Smoke From Cluster 560SEL - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 11-30-2009, 09:35 PM Thread Starter
86SEL560's Avatar
Date registered: Nov 2009
Vehicle: 1986 560SEL
Hi guys, I'm new to the forum. Found some very useful info. I just took my cluster out to see how many pins the outside temp display had and to change a bulb. After putting the cluster back, I turned on the car to check and see if all the bulbs worked and the cluster started to smoke. I turned off the car and pulled the cluster out again and found the wire going to the SRS bulb melted. I haven't tried turning it on again, afraid something may catch fire. Please help any info would be greatly appreciated. Thanks
86SEL560 is offline
post #2 of 7 (permalink) Old 11-30-2009, 09:38 PM
CH4S Artist
Teutone's Avatar
Date registered: Sep 2004
Vehicle: 1985 500SEC, 1991 190E 2.6.
Quoted: 1799 Post(s)
Welcome to the forum.
The electrical diagram pdf is too large to be attached here.
If you need the file, PM me with email address, and i'll attach.
The forum archive has a wealth of information available at your finger tips.
The search function accepts 2 words of at least 3 letters.
For all available resources / forum features / 'how to' navigate the forum etc, please make sure to carefully read the 'Welcome to the Forum' announcement / tutorial sticky on top of the W126 page.
Cheers
Teutone is offline
post #3 of 7 (permalink) Old 11-30-2009, 10:02 PM
CH4S Artist
Teutone's Avatar
Check your email. The electric diagram pdf is a 252KB whopper.
Cheers
Teutone is offline
post #4 of 7 (permalink) Old 11-30-2009, 10:07 PM Thread Starter
86SEL560's Avatar
got the email thanks
86SEL560 is offline
post #5 of 7 (permalink) Old 11-30-2009, 10:29 PM Thread Starter
86SEL560's Avatar
I found this diagram on w126shop.com I circled what melted. I'm not too good at reading wiring diagrams and don't really know what to do next after looking at the diagram.
86SEL560 is offline
post #6 of 7 (permalink) Old 12-01-2009, 12:06 AM
mclare's Avatar
Date registered: Aug 2008
Vehicle: 2012 CL550 4MATIC Coupe
Quoted: 307 Post(s)
Send a message via Yahoo to mclare Send a message via Skype™ to mclare
what probably happened is that when you took out the cluster, the D-key on the 15 pin plug broke as they get brittle. When you replaced it, you skewed the pins and smoke checked it. This happened to me while rebuilding Mapearsos cluster. Bad news is the cluster is toast. Good news is that I have 5 replacement 560 clusters and can transplant your odo.
I am away in Phoenix for two days rescuing a SEC but will be back Wed. PM me if you need my help.
M
Current Stable:
2012 CL550 C4 4MATIC Coupe
Past cars:
1991-560 SEC AMG - Coupe - 199/261 - 300 HP Custom Built Motor - Highly Modified Coupe.
1990-560 SEL - Sedan - 199/261 - Stock. Euro Headlamps & Wipers
1987 560 SEC Black/Tan
1988 420 SEL Champagne/Brown
mclare is offline
post #7 of 7 (permalink) Old 12-01-2009, 06:07 AM Thread Starter
86SEL560's Avatar
I think the clusters ok here's two pics of what melted. I wrapped the wire with electric tape to cover all the melted insulation. I think when I pushed the cluster back in place the SRS indicator wire got pinched and shorted out, but this morning when I wrapped it up and checked to see if it still works the bulb lit up, so I have no idea what happened. Hopefully no more smoke comes out from anywhere we all know its a pain to get it back in once it comes out .
Thanks for the help guys. I'll keep you updated if anything goes wrong.
ID:	276233   Click image for larger version
86SEL560 is offline
for sale, 89 560sel, and 86 560sel for parts seppi For Sale/Wanted/Trade/Giveaway 8 04-17-2009 05:15 PM
Smoke Smoke Smoke....2003 ML 350 sloffie W163 M-Class 8 04-07-2009 08:51 PM
DEAR GOD! blue smoke from a 560SEL after prolonged downhill runningl shrimpton W126 S,SE,SEC,SEL,SD,SDL Class 20 04-04-2009 09:51 PM
560SEL - Slight Smoke sklas W126 S,SE,SEC,SEL,SD,SDL Class 11 02-13-2008 09:09 PM
Smoke or not to Smoke that is the question DEATHERAGE R170 SLK-Class 29 03-15-2005 04:39 PM
