GTS 5.8 Camshaft - Mercedes-Benz Forum
post #1 of 28 (permalink) Old 04-17-2012, 06:43 PM Thread Starter
Date registered: Feb 2008
Vehicle: 1982 500 SEL 126 V8 Euro Model; Engine type: 117961; tranmission: 722350
Quoted: 9 Post(s)
GTS 5.8 Camshaft
Need help from the experts and euro 500 owners: Camshaft No. "GTS 5.8" stamped in my 500SEL Euro hot rod. What do I have? Would this be the reason why this Euro 500SEL runs harder than my old Euro 6.9 AMG?
zukamb is offline
post #2 of 28 (permalink) Old 04-20-2012, 08:32 PM
jhodg5ck's Avatar
Date registered: Sep 2002
Vehicle: Depends on the day!
Quoted: 24 Post(s)
Send a message via AIM to jhodg5ck
never heard nor come across anything of that nature. Given the # of tuners running about in the 80's just about Anything is possible!
Best bet, have them Cam Dr'ed up, then you'll know what you have..
Enthusiast Service, Restoration & Tuning.
87 Hammer Wagon 6.0L 32V
87 Hammer 6.0L 32V
87 Hammer Coupe 6.0L 32V
86 560SEL AMG 6.0 32V
etc....
Mercedes Repair Atlanta
jhodg5ck is offline
post #3 of 28 (permalink) Old 04-21-2012, 07:05 PM Thread Starter
Quoted: 9 Post(s)
Thanks Jonathan; I'm not much of a mechanic so what is "Dr'ed up" ? and how to go about doing it?
zukamb is offline
post #4 of 28 (permalink) Old 04-21-2012, 10:00 PM
Frankthemoneyman's Avatar
Date registered: Apr 2008
Vehicle: 190e2.6 sold, 300E part,300 SEL pending final verdict, 560SEL SOLD, 560 SEC Sold, 300 TD given away
He probably meant ‘Degreed’ ?
If you have a stock cam for comparison, you could compare the two by simply pulling your valve cover and mic the lift and compare the profile and duration.
Option two, any old hot rod shop or machine shop should be able to tell by the above mentioned procedure.
Oldest trick in the book and since cam installation borders on drive way hero capability, it was a popular modification in Europe during the 80’s. Pre- smog days.
Frankthemoneyman is offline
post #5 of 28 (permalink) Old 04-21-2012, 11:50 PM
500SEC_AMG's Avatar
Date registered: Feb 2009
Vehicle: 500 SEC AMG Mod'd
Quoted: 5 Post(s)
Send a message via AIM to 500SEC_AMG
Thats funny I am changing my Euro 500SEC cam tomorrow. I was looking at 87 SEL cams on a supposed ECE motor and they didn't look a lot different, I guess the only way is to look at the No# on the back of the cam.
500 SEC Euro Classic White repaired!!
1987 Japanese 500 SEL Tri Ys and Velour
2000 CLK 430
Photojournalist
Collector of Vinyl
500SEC_AMG is offline
post #6 of 28 (permalink) Old 04-24-2012, 02:05 PM Thread Starter
Quoted: 9 Post(s)
In trying to decipher the origins of my "GTS 5.8" cams can you check the numbers on the ECE cams? My "GTS 5.8" numbers are not in the back of the cams but they are cast between the 2d and 3d cam lobes from the front visible thru the oil cap hole.
zukamb is offline
post #7 of 28 (permalink) Old 04-24-2012, 05:44 PM
jhodg5ck's Avatar
Quoted: 24 Post(s)
sounds like someone spent some $$$$$ and had blanks made so as to avoid the change in base circle. Nicely Done..
87 Hammer 6.0L 32V
etc....
jhodg5ck is offline
post #8 of 28 (permalink) Old 04-24-2012, 08:25 PM
500SEC_AMG's Avatar
Quoted: 5 Post(s)
I just stripped one of the head bolts. The hex hole is stripped any suggestions on what to do to remove them ?
2000 CLK 430
Photojournalist
Collector of Vinyl
post #9 of 28 (permalink) Old 04-24-2012, 08:45 PM
jhodg5ck's Avatar
Quoted: 24 Post(s)
buy a cheap set of 1/2 inch torx bits and drive the appropriate oversize bit in..it'll come free. 5lb sledge works well.
87 Hammer 6.0L 32V
etc....
jhodg5ck is offline
post #10 of 28 (permalink) Old 04-24-2012, 10:14 PM
500SEC_AMG's Avatar
Quoted: 5 Post(s)
I will do that, have the torx already, CLK 430 requires that crazy shit. Should I tap the bolts hard to free them up?
2000 CLK 430
Photojournalist
Collector of Vinyl
camshaft id RJMBurgess W126 S,SE,SEC,SEL,SD,SDL Class 7 01-16-2012 06:32 AM
camshaft v8alligator Unimog 17 07-08-2011 03:56 PM
'07 C280 - Oil leak around Camshaft adjuster and Camshaft Position sensor pcy W203 C-Class 0 07-12-2010 07:40 AM
camshaft, camshaft bearings, and rocker arms lyrics10 W126 S,SE,SEC,SEL,SD,SDL Class 5 08-24-2007 04:14 PM
500 SEC camshaft Splas W126 S,SE,SEC,SEL,SD,SDL Class 0 05-18-2004 03:27 AM
