1991 350SD ASD Operation - Page 2 - Mercedes-Benz Forum
post #11 of 13 (permalink) Old 04-05-2014, 09:39 AM
Premium Member
Dr.Grillz's Avatar
Vehicle: Mercedes
Quoted: 277 Post(s)
In my case, it was the accumulator. Even at idle, it sounded as someone was taking a hammer to my car with the sound coming from behind the firewall on the driver's side. At speed, the sound was less obvious. Also noted, the ASD is pumped via a SLS pump thats exactly the same as the ones found on a 560. There are hoses that run from it. When the car was in idle, you can see the hoses react to the "knock" sound I was hearing coming from the ASD assembly.
Dr.Grillz is offline
post #12 of 13 (permalink) Old 04-23-2014, 05:17 AM Thread Starter
Date registered: Dec 2007
Vehicle: 1991 350SD
Hats off to Dr. Grillz who nailed this one...received the accumulator ($98), installed it and bled the system all in less than an hour...problem solved!
ianrandom likes this.
_________________________________
1985 Volvo Diesel Wagon 320,000 (sold)
1983 300TD 385,000 mi (sold)
1987 300D 280,000 mi (sold)
2008 ML320 CDI 190,000 mi
1991 350SD 167,000 mi
w2hmh is offline
post #13 of 13 (permalink) Old 03-19-2018, 11:32 AM
Date registered: Jan 2010
Vehicle: 1989 300SE EURO
Quoted: 22 Post(s)
Availability of ASR and ASD
Originally Posted by Dr.Grillz View Post
ASR and ASD both utilized that little window in the speedometer that would light up when activated.
A little info on the two from a 1991 article that provides good info. I have driven two cars with ASD (my 190E AMG and a 2.5-16) and can say that ASD is a great option to have and beneficial on snowy roads.
"ASD and ASR have been offered in Mercedes cars sold in Europe the last two years."
I think the cars available with ASD or ASR and when as mentioned in this article might be a little bit misleading.
Here's some other information I found on availability of ASR and ASD in Europe:
- ASD (presented at IAA 1985) was only offered for the I6 models from 1987 on.
- ASR I (presented at IAA 1985) was available only on the larger V8 models from 1987 on.
- Starting 1989 ASR II was available on all models
[source: http://5komma6.mercedes-benz-passion...-asd-und-asr/]
steh-fan is offline
