Seatbelt presenter electrical wiring diagram - Mercedes-Benz Forum
post #1 of 12 (permalink) Old 07-11-2009, 09:01 PM Thread Starter
Date registered: Aug 2008
It doesn't really bug me, but my presenters never worked. I did a bit of research and it seems to me that the usual culprit is the mechanical device. I wonder if it is possible that somehow someone disconnected mine, since there is no whirring coming out of the seatbelt at all (there is no struggle or gears slipping)?
I got the wiring diagrams from the russian website diakom.ru, but I can't find anything in there about the presenters. I hope to troubleshoot as much as possible before opening the sides of the car.
Would anyone care to share a pdf or two? Thanks...
Ivo Nedev is offline
post #2 of 12 (permalink) Old 07-12-2009, 05:13 AM
MBL87560SEC's Avatar
Date registered: Jul 2004
Vehicle: 1991 500SEC sub 50K mi. 1987 560SEC Now 150K mi. 2018
Quoted: 396 Post(s)
Hi there,
Here they are off the MB CDs.
Cheers, MBL
ID:	248537   Click image for larger version
MBL87560SEC is offline
post #3 of 12 (permalink) Old 07-12-2009, 05:56 AM
mramay's Avatar
Date registered: Feb 2005
Vehicle: Two '87 570SECs, one '87 560SEL
Quoted: 246 Post(s)
There seem to be just a couple of common failures on the presenters.
Fuses
bad contacts (dirty) on the seat belt buckle receiver on the side of the seat
bad nylon gear in the presenter mechanism
buckle/unbuckle a couple of dozen times
The only way to really know the state of the nylon gear is to remove the side panels to look at it, but it's the most common failure.
Blasphemous Mike
US '87 560SEC with Euro headlights, clear markers, H&Rs, 17x8.5/Nitto's, ATE slotted rotors with ceramic pads, BergWerks FGS, 3.07 Limited Slip. '87 560SEL with Euro Headlights, lowered, 235/40/17's
mramay is offline
post #4 of 12 (permalink) Old 07-12-2009, 06:45 AM
granit560's Avatar
Date registered: Dec 2007
Vehicle: 1987 560 sec impala metalflake over cream
Quoted: 11 Post(s)
As you said they arn't bothering you, but yes it would be nice if everything worked. mine work, but to me they are a pita. often iv thought of disconnecting them!
granit560 is offline
post #5 of 12 (permalink) Old 07-12-2009, 06:57 AM
mramay's Avatar
Quoted: 246 Post(s)
My wife and I agree that they're one of the cooler things in the car. I love seeing the expression on noobs when the seatbelt is given to them, then I explain that this is a 22 year old car with automatic climate control, self-leveling suspension, and headlight wipers - doesn't their new Toyota/Ford/Chevy do that?? :-)
Blasphemous Mike
mramay is offline
post #6 of 12 (permalink) Old 07-12-2009, 07:30 AM
granit560's Avatar
Quoted: 11 Post(s)
I get the same reaction; but say when i shut the door & forget my smokes then open it again & try to reach in i got this thing in my way, plus passenger side also goes,(maybe it shouldn't). then i have the problem of sitting in car just to start it once a week & iv got this thing in my way, so i hook both of them so i can have car running & not be bothered by this when im in & out listening to things. But i guess no more annoying than the Bing, Bing, Bing. when your keys are in ignition & door open. Bottom line, mramay is right it's good to have all parts on these cars in working order. plus it is a cool feature.
post #7 of 12 (permalink) Old 07-12-2009, 09:04 AM Thread Starter
Thanks, guys! So, I looked at the diagrams and I don't see what would someone unplug in order to disable the extenders. I did the reset with fuse 15, but nothing changed.
Does anyone know where the control units are located within the car?
What is the easiest way to disable the extenders (so that I can reverse it)?
post #8 of 12 (permalink) Old 07-13-2009, 01:40 PM
Taylor422's Avatar
Date registered: Apr 2009
Vehicle: 1990 560 SEL
Quoted: 9 Post(s)
I can't say I've ever noticed this feature in my or my dad's car. Does the car reel out the seatbelt and make it easier to grab?
Taylor422 is offline
post #9 of 12 (permalink) Old 07-13-2009, 02:03 PM
Chadahar's Avatar
Date registered: Apr 2008
Vehicle: '82 Euro 500SEL, '85 Euro 500SEC AMG WB Cabriolet,'86 Euro 500SEC RUF
Quoted: 369 Post(s)
Presenters are just in Coupes. The presenter is an arm that holds the seatbelt and buckle clip and when the door is shut and someone in the seat..or not(if the door is opened then it'll present). It moves forward with the belt and clip. In the SEC's, CD's and CE's (Coupes).
Do a search in this forum for Seat belt presenter and there are several posts. One is a DIY by Axel in Florida that is a great help. I'll be doing my Driver's side again and adjusting the switches per Axel's DIY ,maybe tomorrow.
If you have the CD's the index will show you the number and it's pretty straight forward. Remove the rear seat on the side you are working on, then remove the grab handle and window switch(pull the panel insert off to unfasten the switch as mine didn't come apart at the switch.) Then remove the panel and the presenter assy is right there.
"I know you think you understand what you thought you heard me say, but what you thought you heard me say is not necessarily what I meant!"
Chadahar is offline
post #10 of 12 (permalink) Old 07-13-2009, 03:52 PM
Taylor422's Avatar
Quoted: 9 Post(s)
Gotcha. My only experience is with the SELs.
Electrical question(Possible wiring diagram needed) twitch_de R170 SLK-Class 4 06-12-2009 10:51 AM
Electrical wiring diagram Perostbo W163 M-Class 0 05-22-2007 04:04 AM
Electrical wiring diagram (more) Les K (UK) R170 SLK-Class 5 11-27-2006 01:07 PM
Electrical Wiring Diagram- Airconditioning circuit premos W124 E,CE,D,TD Class 0 02-20-2006 12:47 AM
Electrical (or at least Radio) Wiring Diagram yawstring R170 SLK-Class 1 07-03-2003 01:22 AM
