sunroof tubing problem - Mercedes-Benz Forum
post #1 of 17 (permalink) Old 05-15-2010, 01:31 PM Thread Starter
tandm1999's Avatar
Date registered: Feb 2007
Vehicle: 1983 300d turbo 249k (benzoil), 1983 300sd 188k, 1990 560sel 175k, 1985 380se 290k 1990 560sel
ok i have searched the archives and im still having trouble finding what i need , in my sunroof cavity is the cable and the tube it runs thru or rather is guided through , well that tubing is bent and the cable is ow coiled up outside of it ,,, how hard is to replace the tubing and cable , , if anyone has any information or can guide me it would greatly be appreciated
tandm1999 is offline
post #2 of 17 (permalink) Old 05-15-2010, 02:32 PM
Rmac58's Avatar
Date registered: Nov 2007
Vehicle: 2013 MINI Copper S Clubman, '84 300CD-weekend car
Quoted: 139 Post(s)
This is from the FSM. It contains all the jobs necessary.
This is a 126 chassis, that's in your avatar pic, but you list a couple of 300D's, that would be a 123 chassis.
File Type: pdf R&R slising roof cable 77-140.pdf 126.pdf (865.3 KB, 86 views)
File Type: pdf R&R mounting bracket SR motor & gear,126, 77-180.pdf (1.69 MB, 71 views)
Rmac58 is offline
post #3 of 17 (permalink) Old 05-15-2010, 03:54 PM Thread Starter
tandm1999's Avatar
thanks rmac but wow its a task huh , anyway i thank you for the information , and i have a few mercedes diesel and gassers both 123 and 126 bodies
post #4 of 17 (permalink) Old 05-15-2010, 05:22 PM
Rmac58's Avatar
Quoted: 139 Post(s)
Yeah, looks pretty involved. I'm sure it would a similar procedure on a 123.
Rmac58 is offline
post #5 of 17 (permalink) Old 05-15-2010, 06:26 PM Thread Starter
tandm1999's Avatar
well the one im having trouble with is my 1990 560sel not the 123
post #6 of 17 (permalink) Old 05-16-2010, 04:50 AM
Rmac58's Avatar
Quoted: 139 Post(s)
I'm wondering if you can just replace the cable instead of the tube.
Rmac58 is offline
post #7 of 17 (permalink) Old 05-16-2010, 11:31 AM
mclare's Avatar
Date registered: Aug 2008
Vehicle: 2012 CL550 4MATIC Coupe
Quoted: 312 Post(s)
Send a message via Yahoo to mclare Send a message via Skype™ to mclare
He said the tubing is kinked, not the cable. If that's the case, I think you are kinda screwed. You will have to remove the headliner and the "C" pillar covers and I still do not know if you can even get to it then. I had all of that out when I was rebuilding my car and sunroof and you can't really see the guide tube until it comes forward. It is clearly laid in there when the roof panels are being welded in the body shop main assembly. Short of cutting an access hole in your lower roof.??
mclare is offline
post #8 of 17 (permalink) Old 05-17-2010, 01:25 AM
dan500se's Avatar
Date registered: Jul 2008
Vehicle: `81 W123 280E, `83 W126 280SE, `85 W126 280SE, `91 W126 500SE, `96 W202 C180T
Quoted: 8 Post(s)
Send a message via Yahoo to dan500se Send a message via Skype™ to dan500se
I have done last year a whole sunroof change! I have changed the sunroof frame also, all the elements!
The headliner must to be removed and C pillar covers too...The sunroof cable and tubing must to be disconected from the sunroof motor! After that the tubing can be changed as in the pdf description presented above!
Good luck!
dan500se is offline
post #9 of 17 (permalink) Old 05-17-2010, 01:55 AM
mclare's Avatar
Quoted: 312 Post(s)
Good luck!
Good to know! I would not have thought that you could get it out... I need to change out my motor soon.
mclare is offline
post #10 of 17 (permalink) Old 05-17-2010, 05:22 AM
dan500se's Avatar
Quoted: 8 Post(s)
It is much more easyer than apears! I think in that pdf above they are some info about the sunroof motor too...
dan500se is offline
Vacuum tubing help! fester11 Vintage Mercedes-Benz 6 02-08-2009 04:50 PM
Sunroof Problem???? ThorneGator W123 E,CE,D,CD,TD,TE Class 6 04-19-2007 11:19 PM
Vacuum Tubing noeljb R/C107 SL/SLC Class 12 03-19-2006 08:26 PM
sunroof problem jjazac W126 S,SE,SEC,SEL,SD,SDL Class 0 08-07-2004 07:17 PM
Why the exposed tubing? My Self W163 M-Class 11 01-08-2003 06:41 PM
