560SEC - Euro vs US differences? - Page 2 - Mercedes-Benz Forum
post #11 of 18 (permalink) Old 06-19-2011, 04:27 PM
bondavi's Avatar
Date registered: Sep 2004
Vehicle: 1983-2007 MB's
Quoted: 829 Post(s)
Affirmative, all US versions were 9:1.
bondavi is offline
post #12 of 18 (permalink) Old 06-19-2011, 04:42 PM
Date registered: Apr 2006
Vehicle: 1990 560 SEL with Euro engine, 1998 SL500 Sport
Quoted: 42 Post(s)
Exhaust setup is different and the EZL is different - 8 pin vs. 4 pin.
The temp gauge is in Celsius, and speedometer in KM although most that are imported into the US are converted to MPH.
There is typically a warning triangle on the inside of the rear deck lid.
The AC setup can be different as well with dual Klima controls.
1990 560 SEL, 1991 560 SEC Euro, Japanese Import
Birmingham, MI
graftdesign is offline
post #13 of 18 (permalink) Old 06-19-2011, 04:56 PM
GGR
Vehicle: W111 Coupe
Quoted: 20 Post(s)
Originally Posted by V12StealthHunter View Post
So all U.S 560s were 9:1 compression? Sweet. All the better for a turbo/super charger upgrade.
Best for a turbo upgrade is the 500 US version: 8:1 CR. I believe the aditional boost this allows more than compensate for the loss of 550cc.
GGR is offline
post #14 of 18 (permalink) Old 02-03-2018, 11:43 AM Thread Starter
Date registered: May 2011
Vehicle: 2 x Mercedes Benz
Originally Posted by bondavi View Post
Euro 560 with triy's had 299hp. That's 61hp diff over US.
Also euros had:
8-pin ezl's with knock sensors (after '88)
2.65 LSD rear end
More aggressive cam profile
Transmission mode selector switch
Do all Euro 560 SECs have the more aggressive cam profile vs the US cars?
The 8-pin vs 4-pin EZL should be easy to spot under the hood for engine I.D. purposes correct?
Is the Euro LSD a clutch type and if so surely they need new clutches after 30 years on the road! Anyone know the cost for this?
Compulsive is offline
post #15 of 18 (permalink) Old 02-03-2018, 01:31 PM
ianrandom's Avatar
Date registered: Jul 2008
Vehicle: 1986/1990 W126
Quoted: 1137 Post(s)
Yes to the clutches in the diff thing. And the 8 pin thing being easier to spot. Not sure about the cam thing.
'86 420SE
'90 420SEC
Daily transport 9spd Giant DH Comp downhill bike
ianrandom is offline
post #16 of 18 (permalink) Old 02-03-2018, 03:56 PM
CH4S Artist
Teutone's Avatar
Vehicle: 1985 500SEC, 1991 190E 2.6.
Quoted: 1759 Post(s)
Did the GenII 560 RUF high compression come with the 2:65 LSD?
On my wrecking yard trips in the past, I had made it a habit to look for LSD. US 560 LSD were 2.47, but Euro cars usually had 2.24 i think.
I know the W116 6.9 came with a 2:65 LSD, that should fit perfectly into a Gen i car.
The Gen II differential has different housing and mounts, but the innards between Gen1 and 2 are the same and can be swapped.
David, what was the rear end on your Gen II Japan 560SEC ?
Also, from looking at quite a few M117 engines with heads off, it looks like the top of pistons indent for the 2 valves are a single rectangle.
I have looked at HV high compression engines where pistons had 2 round indents over the valves
Teutone is offline
post #17 of 18 (permalink) Old 02-03-2018, 05:28 PM
bondavi's Avatar
Quoted: 829 Post(s)
The 10:1 560 motors (822 code) used 16/17 cams, the later 1988 and up uses 24/25, identical profiles, more aggressive at higher RPM than stock standard 180kW model.
Also, these cars came w/ 2.65 LSD's, such as was on my 90 Japanese home market car.
bondavi is offline
post #18 of 18 (permalink) Old 02-04-2018, 05:04 PM
Premium Member
Dr.Grillz's Avatar
Vehicle: Mercedes
Quoted: 276 Post(s)
Hey Horst, long time no chat!
Euro 560's came with 2.65 LSD's (unless it has ASR which is an open differential). US 560's came with 2.47 LSD's (again, if it had ASR, it was open)
Gen I Euro's commonly had 2.24's, some LSD, some not... some also had different ratios depending on option and country of origin.
US 6.9's and Euro 6.9's had different ratios, but would only fit Gen I 126's.... they will not fit a 560.
Teutone likes this.
1980 Mercedes 280TE AMG
1990 Mercedes 560SEL with AMG parts modifications
1991 Mercedes 190E AMG with Brabus 4-cyl M102 2.6
Dr.Grillz is offline
Differences between US and euro 124s eiriksmil W124 E,CE,D,TD Class 24 12-27-2010 11:45 AM
Euro 117.960/2 and 117.963...differences? bondavi W126 S,SE,SEC,SEL,SD,SDL Class 1 09-14-2007 06:16 PM
560sec Amg - Differences? Cacciatore08 W126 S,SE,SEC,SEL,SD,SDL Class 9 08-21-2007 09:05 AM
560SL vs. (560SEL & 560SEC) Engine Differences parrots R/C107 SL/SLC Class 5 03-08-2006 12:48 PM
US / Euro Spec CLK - what are the differences? jonny72 C209/A209 CLK-Class 0 03-11-2004 01:10 PM
