Post ECE Code 822 replacement cams (24/25) available. Now taking orders. - Page 8 - Mercedes-Benz Forum
post #71 of 80 (permalink) Old 05-22-2015, 06:27 AM
stimpy451's Avatar
Date registered: Jan 2015
Vehicle: 1988 560 SEC, 2007 CLK350, 1967 Porsche 911S, 1967 Pontiac Firebird 400, 1968 Pontiac GTO Convert.
Quoted: 54 Post(s)
Well, you're just a genius, aren't you. I read the thread. I have a good block and have about 30 years of airframe and powerplant experience which I think gives me the ability to put some goddamn cams in a car. I'm not backpedalling and I'm not questioning the product.
You posted at one point - and you seemed upset - that only your friends bought your cam sets.
That's about all you'll get with the methodology you employed. I'm sorry I feel that way with the information at hand. I don't know you, and I don't really want to now.
Too busy for flame wars with old guys on the interwebs. I'll let myself out.
stimpy451 is offline
post #72 of 80 (permalink) Old 05-22-2015, 08:06 AM
~BANNED~
Date registered: Jun 2013
Quoted: 511 Post(s)
I see both sides for this. I understand your frustration, Stimpy, but you are being a tiny dick about it. Where else can you find a set of performance cams for $450??
If you're genuinely interested why not say to Mike: "Hey, I'll buy your cams for full-price, I'll install them, and I'll post before and after dyno runs; and if I do all that how about kicking me back $225?" That may have worked better.
Taking the elementary school approach was a bad idea.
Luke Colorado is offline
post #73 of 80 (permalink) Old 05-26-2015, 08:50 AM
1mbzdoc's Avatar
Date registered: May 2014
Vehicle: 2010 glk350 91 560sec 74 230 66 220seb 86 300e 88 300e
Quoted: 203 Post(s)
Originally Posted by mclare View Post
I do have the timing card, but I'm not going to publish it here for obvious reasons.
I will repeat what I asked the new guy, what are your engine re-build plans? because you cannot just pop these cams in, you need to do your heads. You do understand why, right?
Yes I do understand that when the base is cut the valve stem will have to be longer or shimmed to take up clearence. I also understand that this will also change the angle of the rocker arm and push the valve sideways more than it already does. If base is cut the best way to keep geometry correct would be to raise the lifter the same as valve stem gets raised. I also understand that cutting valve seats will lower comp and that valve timing can still fill the cylinder. I have been building racing motors for harleys since the 90's. I change my own guides and grind my own seats. I assemble everything after I get it back from machine shop myself. I understand the trouble you went through to get these and love that you are willing to pass on your good fortune. please pm me if you will give up the info thanks for your time.
current stable
2010 glk350-86 300e-88 300e white-66 220seb-74 230- 2012 chevy cruze eco wifes commutor 40plus mpg on regular. 1970 gmc 2500- 2002 gmc 2500hd duramax/allison-50s something willeys pickup-74 harley fxe-92 harley flhtcu ultra classic-2017 harley road glide special- 2018 road glide special-98 special construction harley powered.-
1mbzdoc is offline
post #74 of 80 (permalink) Old 05-26-2015, 09:11 AM
~BANNED~
Quoted: 511 Post(s)
Well, I don't understand... is this because the cams are reground and their diameter is smaller?
post #75 of 80 (permalink) Old 05-26-2015, 09:22 AM
1mbzdoc's Avatar
Quoted: 203 Post(s)
Yes smaller diameter means cam is farther away from rocker arm. clearance needs to be taken up somehow. Either taller rocker arm, longer valve stem or taller lifter.
current stable
1mbzdoc is offline
post #76 of 80 (permalink) Old 05-26-2015, 09:49 AM Thread Starter
mclare's Avatar
Date registered: Aug 2008
Vehicle: 2012 CL550 4MATIC Coupe
Quoted: 311 Post(s)
Send a message via Yahoo to mclare Send a message via Skype™ to mclare
Yes Luke, I explained that to you. They are "Short" by 30 thousandths and that's why you have to do the heads and a valve job, to compensate for that.
Current Stable:
2012 CL550 C4 4MATIC Coupe
Past cars:
1991-560 SEC AMG - Coupe - 199/261 - 300 HP Custom Built Motor - Highly Modified Coupe.
1990-560 SEL - Sedan - 199/261 - Stock. Euro Headlamps & Wipers
1987 560 SEC Black/Tan
1988 420 SEL Champagne/Brown
mclare is offline
post #77 of 80 (permalink) Old 05-26-2015, 09:54 AM Thread Starter
mclare's Avatar
Quoted: 311 Post(s)
Well I can see that you clearly understand, not like that other clown who was just fishing for free stuff.
Since these are nearly direct, perfect copies of stock 822 cams with only a "Slight" modification to get around copyrights, There are no surprises with my "Design" since it's MB's design.
I will give you a Cam Card with your purchase of a set, but I will not just give out the specs to everyone for free.
Current Stable:
Past cars:
mclare is offline
post #78 of 80 (permalink) Old 05-26-2015, 12:27 PM
~BANNED~
Quoted: 511 Post(s)
Thanks Mike. That conversation was many months ago and information leaves my short-term storage quickly.
post #79 of 80 (permalink) Old 10-18-2018, 08:55 AM
tomrmaguire's Avatar
Date registered: Mar 2018
Vehicle: 05 CL55 AMG, 04 S430 4Matic, 88 560SL
Mike,
Are you still doing this? Rebuilding my M117 heads and am intrigued.
Tom
tomrmaguire is offline
post #80 of 80 (permalink) Old 10-19-2018, 06:59 AM Thread Starter
mclare's Avatar
Quoted: 311 Post(s)
Originally Posted by tomrmaguire View Post
Mike,
Tom
Yes I am Tom. Call me at: 661-618-9590
Current Stable:
Past cars:
mclare is offline
