Timing Chain Help / Advice needed - Mercedes-Benz Forum
post #1 of 14 (permalink) Old 03-08-2012, 03:08 PM Thread Starter
Date registered: Feb 2012
I apologize for the novel but I am trying to provide as much info as possible. Thanks to anyone who actually reads and can provide help. I am working on a 1980 500 SEL and doing the timing chain.
When I removed the valve covers I noticed that on both inboard chain guides were completely missing. The chain had obviously been grinding the pins because they had deep grooves worn in them. Who knows how long the motor has been like this!! Not only were the pins worn, but also the timing cover and the side of the cylinder head had grooves from the chain rubbing against it.
I decided to pull the entire front of the motor apart so I could see exactly what was going in, and in case the guides had somehow fallen down in the TC I wanted to extract them.
This morning I was actually able to completely remove the timing cover but I had to remove it in a manner that I don't believe I'll be able to reassemble and have the oil pump chain installed properly. How on earth am I supposed to do that? In order to remove the timing cover I also had to cut the timing chain too because it really wanted to pull the chain sprocket off the crankshaft while I was pulling the TC
Am I supposed to put the timing chain all in, and then break the oil pump chain and reinstall it after putting the cover back on?
Also, have you guys had good luck with using the O rings to keep a seal? I'm inclined to use RTV but I don't want to do something stupid.
Thanks!
TBIAgent69 is offline
post #2 of 14 (permalink) Old 03-08-2012, 03:59 PM
Date registered: Sep 2007
Vehicle: 90 420SEL 240,000 miles strong
Send a message via AIM to RickASolis
Wow, go play the lottery, cause your the luckiest man alive right now
Get your timing chain and rails done like you should. I would know more than anyone!! The noise it makes when it goes will make you cry.
RickASolis is offline
post #3 of 14 (permalink) Old 03-08-2012, 04:06 PM
Date registered: Apr 2006
Vehicle: 1983 380SL, 2000 S430, 1991 420SEL (retired) - RHD
Quoted: 386 Post(s)
Do a search, there's heaps of stuff including a "how to" video reference.
Aussiemerc is offline
post #4 of 14 (permalink) Old 03-09-2012, 02:17 AM Thread Starter
Lol I tried. Can you give me specific key words to look for because Timing Cover, and Timing chain brought up a bunch of threads about parts lists or unrelated things.
I tried searching on Youtube too but I must be looking for the wrong thing.
BTW, there were absolutely NO broken chain guides in the motor. It must have just been broken off manually and never replaced!!
post #5 of 14 (permalink) Old 03-09-2012, 07:22 AM
LASwede's Avatar
Date registered: Feb 2004
Vehicle: '02 E320 Wagon, '13 Chevrolet Volt
I think pieces fall down in the oil pan if they do not get stuck inside the engine...
I have also heard that you can tie the new chain onto the old one and and turn the engine, to easier get the new chain on. If you already took it off, it is another matter.
LASwede is offline
post #6 of 14 (permalink) Old 03-09-2012, 08:37 AM
Date registered: Aug 2011
Vehicle: 1985 300E US Champagne, 1978 280SE Euro Milan Brown Metallic, Gen1 1985 500 SEC Euro Paget Red
Quoted: 4 Post(s)
Have you pulled the oil pan and not found any bits of guide rail? That's bizarre.
I've followed this tutorial here:
450 - M117 Timing Chain Replacement
But it doesn't discuss removing the front cover or changing the lower guide rails.
The last time I removed and replaced guide rails I did it with a stiff wire, bent to shape and carefully slotted them in, then pushed the pins in carefully until they were seated. It was much easier than I expected. However with the front cover off, you can put the guide rail pins and guide rails in first, then just install the cover over them. This is how it was done at the factory. I always wondered why they used pins rather than bolts, until I saw a video of an AMG 6.3 being assembled on the internets.
Most RTV (Room Temp. Vulcanized) silicone adhesives are bad for aluminum and will cause corrosion around bolts over time.
I recommend not using RTV silicones on aluminum engines. They're all corrosive to some extent, especially where dissimilar metals meet.
toxonix is offline
post #7 of 14 (permalink) Old 03-09-2012, 08:39 AM
Quoted: 4 Post(s)
Also, I'm not sure why the crank sprocket would want to come off with the TC, sorry.
toxonix is offline
post #8 of 14 (permalink) Old 03-09-2012, 12:15 PM
Quoted: 386 Post(s)
Smile Video/photos of chain replacement
[QUOTE=TBIAgent69;5151244]Lol I tried. Can you give me specific key words to look for because Timing Cover, and Timing chain brought up a bunch of threads about parts lists or unrelated things.
I'll find it because I need it myself soon. It may be in the BenzWorld 107 forum -Look in the EGV107 and go to timing chain. The trouble is there is so much to look at. I'd do it now but I'm off to golf- first nice fine day in a while so the Benz will have to wait!
post #9 of 14 (permalink) Old 03-10-2012, 03:59 PM
Quoted: 386 Post(s)
Found one:
PeachPartsWiki: M116/117 Timing Chain replacement- I think it's
PeachPartsWiki: M116/117 Timing Chain Replacement
post #10 of 14 (permalink) Old 03-10-2012, 04:38 PM
mramay's Avatar
Date registered: Feb 2005
Vehicle: Two '87 570SECs, one '87 560SEL
Quoted: 256 Post(s)
I had a portion of a broken guide get stuck about half way down and took me two (2) days to get that #$%^&* POS chunk out of the engine. With the oil pan off, I could look up and *just* see the thing. If you have a part of a guide up top, the rest is in the engine.
Blasphemous Mike
US '87 560SEC with Euro headlights, clear markers, H&Rs, 17x8.5/Nitto's, ATE slotted rotors with ceramic pads, BergWerks FGS, 3.07 Limited Slip. '87 560SEL with Euro Headlights, lowered, 235/40/17's
mramay is offline
'73 450SL timing chain replacement advice needed. rcrvine Vintage Mercedes-Benz 7 07-10-2011 05:41 PM
Help needed with timing chain chiro W201 190-Class 4 09-28-2010 02:18 PM
Timing chain help needed sat1962 W126 S,SE,SEC,SEL,SD,SDL Class 18 12-24-2009 01:10 PM
Timing Chain Advice, Help Needed streetrules W123 E,CE,D,CD,TD,TE Class 0 07-16-2005 12:14 AM
parts needed to fix timing chain ibrahim83 W126 S,SE,SEC,SEL,SD,SDL Class 5 10-09-2003 06:16 AM
