front door wood warping question - Mercedes-Benz Forum
post #1 of 22 (permalink) Old 12-31-2014, 04:46 PM Thread Starter
vdubpower's Avatar
Date registered: Nov 2003
Vehicle: 1985 500sel and 500sec 2012 E63 1989 Porsche 911
Quoted: 545 Post(s)
yeah so the wood has warped so its basically lost is form against the metal backing
the laquer and finish is still perfect, no fade or cracks..
is there anything i can do to repair this simply?
ive got the door off as I was Dynmatting the doors and this is the last one....thought I was done with this project and now gotta deal with this
thanks
1985 500SEL Euro Nautic Blue - A Classic Beauty
1985 500SEC Euro Nautic Blue
1989 Porsche 911 Carrera Silver Anniversary Edition
2012 E63 AMG Iridium Silver - Performance Package
vdubpower is offline
post #2 of 22 (permalink) Old 12-31-2014, 05:02 PM
GreenT's Avatar
Date registered: Mar 2013
Vehicle: 1995 S500 - 1986 420SEL
Quoted: 10413 Post(s)
Hard to tell without pics but you should be able to glue it and clamp it back together.
GreenT is offline
post #3 of 22 (permalink) Old 12-31-2014, 05:11 PM Thread Starter
vdubpower's Avatar
Quoted: 545 Post(s)
yeah ill post some but my fear is because the contour has been lost due to warping. that if i glue and clamp im gonna crack the wood
post #4 of 22 (permalink) Old 12-31-2014, 05:17 PM
GreenT's Avatar
It depends. Some glues works with moisture that you can also use to soften the veneer and help reshape it. That, pads with clamps, and time, will get you there.
GreenT is offline
post #5 of 22 (permalink) Old 12-31-2014, 05:28 PM Thread Starter
vdubpower's Avatar
Quoted: 545 Post(s)
i got a little hot glue gun, but i dont think it will do the trick
ID:	1264530   Click image for larger version
post #6 of 22 (permalink) Old 12-31-2014, 05:48 PM
GreenT's Avatar
That's an easy fix. Gorilla glue should work, spray a little water in between and clamp using some thick fabric to protect the epoxy finish.
Let it sit for a day or two, don't rush it.
GreenT is offline
post #7 of 22 (permalink) Old 12-31-2014, 05:51 PM
281lxm's Avatar
Date registered: Dec 2011
Vehicle: 1991 560 SEC 1994 E500 2014 E350 Cab
Quoted: 435 Post(s)
I agree I think some humidity is in order, that is what seperated the glue ultimately. I have had success with a steamer for wall paper. Takes a bit to heat it up, but use the hose end, not the big white attachment and you can get steam there but becareful @You can burn the skin off your hands pretty quick.
_____________________________________________
1991 560SEC 199 /268, 17" RS90'S, Eibach springs, Bilstein HD shocks, Custom rear sway bar, Euro Headlights, Custom ceramic coated headers and down pipes with stainless dual exhaust, W140 glass sunroof, dog ear trunk spoiler, OEM Skid Plate, Euro bumpers, wood refinish and restored.
281lxm is offline
post #8 of 22 (permalink) Old 12-31-2014, 06:01 PM Thread Starter
vdubpower's Avatar
Quoted: 545 Post(s)
ok cool, ill give it a try, i have a steamer for spot cleaning, ill give it a try with gorilla glue rather than the glue gun
or else ill move back to south florida, plenty of wetness there
post #9 of 22 (permalink) Old 12-31-2014, 06:25 PM
Date registered: Feb 2008
Vehicle: Too many to list
Quoted: 1508 Post(s)
Gorilla glue expands like expanding foam
Use super glue /crazy glue for instant bond
tusabes is offline
post #10 of 22 (permalink) Old 12-31-2014, 10:27 PM Thread Starter
vdubpower's Avatar
Quoted: 545 Post(s)
will gorilla glue dry thin so there is no gap between the metal and wood, the glue gun dries as thick as its put on so not the best for this project thus far
