SLS High Pressure Hard Line - Mercedes-Benz Forum
post #1 of 22 (permalink) Old 10-06-2008, 07:35 AM Thread Starter
BigD560's Avatar
Date registered: Feb 2008
Vehicle: 1990 Mercedes 560SEL
So my high pressure hose on my SLS has been leaking steadily since I've owned my car. Now it's at a point where it just hemorrhages hydraulic fluid all over the bottom of the motor and exhaust.
So I purchased a new SLS hose and got underneath to make the repair, but I ran into a problem when I got to the back of the hose at the hardline.
I rounded off the nut for the hardline behind the high pressure hose; This particular line is long as hell and looks expensive.
I plan on cutting the end of the line off, locating a new 12MM fitting, and flaring it on to the existing line.
Does anyone have any experience with this or perhaps a parts car with this line intact? Does anyone have any idea where I can get the 12MM flared fitting? I have yet to find the piece I need at any parts stores.
We're adding a little something to this month's sales contest. As you all know, first prize is a Cadillac Eldorado. Anybody want to see second prize?
Second prize is a set of steak knives.
Third prize is you're fired.
BigD560 is offline
post #2 of 22 (permalink) Old 10-06-2008, 08:34 AM
mramay's Avatar
Date registered: Feb 2005
Vehicle: Two '87 570SECs, one '87 560SEL
Quoted: 259 Post(s)
Markus is in the middle of this same problem. He'll chime in shortly with an answer.
Vise Grips didn't work??
Blasphemous Mike
US '87 560SEC with Euro headlights, clear markers, H&Rs, 17x8.5/Nitto's, ATE slotted rotors with ceramic pads, BergWerks FGS, 3.07 Limited Slip. '87 560SEL with Euro Headlights, lowered, 235/40/17's
mramay is offline
post #3 of 22 (permalink) Old 10-06-2008, 08:51 AM Thread Starter
BigD560's Avatar
Well, the wrench started walking on one side, so I tried another, and it rounded that side too.
Vice grips just couldn't get enough of a hold on it after it rounded. That thing is in there TIGHT.
I'll see what I can find out too. I honestly think the most cost/time effective method would be to flare on a new fitting. The line is paired up with a low pressure line in rubber isolators down the length of the frame. It would take forever to remove the things, and also subject myself to potentially stripping more fittings.
I'm going to call MB and see if they sell the fitting without the line; that will make this alot easier. Then I can just do the inverted flare with my flair tool. Hopefully it'll provide enough seal.
Marcus, let me know what you end up doing.
BigD560 is offline
post #4 of 22 (permalink) Old 10-06-2008, 08:57 AM Thread Starter
BigD560's Avatar
I just got off the phone with MB and the line itself is only $40.
Plus, the isolators are clamshell style anyway, so removing the line shouldn't be too difficult.
I'd still like to hear an alternative if there is one though....
BigD560 is offline
post #5 of 22 (permalink) Old 10-06-2008, 02:07 PM
markusfmeyer's Avatar
Date registered: Nov 2005
Vehicle: too many
I hope it isn't the same line I had trouble with. I hope its the line that crosses over the engine to another connector on the passenger side. If its the one from the passenger side to the rear of the car, there are actually 2. And good luck getting them out and back in, which is where I'm at. I just need to make time to get to the place that can cut and flare them for me as there is no way without dismantling half the car that I'll get the new lines from my donor car back on there again without doing the cut-n-splice.
I learned when rounding off brake line nuts to go buy a set of flare nut wrenches. Of course, if someone rounded them off before you...your SOL!
markusfmeyer is offline
post #6 of 22 (permalink) Old 10-06-2008, 02:40 PM Thread Starter
BigD560's Avatar
Markus this is exactly the line we're talking about.
I'm not too scared by it, I just know that if one side stripped, the other probably will too. It's not terribly expensive from MB, $40, and the rubber isolators that holds it too the frame are clamshell style, so the line can be pulled from the low pressure line without having to remove them both.
