What did you do to your 126 today? - Page 972 - Mercedes-Benz Forum
post #9711 of 10368 (permalink) Old 09-26-2018, 08:21 PM
gwg
gwg's Avatar
Date registered: Nov 2014
Vehicle: 1991 300SE W126, 1985 300SL R107, 1991 190E 2.3 (caretaker)
Quoted: 42 Post(s)
Lovely car, @newtome190e and couldn't agree more about the sway bar. For the next level, try H&R springs!
gwg is offline
post #9712 of 10368 (permalink) Old 09-27-2018, 08:42 AM
1783pictures's Avatar
Date registered: Feb 2016
Vehicle: 85 500SEC (Euro), 87 560SEC (now sold)
Location: Eastern NC (formerly China, NYC and Connecticut)
Quoted: 334 Post(s)
Cool Awesomeness
Originally Posted by newtome190e View Post
Matt (1783pictures) sold me the custom Hellwig rear sway bar that he couldn't use for his gen I SEC. I just had it installed on my 300SE, and I'm absolutely thrilled with it.
Craig, with the hurricane and loss of power etc. I had no idea if the box ever arrived or if you installed it. I am glad to see it did the trick. How I wish it would have worked for me, but such is life. Enjoy and don't drive too too fast!
By the way, love the color of your SEL. She is simply gorgeous.
1783pictures is offline
post #9713 of 10368 (permalink) Old 09-28-2018, 04:35 AM
Date registered: Dec 2013
Quoted: 54 Post(s)
@1783pictures Matt: I'm glad you and your SEC are ok following the hurricane. And thanks for the compliments on my car - nautical blue is indeed a beautiful color. I initially had my heart set on finding a car in either 199 blue-black or 904 midnight blue. But then this car sort of fell in my lap, and I fell instantly in love with the color!
@gwg : Thanks! I noticed you recently upgraded to H&R Springs. Any more pics/thoughts on how it sits and rides? Down the road I might consider it too, when my current suspension needs a refresh.
newtome190e is offline
post #9714 of 10368 (permalink) Old 09-29-2018, 02:06 PM
kevdupuis's Avatar
Date registered: May 2016
Vehicle: 1985 300 TD 1981 300 SD
Quoted: 38 Post(s)
Stopped in at the transmission shop yesterday to have a look at the disassembled 722.3 from the 81 on the work bench, as expected the reverse clutch pack was worn out, the rest were fine but are being replaced along with the seals & bushings. What I didn't expect was that the scraping sound in reverse wasn't a bad bearing but due to the wear in the reverse clutch pack the apply piston was coming into contact with the rivet heads on the front drum, aside from some wear marks on the apply piston there's no real damage to the parts and will be reused. We also sent the torque converter out to be cut open and checked over, so barring any unforeseen problems the SD should be back on the road Wednesday.
MBL87560SEC likes this.
kevdupuis is offline
post #9715 of 10368 (permalink) Old 09-29-2018, 03:19 PM
MBL87560SEC's Avatar
Date registered: Jul 2004
Vehicle: 1991 500SEC sub 50K mi. 1987 560SEC Now 150K mi. 2018
Quoted: 418 Post(s)
Sounds GREAT man!
Congrats!
MBL
91 500SEC EURO Germany
87 560SEC USA 49 State Version
MBL87560SEC is offline
post #9716 of 10368 (permalink) Old 10-03-2018, 06:10 PM
kevdupuis's Avatar
Quoted: 38 Post(s)
Trans just going together, my trans guy also sent the front drum to the machine shop to get the rivets removed then have the holes tapped, counter sunk and chamfered screws installed as per Mercedes TSB in order to prevent contact between the reverse apply piston and the front drum again. According to him the TSB covers both 722.3 & 722.4 transmissions. All is set for Friday pickup then it's oil change, rust proofing and snow tire installation time, I also want to make a winter front for the grill.
I thought I had taken some pics of the contact marks on the apply piston and the machine work on the front drum but when I checked my tablet there was nothing, I guess it didn't pick up my finger tapping the screen to take the pictures and I was to distracted to notice. DUH!!!
ianrandom likes this.
post #9717 of 10368 (permalink) Old 10-04-2018, 01:56 PM
Stutz's Avatar
Date registered: Oct 2009
Vehicle: 1999 500SL, 1988 SEC
Quoted: 257 Post(s)
Was back at it today on the head replacement and probably spent 8 hours in the garage. I think I have about 15 to go, and one of the things left to do is change the lower oil pan and that little plastic foot on the oil pump. That should not be hard but its under the car💩💩. Since I sent the parts off to be plated they all came back in one box as you can see from the picture. That makes it interesting trying to figure where things go. I have lots of pictures but of course they are at the wrong angle or not clear etc and since I could not label the parts....... I probably will ask some of you for pictures of your engine. As get more done though the box of bolts gets smaller👍 . I am sure some bolts are not in the right place but they will work. The engine is starting to look great so I am pleased at that. The one snag was installing the new main crank pulley. I thought I had it lined up correctly, and I know it only goes on one way, but, you guessed it, fix bolts went in great, the sixth was off. Those bolts are a sucker to get at as well so lots of swearing. That job will be left to another day when I am fresh. Hopefully I can do some more this weekend and start it up before winter. This has been a huge undertaking and I agree with others that you might as well remove the engine to do all this
ID:	2457729   Click image for larger version
ID:	2457733   Click image for larger version
Stutz is offline
post #9718 of 10368 (permalink) Old 10-04-2018, 10:37 PM
liviu165's Avatar
Date registered: Aug 2013
Vehicle: 1991 560SEC
Quoted: 632 Post(s)
While you have the oil pan off, I recommend replacing the rubber o-ring of the oil level connector on the block (the larger o-ring). That o-ring is known to leak after a while and now is a good opportunity for you (to replace it, the connector slides inside the engine, so the oil pan must be off).
ID:	2457779   Click image for larger version
ID:	2457781   Click image for larger version
liviu165 is offline
post #9719 of 10368 (permalink) Old 10-04-2018, 10:44 PM
liviu165's Avatar
Quoted: 632 Post(s)
Just curious, what makes the H&R springs an upgrade?
liviu165 is offline
post #9720 of 10368 (permalink) Old 10-05-2018, 01:07 PM
ianrandom's Avatar
Date registered: Jul 2008
Vehicle: 1986/1990 W126
Quoted: 1206 Post(s)
Wet sanded and polished the upper half of the rear door. Last time it had paintwork it came back with major orange peel there, although more towards the handle end of things. I need to do the fuel filler area really and it will look better. You only notice it from certain angles but it was bad.
It looks OK now in the pic, but when I went to fill with fuel I saw (bright lighting at the petrol station) its incredibly swirly still. Oh well, another time. It looked lovely after a wash, so no urgency.
Wet sanding is time consuming! I'm new to it, only did it once before. I might have to get my buffer out to help me next time.
ID:	2457831   Click image for larger version
dadrab likes this.
'86 420SE
'90 420SEC
Daily transport 9spd Giant DH Comp downhill bike
ianrandom is offline
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
