Driveshaft rebuild and bad centering bushings? - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 07-14-2014, 03:06 PM Thread Starter
Date registered: Sep 2013
Vehicle: 1989 300SE
Quoted: 13 Post(s)
After I finish with the front end, I am going to do the driveshaft on my way to the rear end. I know the flex discs are bad, but how do you tell if the centering bushings are bad?
emdcksn is offline
post #2 of 11 (permalink) Old 07-14-2014, 03:21 PM
mramay's Avatar
Date registered: Feb 2005
Vehicle: Two '87 570SECs, one '87 560SEL
Quoted: 256 Post(s)
I grabbed the driveshaft near the center bearing and moved it back and forth to check stiffness. Couldn't tell if it was bad so I put in the new bearing "because I was there", and it felt about the same. Inexperience on my part? Likely. Replaced a good bearing with a good bearing? Also likely.
If you are going to do the flex disks, then do the center bearing, "because you are there". It's inexpensive and you have to drop the drive shaft to do the disks. Just make sure when you separate the forward portion of the drive shaft from the rear section you mark it so the splines go back EXACTLY the same. Just remember to use some blue Loctite on the two bolts that hold the center bearing in place.
Blasphemous Mike
US '87 560SEC with Euro headlights, clear markers, H&Rs, 17x8.5/Nitto's, ATE slotted rotors with ceramic pads, BergWerks FGS, 3.07 Limited Slip. '87 560SEL with Euro Headlights, lowered, 235/40/17's
mramay is offline
post #3 of 11 (permalink) Old 07-14-2014, 03:40 PM Thread Starter
Vehicle: 1989 300SE
Quoted: 13 Post(s)
Sorry, not the center bearing but the centering bushings at each end of the drive shaft. Is this a even a wear item that goes bad? The flex disc's, center bearing and rubber bearing boot are already on the list for sure.
emdcksn is offline
post #4 of 11 (permalink) Old 07-14-2014, 03:55 PM
wooky_chew_bacca's Avatar
Date registered: Oct 2009
Vehicle: '91 560SEC, '91 300SE (sold), '98 Yota, '02 S-10 Hauler
Quoted: 1282 Post(s)
RATS, I didn't do the blue Loctite I did replace the carrier and the center bearing. The centering sleeves on mine seemed to be part of the shaft and they were ok. Here's a couple of pics from mine done last fall (along with a boatload of OTHER stuff I had to do)
The marks on the shaft painted to see easier and the age cracks in the bearing carrier
Name:	Rear Flex Disc and Center Bearing 002.jpg
ID:	1036450   Click image for larger version
Name:	Rear Flex Disc and Center Bearing 008.jpg
Some days it's just not worth chewing through the restraints
My Stable:
'91 560SEC "Ursula"
'91 300SE (sold) "Sadie"
'11 Suzuki SX4 Sport Sedan
'02 S-10 Truck
'72 SeaBird boat, "Riff Raft", overhaul restarted
Dif-tor heh smusma
I'm surprised that NOBODY has asked me what this is / means
LOL
wooky_chew_bacca is offline
post #5 of 11 (permalink) Old 07-14-2014, 04:30 PM Thread Starter
Vehicle: 1989 300SE
Quoted: 13 Post(s)
Thanks Wooky, how hard was the bearing to remove/reinstall? Mercedes source says it is difficult and needs a special piece of pipe?
emdcksn is offline
post #6 of 11 (permalink) Old 07-14-2014, 04:47 PM
mramay's Avatar
Quoted: 256 Post(s)
I claim Senior Moment!!! :-)
Oops, bushings. My experience is with the disks and the center bearing. But, I've not seen any wear on the bushings on the driveshaft ends that center the driveshaft for the transmission and differential, nor any requirement to refurbish or even check them. I could be wrong (see above), but unless there is a noticeable slop there, I'd not worry.
wooky_chew_bacca and GreenT like this.
Blasphemous Mike
mramay is offline
post #7 of 11 (permalink) Old 07-14-2014, 04:58 PM Thread Starter
Vehicle: 1989 300SE
Quoted: 13 Post(s)
Thanks. I'll check for any play once the disc's are unbolted.
emdcksn is offline
post #8 of 11 (permalink) Old 07-14-2014, 06:05 PM
Well since I was replacing both the carrier and the bearing I just had to get the old off the shaft, came off fairly easy using a short prybar I have here (looks like a bent flat tip screwdriver) and just worked my way around til it popped off
Setting the new bearing in the carrier I used a short pipe nipple of the same diameter and tapped it in, same with the bearing to the shaft being VERY careful not to let it slip and mess up the seal. You can probably tell I don't have too many of the "special" tools here, my Uncle Art (R.I.P) taught me to work with what ya have on hand, the only man I knew who could tune a car by ear and have it within specs
autologic likes this.
My Stable:
'91 560SEC "Ursula"
'02 S-10 Truck
Dif-tor heh smusma
LOL
post #9 of 11 (permalink) Old 07-14-2014, 06:49 PM Thread Starter
Vehicle: 1989 300SE
Quoted: 13 Post(s)
Thanks Wooky
wooky_chew_bacca likes this.
emdcksn is offline
post #10 of 11 (permalink) Old 01-20-2019, 12:08 AM
Date registered: Aug 2011
Vehicle: Diesels om616 -> om606
Quoted: 85 Post(s)
awakening an old thread when i was searching for the dimensions of said bearings, aswell as the centering bushings.
ive swapped countless of center-bearings on different benzes without any special pipe.
the difficult part is normaly getting the old one out, i just use a hammer, and something to tap it out with "from above" getting it back in is a lot easier.
the lovely Kent Bergsma at Mercedessource loves selling his special kit, tools and his own unique compounds of snakeoil.
apperantly you need a special tool to undo the shockmounts, instead of a normal spanner. (22mm if i recall correctly)
Hope you had success with your swap anyhow
(with or without a special pipe)
Daily: w123 om602 7.5mm 200whp
special/projects/storage: 20 cars +
swampmonkey is offline
