Seatbelt presenter electrical wiring diagram - Page 2 - Mercedes-Benz Forum
post #11 of 12 (permalink) Old 12-01-2009, 03:41 AM
Indyz12's Avatar
Date registered: Jul 2009
Vehicle: 1989 300CE Blue-Black (M103-C124), 1993 500 SEL (M119-V140), 1985 500 SEC (M117-C126)
Send a message via Skype™ to Indyz12
Hi Guys.
I know this is an older topic but wondering if you could help.
I recently changed my seatbelt presenter from the early type (1989 CE) to the newer type (Post 1992).
The fixings are the same, however the wiring is different.
All wires match up (colour coded) apart from 1 solid brown wire that comes from the car's loom. The original wiring has 2 solid brow wires, where the new presenter has only 1 solid brown wire. One brown wire from the car is thicker than the other. Should i connect these together onto the presenter's wiring?
I look forward to your help!
Indyz12 is offline
post #12 of 12 (permalink) Old 12-01-2009, 05:34 AM
Aspect's Avatar
Date registered: Jun 2004
Vehicle: w126
Quoted: 46 Post(s)
The solid brown colored wires are earth/grounds.
Aspect is offline
Electrical question(Possible wiring diagram needed) twitch_de R170 SLK-Class 4 06-12-2009 10:51 AM
Electrical wiring diagram Perostbo W163 M-Class 0 05-22-2007 04:04 AM
Electrical wiring diagram (more) Les K (UK) R170 SLK-Class 5 11-27-2006 01:07 PM
Electrical Wiring Diagram- Airconditioning circuit premos W124 E,CE,D,TD Class 0 02-20-2006 12:47 AM
Electrical (or at least Radio) Wiring Diagram yawstring R170 SLK-Class 1 07-03-2003 01:22 AM
