W126 Heater, Vents, EC, dash rebuild - Mercedes-Benz Forum
post #1 of 15 (permalink) Old 01-19-2015, 08:53 PM Thread Starter
300SD_Dreamer's Avatar
Date registered: Apr 2008
Short; Once committed to opening the dash, rebuild everything underneath.
After many searches and pouring over websites, I cannot find a guide to rebuilding a 300SD, (1983) dash, vents, heater, blower, mono-vavle, vacuum actuators in one concise place. Just bits and pieces. Even Kent (The Guy) doesn't have a Guide...yet... Help?
Thanks to this forum and Kent's ...Source, The engine and turbo are great and the tranny shifts like a ....well, Benz!
So on to Creature Comforts (the Girl wants heat....)
Removing the dash and rebuilding everything underneath is the general goal.
Once I'm into an area, I like to spend lots of Zen Time and fix everything in the area and clean/refinish as I go.....
my own situation: '83 and 82 300sd:
The vacuum line from the engine pump shows a leak.
The EC Control seems to be conscious and working, but no doors move.
The front vents, center left and right do NOTHING as far as airflow goes.
Heater blows only slightly warm air , and not in any specific direction.
So I think taking it ALL apart and giving it the replace/rebuild/refinish/polish everything treatment should get it all working again.
The AC...well, THAT's another Story and is Out of Scope, me thinks, in this Thread.
With your collective Input, this thread might grow into a sectioned Heater and Vents Restoration Guide:
Section #1: Remove Glove Box - don't you hate a crooked Glove Box!?
Glove Box Removal: Gets you into the vent section of the dash. not tested or photographed yet
1) Pry glove box light out and disconnect wire.
2) Gently pry upper half of the plastic rivet to release it.
3) Remove the lower half of that rivet.
4) Remove glove box. (installation is reversed)
2) Remove Center Console - fragile plastic does NOT like guessing here.
3) Remove Dash - going ON is tougher than getting it off?
4) Rebuild MonoValve
4.5) Flush Heater Core
5) Rebuild Bower with brushes and bearings.
6) Test Vacuum Actuators and replace
7) replace all Vac hoses
8)Good air flow to passenger doors through the permeable leather (true Benz)
9) Rear Passenger Heat and controls
10) test before reassembly
HELP?
Much Thanks in keeping our 'Ol Ladies beautiful!
"Rear passenger heat" are the floor ducts under the front seats. Some think the fresh air vents at the rear of the console transfer heat. They only send outside air, so shut those during cold weather.
Programa Main Page.
ProgRama Remanufactured Electronic Control Modules 2-3 YEAR warranty
W126 CCU Page.
Professionally remanufactured parts with extended warranty
Rebuild all of the vacuum pods even if they hold a vacuum. Cheap insurance while everything is apart. Purchase the rebuild kits and special tool to rebuild them from George Murphy at Performance Analysis Co. Phone number see thread
sealing foam on all the doors/flaps. Possibly Oven Door Sealing like Grainger Item # 21VM85? What diameter?
MORE TO COME!! 20Jan2015
Last edited by 300SD_Dreamer; 01-21-2015 at 07:00 PM. Reason: additional Info from Members
300SD_Dreamer is offline
post #2 of 15 (permalink) Old 01-19-2015, 09:44 PM
Date registered: Feb 2013
Vehicle: 1972 280 SEL 4.5 (sold) 1971 280 114 Coupe (sold) 1988 300 SE 2005 jag XK8
Quoted: 301 Post(s)
"Rear passenger heat" I presume you mean the floor ducts under the front seats? Some think the fresh air vents at the rear of the console transfer heat. They only send outside air.
wooky_chew_bacca and 281lxm like this.
carnut62 is offline
post #3 of 15 (permalink) Old 01-20-2015, 12:59 AM
ianrandom's Avatar
Date registered: Jul 2008
Vehicle: 1986/1990 W126
Quoted: 1203 Post(s)
Yes on your climate version you have only non heated air to the central rear vent, so that just needs to be shut during cold weather.
Removing the dash is actually bizarrely easy. I've never refitted one though - yet :-)
281lxm likes this.
'86 420SE
'90 420SEC
Daily transport 9spd Giant DH Comp downhill bike
ianrandom is offline
post #4 of 15 (permalink) Old 01-20-2015, 05:42 AM
281lxm's Avatar
Date registered: Dec 2011
Vehicle: 1991 560 SEC 1994 E500 2014 E350 Cab
Quoted: 436 Post(s)
and should you require any bits like duct work for a non airbag W126, I have the complete dash, complete heater box and all the ductwork from an 87 SEC.
_____________________________________________
1991 560SEC 199 /268, 17" RS90'S, Eibach springs, Bilstein HD shocks, Custom rear sway bar, Euro Headlights, Custom ceramic coated headers and down pipes with stainless dual exhaust, W140 glass sunroof, dog ear trunk spoiler, OEM Skid Plate, Euro bumpers, wood refinish and restored.
281lxm is offline
post #5 of 15 (permalink) Old 01-20-2015, 10:15 AM
MSGGrunt's Avatar
Date registered: Sep 2013
Vehicle: 1993 300E, 1995 E320
Quoted: 126 Post(s)
I will be following this closely as I would like to tackle the same project and add in the swapping in of a new updated AC compressor kit and a rebuilt CCU from Prgrama in Florida.
Programa Main Page.
W126 CCU Page.
Rebuild all of the vacuum pods even if they hold a vacuum. Cheap insurance while everything is apart. Purchase the rebuild kits and speacial tool to rebuild them from George Murphy at Performance Analysis Co. Phone number 865-482-9175.
Replace all of the sealing foam on all the doors/flaps on the heater. Not sure what type of material to use that will not deteriorate after a bit of time. Advice???
MSGGrunt is offline
post #6 of 15 (permalink) Old 01-20-2015, 12:35 PM
Vehicle: 1981 300SD
Quoted: 13 Post(s)
Hello 300SD,
Send me a PM. I have a rather lengthy but not finished yet document covering the removal of the dash and rebuilding of the HVAC system on my 1981 300SD. I got stalled with the document about 8 months ago when it was about 80% complete and lost my momentum.
I can use you as a 'proof reader' to see if the text and pictures do what I intended them to do. The document is too large to attach due to my forum account limitations. Hence the PM method.
I'm on the other side of the Atlantic so my response time will be delayed.
Thanks and take care,
PK
300SD_Dreamer likes this.
Mahone Bay is offline
post #7 of 15 (permalink) Old 01-20-2015, 05:55 PM
bob393's Avatar
Date registered: Jan 2005
Vehicle: 1987 560 SEL
Quoted: 88 Post(s)
This has the potential of being a great thread!
bob393 is offline
post #8 of 15 (permalink) Old 01-20-2015, 07:19 PM Thread Starter
GREAT Input so far!! 20Jan2015.
I put the info above into the first Post using "EDIT" for easier reference.
I hope to review Mahone Bay's document soon.
So can I infer that putting the dash back ON, is a luck-shot?
post #9 of 15 (permalink) Old 01-21-2015, 10:17 AM
gogi's Avatar
Date registered: Jan 2008
Vehicle: 1991 560sec. 1969 280SL
Quoted: 238 Post(s)
Smile Interested dash
Hello,
I'm wondering what color the dash pad you have is and the under dash carpeted knee panels are. Thanks very much.
Dave.
gogi is online now
post #10 of 15 (permalink) Old 01-21-2015, 10:18 AM
281lxm's Avatar
Quoted: 436 Post(s)
The dash has some cracks and is the standard blue/black. The rest of the stuff is 268 grey
281lxm is offline
