Forensic Body Work - Page 2 - Mercedes-Benz Forum
post #11 of 27 (permalink) Old 08-05-2015, 06:53 PM Thread Starter
~BANNED~
Date registered: Jun 2013
Quoted: 511 Post(s)
So, you think I could discard that piece of square tubing all together, Kim?
Luke Colorado is offline
post #12 of 27 (permalink) Old 08-05-2015, 06:54 PM
281lxm's Avatar
Date registered: Dec 2011
Vehicle: 1991 560 SEC 1994 E500 2014 E350 Cab
Quoted: 435 Post(s)
the bar was federal standards, I took mine out on both bumpers, and the one I sent to wooky.
@KRH , on the G2 sec, do we need to notch out the frame horn on the right side of the car for the thing to bolt up properly? My right side sags a bit and it doesn't fit properly.
_____________________________________________
1991 560SEC 199 /268, 17" RS90'S, Eibach springs, Bilstein HD shocks, Custom rear sway bar, Euro Headlights, Custom ceramic coated headers and down pipes with stainless dual exhaust, W140 glass sunroof, dog ear trunk spoiler, OEM Skid Plate, Euro bumpers, wood refinish and restored.
281lxm is offline
post #13 of 27 (permalink) Old 08-05-2015, 06:58 PM Thread Starter
~BANNED~
Quoted: 511 Post(s)
OK, that explains the crappy quality of the bar. I didn't look Germanic to me... tell me: did yours have a relief cut in it? Mine is two rectangular pieces that are welded at the back so the are triangular, not straight.
post #14 of 27 (permalink) Old 08-05-2015, 07:03 PM
281lxm's Avatar
Quoted: 435 Post(s)
my first one had pig iron, it weighed like 90 lbs, I used a grinder and just removed everything and started over $$$$$. My second set was off a grey market car, so it wasn't federalized but my third was, IIRC and I removed one solid bar and sent it to Wooky but it was the rear. Ddrab got the other gen 1 front SEL I had and it had pig iron in it too, not sure what he did to it but it was for a sedan.
281lxm is offline
post #15 of 27 (permalink) Old 08-06-2015, 05:14 AM
KRH
KRH's Avatar
Date registered: Nov 2009
Vehicle: 87 Euro500HVSEC. 88 Euro 560HVSEC. 89 Euro 560HVSEL
Quoted: 531 Post(s)
Sorry iam in Bali on holiday otherwise I could have taken any pics you require as my black 560 euro coupe is stripped down plus I have spare sets of euro front & rear bumpers in both gen2 & gen1 so any exact details or pics I can provide when I get back home next week.
The trick to fitting these bumpers correct is supporting the bumper so it's tucked up hard before tightening up the 4 front nuts. The sides should also be hard up against the side qtr panel bottom wheel arch so it all looks blended in without gaps.
by
, on Flickr" border="0" />
87 White Euro 500 "ECE" 265hp SEC
88 Black Euro 560 "RUF"300hp SEC
89 Blue Euro 560 "RUF" 300hp Hydro SEL
KRH is offline
post #16 of 27 (permalink) Old 08-06-2015, 05:32 AM
Premium Member
Date registered: Jun 2012
Vehicle: 1991 560 SEC Black on Grey
Quoted: 543 Post(s)
Premium Member
I removed the pig iron bar that came with mine which was off an 85 Euro if I remember correctly.
bflobob8 is online now
post #17 of 27 (permalink) Old 08-06-2015, 06:40 AM Thread Starter
~BANNED~
Quoted: 511 Post(s)
This leads me to my next question: where does the factory bumper bolt up on the sides and how many bolts are there?
post #18 of 27 (permalink) Old 08-06-2015, 07:12 AM
Date registered: Nov 2002
Vehicle: '82 500sec euro, '95 Ford F150
Quoted: 143 Post(s)
There's a square shackle that the bumper slides into.
The Euro is narrower than the U.S., but you can use the U.S. if you have to. It's adjustable up and down, giving you the ability to get the tip of the bumper nice and close to the fender.
BTW, we've seen so many photos in the previous threads of otherwise nice examples, where the tip of the bumper is sagging. Not a good look.
roadhouse is offline
post #19 of 27 (permalink) Old 08-06-2015, 07:19 AM Thread Starter
~BANNED~
Quoted: 511 Post(s)
Thank you, that's perfect. I think this is what I am missing and this is what the OG bodyshop hacked up on my car.
Does anyone happen to have pictures of this shackle?
post #20 of 27 (permalink) Old 08-06-2015, 08:55 AM
281lxm's Avatar
Quoted: 435 Post(s)
It is just a rectangle, its what the tab of the bumper insert slides on to. But, if the bolt on point of the chassis isn't modified with a cut, one side will sag at the fender because it will not flush attach. Going to remove and cut my chassis today if time permits.
281lxm is offline
