leaky brand new tire - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 01-30-2015, 06:04 PM Thread Starter
vdubpower's Avatar
Date registered: Nov 2003
Vehicle: 1985 500sel and 500sec 2012 E63 1989 Porsche 911
Quoted: 569 Post(s)
so my practically new bfgoodrich for my pentas has a slow leak, barely even noticed it but it was around12 psi...tire shows no nails? wheel is straight, valve stem looks good....what could it be
tires are 6 weeks old, 500 miles
vdubpower is offline
post #2 of 10 (permalink) Old 01-30-2015, 06:16 PM
Chadahar's Avatar
Date registered: Apr 2008
Vehicle: '82 Euro 500SEL, '85 Euro 500SEC AMG WB Cabriolet,'86 Euro 500SEC RUF
Quoted: 369 Post(s)
Valve core loose in the Valve stem. Happened to me yesterday, after fighting a slow leak in the 2 rear tires on the BBS-RT's on Rose, the other tire that leaked bad had a screw in it. Fixed both for free at Discount Tires where I bought the tires.
Chadahar is offline
post #3 of 10 (permalink) Old 01-30-2015, 06:25 PM
Date registered: Feb 2013
Vehicle: 1972 280 SEL 4.5 (sold) 1971 280 114 Coupe (sold) 1988 300 SE 2005 jag XK8
Quoted: 301 Post(s)
Mix up some dishwashing liquid in a spray bottle. Spray the valve stem, cap off, does it bubble up? Dare it is!! then spray around the rim where it joins the tire bead, does it bubble up?
MBL87560SEC likes this.
carnut62 is offline
post #4 of 10 (permalink) Old 01-30-2015, 06:32 PM
Date registered: Jun 2009
Vehicle: 99 BMW R1100RT, 05 MB C230, 07 Silverado CC Z71, 10 Chevy Tahoe LT
Quoted: 1075 Post(s)
Did you buy/install the tires from a tire store? If so, just go back and have them check it out. They should have a container to dunk the wheel in to see if/where there are bubbles.
If not at a store, just get cracking with the soapy water, I guess.
1999 BMW R1100RT
2005 MB C230K Sport
2010 Chevy Tahoe LT
2007 Chevy Silverado CC Z71
TexFinn is offline
post #5 of 10 (permalink) Old 01-30-2015, 06:39 PM Thread Starter
vdubpower's Avatar
Quoted: 569 Post(s)
yeah i got them from americas tires, they are usually pretty good with me..ill head over tomorrow...thanks..hopefully nothing more than a valve stem
post #6 of 10 (permalink) Old 01-30-2015, 07:36 PM
Chadahar's Avatar
Quoted: 369 Post(s)
America's Tires are Discount Tire in AZ. Same Company. Go back and tell them the problem and let them fix it. They Broke down both of my tires to find the cause, patched the one with the new plug n patch remounted and balanced both for free. Because they really want to sell me more tires and they will.
Chadahar is offline
post #7 of 10 (permalink) Old 01-30-2015, 07:44 PM
MBL87560SEC's Avatar
Date registered: Jul 2004
Vehicle: 1991 500SEC sub 50K mi. 1987 560SEC Now 150K mi. 2018
Quoted: 418 Post(s)
Aaaaaand vdubp,
You could find a leak with the illustrated three piece rim sealing too….
As above, dishwashing liquid n water spray will pinpoint super fast!
Might even be as simple as a not tightened valve stem?
Good Luck man!
MBL
MBL87560SEC is offline
post #8 of 10 (permalink) Old 01-30-2015, 07:45 PM
John350's Avatar
Date registered: Nov 2014
Vehicle: 1990 350SDL, "Grandpa's Roadster" Project Car
Quoted: 824 Post(s)
That said, I finally ended up scrapping a set of tires with 3/4 tread left because they all had slow leaks. I would have to inflate one of them every week or so. PITA!!! Soapy water showed nothing. The shop that installed them didn't have a dunk tank. They broke a couple of them down and put sealer around the beads. Nothing helped. My wife ran over a big chunk of steel and tore one of them up so we replaced all 4. All was well after that.
John350 is online now
post #9 of 10 (permalink) Old 01-30-2015, 08:40 PM
Date registered: Nov 2010
Vehicle: 57 190 Ponton , 89 560 SEL , 560 SEC , 420 SEL
Quoted: 27 Post(s)
CHROMED ALUMINUM/MAGNESIUM RIMS. CHROME PEELS (sorry) anywhere on rim and air leaks out, .... slowly. Happened to two sets of my W-126 tires.
carnut62 and GreenT like this.
Nitro88 is online now
post #10 of 10 (permalink) Old 01-30-2015, 10:06 PM
oldmako's Avatar
Vehicle: 1990 560 SEC 1985 300CD
Quoted: 302 Post(s)
I had a car for a long time and ended up putting four set of tires on it. On ONE set of Yokohama's, one wheel would constantly lose air at a crazy pace with no evidence of a leak. On the other three sets (two michelins and one BF Goodrich) there was no issue with that rim. Weird.
Homie the clown got sick of that crap and stuck a tube in it.
oldmako is offline