I thought about going the cut and flare route, but a double flaring kit at $20, finding the correct fitting (12mmx .125 IIRC, has proven to be a real bitch....I spent all weekend searching) at $5 or $6, and the time and effort without the guarantee of a proper seal have me thinking that I'll just buy a new line.
Why wouldn't you use the line off a donor car? Have you attempted to remove the existing line or are you simply speculating as to the difficulty of the job?
I want to dive in, but I don't want any surprises.
BigD560 is offline
post #7 of 22 (permalink) Old 10-06-2008, 03:22 PM
Vehicle: too many
I took the line off the donor car. Its a BITCH to get out. Have you been under the car to see what you are in for? Those lines run down the pass side, around/under the suspension, and twist/turn around to the self leveling valve. I got them off my parts car without too much trouble because the engine/trans/diff and most of the other big stuff is already gone. But no way I am dropping all that stuff off my SEC just to put it back in. The hard part is snaking the twists/turns around the suspension/rear subframe. That's why I'm having mine cut/spliced to make reinstall easier. Its not the part thats the challenge, its getting it back in there. Believe me, when it happened and I called Jono, he sighed and said "oh boy"....and he's a fulltime mechanic!
post #8 of 22 (permalink) Old 10-06-2008, 08:11 PM
jhodg5ck's Avatar
Date registered: Sep 2002
Vehicle: Depends on the day!
Quoted: 24 Post(s)
Send a message via AIM to jhodg5ck
I hope it flares easier then the fuel line! I had Snap-On's best hand flaring kit and there was No Way in hell that thing was going to flare the fuel line correctly.. ended up finding a guy w/ a hydraulic double end flare machine to get it right.
And Marcus is right, running these lines is a royal PITA...
Jonathan
Enthusiast Service, Restoration & Tuning.
87 Hammer Wagon 6.0L 32V
87 Hammer 6.0L 32V
87 Hammer Coupe 6.0L 32V
86 560SEL AMG 6.0 32V
etc....
Mercedes Repair Atlanta
jhodg5ck is offline
post #9 of 22 (permalink) Old 10-07-2008, 07:19 AM Thread Starter
BigD560's Avatar
Well it sounds like the job's going to be a rough ride no matter which route I decide to take....
Flaring it requires removing the line, because according to Jono, I won't be able to achieve the proper flare with a $20 dbl flare kit with the line in the car, and replacing the whole line itself obviously requires removing it as well.
Jono, what if I find the fitting already flared on a small length of hard line, find another slightly larger diameter length of hardline, cut off the rounded off fitting, sleeve the two together, and TIG weld them?
Obviously kind of a rig, but I did that on a Jeep before and it held up great....maybe I can do it for this application.
BigD560 is offline
post #10 of 22 (permalink) Old 10-07-2008, 08:24 AM
Vehicle: too many
Assuming the weld can stand up to the PSI that hydraulic line is putting out (if its the supply line versus the return line that is). When I rigged the donor car lines up to my car to "test" that the hydraulic valve I had swapped out was working, I saw quite a big of flexing and movement as I moved the lever up and down. So there is quite some pressure in there, whatever it is.
SLS line diameter advice, please isobars W126 S,SE,SEC,SEL,SD,SDL Class 6 02-27-2007 10:36 AM
What can you guys tell me about a high pressure line from the compressor to the CTbenzlvr W124 E,CE,D,TD Class 4 08-16-2006 09:57 AM
SLS return line(s) Clatterpastor W126 S,SE,SEC,SEL,SD,SDL Class 2 12-02-2005 03:56 AM
SLS pressure/ return line repair esde W123 E,CE,D,CD,TD,TE Class 5 08-21-2005 02:09 AM
Just got back from the steelership with hard line costs.... BF_JC230 W123 E,CE,D,CD,TD,TE Class 3 02-16-2004 09:44 PM
