W126 Keyless Entry Installation Made Easy - Page 7 - Mercedes-Benz Forum
post #61 of 66 (permalink) Old 04-01-2019, 09:51 AM
Date registered: Apr 2018
Vehicle: 1988 300SEL W126
Quoted: 116 Post(s)
Thank you, check the link below if you are interested, you can use anyone you like,
https://www.ebay.com/itm/2004-2009-L...AAAOSwglZZcDhN
Originally Posted by partnumber187 View Post
Apologies, I read your post as a query about the quality of the unit itself. That does sound annoying and expensive. The batteries in the remote for my generic keyless unit are a common size disc battery that cost $5 for two at Home Depot or similar.
Faiz, that looks good. Funny we had discussion not too long ago in the W201 board about using a Lexus lock alert buzzer, but no one tmk has installed one yet.
partnumber187 likes this.
Faiz Jan is offline
post #62 of 66 (permalink) Old 04-02-2019, 06:12 AM Thread Starter
mclare's Avatar
Date registered: Aug 2008
Vehicle: 2012 CL550 4MATIC Coupe
Quoted: 311 Post(s)
Send a message via Yahoo to mclare Send a message via Skype™ to mclare
Originally Posted by Faiz Jan View Post
Thank you sir, what a great writing!! as a plan B do you know which pin to target on X-30 block in case i decided to install it there ?
I did a complete writeup on the X-30 block and posted the link in my first post on this thread.
I'm sorry the pics disappeared AGAIN! Edit rights have been taken away, so I cannot restore them again. I restored ALL of the pics in all of my threads two years ago, but they have poof'ed again.
Sorry.
RobertD likes this.
Current Stable:
2012 CL550 C4 4MATIC Coupe
Past cars:
1991-560 SEC AMG - Coupe - 199/261 - 300 HP Custom Built Motor - Highly Modified Coupe.
1990-560 SEL - Sedan - 199/261 - Stock. Euro Headlamps & Wipers
1987 560 SEC Black/Tan
1988 420 SEL Champagne/Brown
mclare is offline
post #63 of 66 (permalink) Old 04-02-2019, 06:42 AM
Premium Member
RobertD's Avatar
Date registered: Mar 2018
Vehicle: 1991 560 SEL
Quoted: 17 Post(s)
Premium Member
also i bought Lexus RX 350 KEYLESS ENTRY DOOR WARNING BUZZER (eBay item number:112488284176) and plug it to the pink wire (Horn wire).
Ah, interesting! Can I assume this makes a chirp or beep sound when you lock / unlock? Are you mounting this in the trunk as well?
Sent from my moto x4 using Tapatalk
RobertD is offline
post #64 of 66 (permalink) Old 04-02-2019, 07:58 AM
Quoted: 116 Post(s)
No, i ran it outside the trunk from one of the rubber seals in the trunk and i mounted behind the bumper from inside to keep it away from water.
RobertD likes this.
Faiz Jan is offline
post #65 of 66 (permalink) Old 04-12-2019, 06:46 PM
Quoted: 116 Post(s)
This the the final result.
youtu.be/LDq_YAKcW7E
QUOTE=RobertD;17744806]Ah, interesting! Can I assume this makes a chirp or beep sound when you lock / unlock? Are you mounting this in the trunk as well?
Sent from my moto x4 using Tapatalk[/QUOTE]
RobertD likes this.
Faiz Jan is offline
post #66 of 66 (permalink) Old 04-14-2019, 06:02 PM Thread Starter
mclare's Avatar
Quoted: 311 Post(s)
2phast cut down a factory key to use in an aftermarket switchblade remote.
Stereo Updates
I did this as well in my original post. I believe that I showed how to grind them down.
Faiz Jan likes this.
Current Stable:
Past cars:
mclare is offline
Keyless entry installation help craiggotgame W124 E,CE,D,TD Class 136 06-16-2014 06:36 AM
W126 keyless entry? the300dictator W126 S,SE,SEC,SEL,SD,SDL Class 8 05-15-2011 08:44 PM
Keyless Entry for w126 (1989 300 SE whockadoo W126 S,SE,SEC,SEL,SD,SDL Class 14 12-31-2010 10:20 PM
W126 keyless entry Darrylzide General Mercedes-Benz 0 12-30-2010 07:58 PM
Keyless Entry for W126 Cyclepsycho W126 S,SE,SEC,SEL,SD,SDL Class 16 12-30-2010 07:53 PM
