be the same part number.
... If I purchase one from eBay is there any way to tell if it is fully functional other than asking for all the resistances?
Not really.
H.D. is offline
post #146 of 174 (permalink) Old 05-04-2018, 08:41 AM Thread Starter
Vehicle: '89 300 SE
Quoted: 44 Post(s)
I see a lot of eBay posts stating a similar part number is interchangeable. Usually 00(4/5/6) 545 XX32 or something along those lines. Is this not entirely true?
post #147 of 174 (permalink) Old 05-04-2018, 11:04 AM
H.D.'s Avatar
Vehicle: 1988 300CE
Quoted: 511 Post(s)
I‘m not sure. There might be country version related differences. What‘s the number of yours?
H.D. is offline
post #148 of 174 (permalink) Old 05-04-2018, 10:49 PM Thread Starter
Vehicle: '89 300 SE
Quoted: 44 Post(s)
post #149 of 174 (permalink) Old 05-05-2018, 12:02 AM
H.D.'s Avatar
Vehicle: 1988 300CE
Quoted: 511 Post(s)
006 545 7632
If you go to ebay.com and type in “006 545 76 32“ (including quotation marks and blancs) you get this:
https://www.ebay.com/sch/i.html?_odk...32%22&_sacat=0
If you type in 0065457632 you get this:
https://www.ebay.com/sch/i.html?_odk...57632&_sacat=0
However, before you buy another EZL, I suggest to repeat the resistance measurements from post 135 (with all plugs disconnected) between terminal 2 and all other 9 terminals (including both coaxial CPS terminals) on your EZL in both directions! ... (once with the meter‘s “Ω“ lead connected to terminal 2 and once with the “COM“ lead connected to terminal 2).
H.D. is offline
post #150 of 174 (permalink) Old 07-09-2018, 10:05 PM Thread Starter
Vehicle: '89 300 SE
Quoted: 44 Post(s)
I've redone the tests and attached an image with the results.
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
