Emergency!!!!! complete transmission fluid leak, car just serviced at MB dealer - Mercedes-Benz Forum
post #1 of 33 (permalink) Old 12-24-2006, 02:11 PM Thread Starter
Dovebar's Avatar
Date registered: Sep 2006
Vehicle: 1990 560 SEL
I think I just dumped all my transmission fluid. and I just had the transmission fluid changed (3 weeks ago) at the dealer as part of a 30K mile service. Car has 29K miles on it. How can I check to see if the dealer messed up? Can I check the pan? Location?
transmission fluid dipstick is BONE dry. fluid dripped heavily from front of engine and sprayed, car will not engage in reverse. drove it 2 miles after incident to get off highway and home.
Dovebar is offline
post #2 of 33 (permalink) Old 12-24-2006, 02:26 PM
MBeige's Avatar
Date registered: Jan 2004
Vehicle: W-1-2-3 Go!
Quoted: 213 Post(s)
Sounds like the transmission cooler lines have leaked. I hope the transmission is still good.
MBeige is offline
post #3 of 33 (permalink) Old 12-24-2006, 02:30 PM
Premium Member
Dr.Grillz's Avatar
Vehicle: Mercedes
Quoted: 277 Post(s)
Since you've had the car serviced at the dealership, call the Mercedes roadside service and have them tow it back to see what the issue is.
1980 Mercedes 280TE AMG
1990 Mercedes 560SEL with AMG parts modifications
1991 Mercedes 190E AMG with Brabus 4-cyl M102 2.6
Dr.Grillz is offline
post #4 of 33 (permalink) Old 12-24-2006, 02:34 PM Thread Starter
Dovebar's Avatar
Did some research I think you're right a. What to look for for a trans oil cooler leak? There was some smoke. I might have destroyed the transmission.
Dovebar is offline
post #5 of 33 (permalink) Old 12-24-2006, 02:39 PM Thread Starter
Dovebar's Avatar
In changing transmission fluid, anything dealer could do to accidently foul oil cooler (filter)? Any recommendations for a good DC/Northern VA independent to take a look? (and tow) this car is going nowhere.
Dovebar is offline
post #6 of 33 (permalink) Old 12-24-2006, 02:51 PM
Premium Member
Dr.Grillz's Avatar
Vehicle: Mercedes
Quoted: 277 Post(s)
Reason I recommended the Mercedes Roadside Assistance call is that they provide free towing to the dealership. Since you had the work just done there and you think that they may have done something wrong, its best to point it out to them to make things right again. After all, you just paid to have it serviced RIGHT. If they screw up, its their job to fix it.
post #7 of 33 (permalink) Old 12-24-2006, 03:03 PM
Date registered: Nov 2004
Vehicle: '91 560SEC
make sure they tightened the trans drain plug down, if the plug isn't there, its safe to say they forgot to tighten it down and you should get a free transmission at there expense
benz420 is offline
post #8 of 33 (permalink) Old 12-24-2006, 03:06 PM
jdc1244's Avatar
Date registered: Jun 2003
Vehicle: 1991 300 SE
Quoted: 2 Post(s)
You drove it home two miles after loosing ATF and there’s smoke…
Well, that may have compromised anything the dealer may have done wrong – you should have stopped the car immediately.
With an ATF cooler line leak you see lots of ATF in the front drivers part of the engine bay and ATF dripping from the blown line. I don’t think the dealer did anything wrong, an ATF and filter change is unrelated to a blown cooler line.
jdc1244 is offline
post #9 of 33 (permalink) Old 12-24-2006, 03:30 PM Thread Starter
Dovebar's Avatar
Completely agree. Should not have driven. Was really close and its Christmas Eve. And get this. My car is freshly detailed looks amazing. My brother and I were there with the hood up, and some lady drives by in a CRV and is clapping and laughing at us. Nice. Merry Christmas.
But interesting: I called roadside assistance and they said they do not provide free towing because car is out of warranty. I'm screwed. Transmission rebuild/new expense? 1K? 2?
Dovebar is offline
post #10 of 33 (permalink) Old 12-24-2006, 03:36 PM
marlinspike's Avatar
Date registered: Feb 2005
Vehicle: 1985 380SE
That's bullshit. Both the ladies attitude and what they told you about the towing. Roadside assistance towing to a dealer is free for life. I would also tell them that a dealer just serviced the transmission before it did this.
http://www.mbusa.com/care/client-car...-assistance.do
Life of the vehicle, no matter how old or how many ownders.
marlinspike is offline
transmission fluid leak when car is running tridor777 W140 S-Class 2 02-12-2006 07:29 AM
...Leak - Transmission Fluid!!! KHULE-1 W124 E,CE,D,TD Class 5 07-03-2005 07:02 PM
transmission fluid leak CI300CE W124 E,CE,D,TD Class 2 05-03-2003 06:34 PM
Transmission fluid leak Benzola SD W126 S,SE,SEC,SEL,SD,SDL Class 1 11-26-2002 10:18 AM
Transmission fluid leak Ted G-Class 3 02-16-2001 05:46 AM
