electrical problem with 87 300SDL - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 01-17-2007, 06:31 PM Thread Starter
Date registered: Sep 2006
Have shorted circuit on fuse 15. This is one that has antenna, dome lights, and courtsey lights. Thought problem was with alarm system. Unplugged module with no change. Only clues to this mistery is the seatbelt warning light flashes continualy when power is on. Have found light flashing with power off and doors closed. The switch for the maplight/courtesylight doesn't work correctly. In one position the light comes on. Another it is off. in still another the passenger side light comes on. Have also unplugged antenna motor thinking there maybe a short there. No change. Have manual on CD. There is a antithief module in the circuit that that appears to effect the circuit. Have no idea where it is located or how to test. Any suggestions?
Wired_Bob is offline
post #2 of 5 (permalink) Old 09-03-2018, 07:59 AM
Premium Member
Date registered: Oct 2009
Vehicle: 1987 sdl, 1989 420 sel, 2013 S 550, 1999 SL 500
Quoted: 13 Post(s)
Premium Member
I had a thread somewhere about my 300 SDL lacking wipers, seats and windows. The excellent local independent tech says it is not fuses. I had to use the car, but it will be gong back.
Does anyone know exactly which relay might cause these losses?
Should I start a new thread? How do I find my old one?
Thanks,
JK
kilboj is offline
post #3 of 5 (permalink) Old 09-04-2018, 01:24 PM
mclare's Avatar
Date registered: Aug 2008
Vehicle: 2012 CL550 4MATIC Coupe
Quoted: 311 Post(s)
Send a message via Yahoo to mclare Send a message via Skype™ to mclare
Thanks,
JK
@killboj - Start a new thread and tag me into it.
Do you have the ETM (Electrical Troubleshooting Manual) You really need it to do any type of electrical T/S! It's like trying to drive to NY from LA with no maps or GPS.. You may get there, but it will take forever. I can teach you how to navigate your electrical system if you are at all adept at electrical.
Current Stable:
2012 CL550 C4 4MATIC Coupe
Past cars:
1991-560 SEC AMG - Coupe - 199/261 - 300 HP Custom Built Motor - Highly Modified Coupe.
1990-560 SEL - Sedan - 199/261 - Stock. Euro Headlamps & Wipers
1987 560 SEC Black/Tan
1988 420 SEL Champagne/Brown
mclare is offline
post #4 of 5 (permalink) Old 09-09-2018, 11:14 PM
redghost's Avatar
Date registered: Oct 2012
Vehicle: 1972 220 D, 1974 450SL, 1995 E300D 2002 S430, 1976 300D, 1986 SDL, 1982 SD
Quoted: 446 Post(s)
Bob, the anti theft device lives under the passenger side foot rest. Pull the carpet, unscrew the plastic cover and you are looking for this critter.
Clay
74 450SL - Froggy
'86 300SDL - Polei
'82 300SD - Allen
Retired cars
'02 s430 - Victor
'76 300D - Voldemort
'95 E300D - Cleo
'72 220D - Gump
'87 300SDL - POS SDL
92 300SE - #1 boys ride
redghost is offline
post #5 of 5 (permalink) Old 09-10-2018, 03:38 AM
Premium Member
Quoted: 13 Post(s)
Premium Member
as to the SDL, here is what I THINK happened: the fuse box has some sort of aftermarket extra cable from the battery to it. Must have been an old fix. Fuses were fine. The battery was showing a little corrosion in the tray area, so I had it removed, cleaned and coated. I SUSPECT that when that was done, the add-on cable was disconnected and reconnected to the terminal clamp. I think it was connected but had stopped passing current. Everything works fine now. Lesson learned: just because a connection looks tight doesn't mean it is working..
kilboj is offline
A/C Electrical Problem Teutonic R/C107 SL/SLC Class 5 03-25-2006 02:46 AM
electrical problem please help anoc320 W203 C-Class 1 03-24-2005 09:11 AM
1987 300sdl Starting Problem mailport25 W126 S,SE,SEC,SEL,SD,SDL Class 1 05-28-2004 01:51 PM
1986 300SDL stall problem - help!!! dingo W126 S,SE,SEC,SEL,SD,SDL Class 1 12-30-2003 04:55 PM
86 300sdl AC Problem Guest (MBNZ) W126 S,SE,SEC,SEL,SD,SDL Class 4 08-12-2001 01:50 PM
