P/S Pump Adjusting nut problem - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 07-12-2008, 12:59 PM Thread Starter
Date registered: Oct 2007
Vehicle: 2000 500SL/1984 300SD
When changing my V-belts, I noticed that the nut that the power steering pump adjusting bolt screws into is all chewed up and doesn't work. It looks like it's hard plastic and is supposed to be somewhat egg shaped so it sticks into an orifice on the back of the P/S pump and moves it as you loosen or tighten the adjusting bolt. Does anyone know where to find a miscellaneous nut like this or how to look up the part number?
Any help is appreciated.
JeffreyD is offline
post #2 of 5 (permalink) Old 07-12-2008, 09:46 PM
CH4S Artist
Teutone's Avatar
Date registered: Sep 2004
Vehicle: 1985 500SEC, 1991 190E 2.6.
Quoted: 1845 Post(s)
Have you tried a forum search (minimum of 3 words with more than 3 letters ea.)?
https://www.benzworld.org/forums/w126...ease-read.html
Which files do you need?
46 Steering System
Checking of steering
* 46-050 - Technical data
* 46-110 - Checking steering play
* 46-130 - Checking power steering pump oil pressure
* 46-140 - Replacing steering following accident
* 46-220 - Reconditioning steering gear
Power steering
* 46-412 - Remove and replace steering gear
* 46-480 - Readjustment of steering gear in vehicle
Steering linkage, steering arms
* 46-512 - Remove and replace pitman arm and lower housing cover seal
* 46-520 - Check idler arm play, remove and replace idler arm bushing
* 46-540 - Remove and replace tie rod ends
* 46-550 - Remove and replace center link
* 46-560 - Remove and replace center link and tie rod end boots
Steering wheel, steering column, steering shaft, steering lock
* 46-610 - Remove and replace steering wheel
* 46-612 - Remove and replace steering wheel slip ring
* 46-620 - Remove and replace steering column
* 46-625 - Steering column disassembly/assembly
o Select page...
* 46-640 - Remove and replace steering wheel lock
Power steering pump
* 46-700 - Power steering pump identification
* 46-705 - Remove and replace power steering pump seal
* 46-710 - Remove and replace power steering pump
* 46-715 - Filling and bleeding power steering pump
* 46-720 - Disassembly/assembly power steering pump
Teutone is offline
post #3 of 5 (permalink) Old 07-13-2008, 07:29 AM
CH4S Artist
Teutone's Avatar
Its in the archive as well:
Cheers
File Type: pdf 46-710 rem & install power steer. pump.pdf (266.2 KB, 82 views)
Teutone is offline
post #4 of 5 (permalink) Old 07-15-2008, 12:16 PM Thread Starter
Kent at MercedesSource.com was able to find a few used nuts. Here is a picture of it, it's a square plastic nut with "nubs" sticking off the side that go into an orifice on the back of the P/S pump. It's not very hard plastic so they eventually get mangled or shear off and the tensioner bolt just spins and spins. Bad design on this one I think.
JeffreyD is offline
post #5 of 5 (permalink) Old 07-15-2008, 12:37 PM
CH4S Artist
Teutone's Avatar
We have a few van's with the same function nut in metal. The threads still go bad.
Teutone is offline
Restoring function to your closing assist pump. Adjusting the pressure shut-off. Long w/pics. Brett San Diego W140 S-Class 46 01-17-2019 03:29 PM
lug nut problem j3s5e W124 E,CE,D,TD Class 10 07-30-2008 03:09 AM
adjusting throttle cable, acceleration problem veryslowbenz R/C107 SL/SLC Class 10 02-02-2007 03:56 AM
problem locating the 19mm nut to loosen the tensioner belt autosleek W124 E,CE,D,TD Class 4 01-23-2007 05:11 PM
lug nut problem with 1998 E320 247hoopsfan W210 E-Class 2 01-06-2005 07:04 PM
