Hi all,
As the title states, my E420 is not in good shape.
After some hard driving, the car started producing large amounts of white smoke from the exhaust and losing coolant at a rapid rate. Things seemed ok from a compression test, leak down test, and block test. My friend who is a mechanic recommended replacing the intake manifold gasket as there are opportunities for coolant to leak into the intake through that gasket.
I performed that job, (the gasket was indeed compromised), and got everything machined before putting it back together. However, still white smoke.
Fast forward to now, the car has sat for a month or two and I decided to get it properly diagnosed at a local mercedes mechanic. After about 4 hours with the car he called me and let me know that they had found cylinder 4 half full of coolant and that he believed the engine has a cracked head, or at least a severely blown head gasket.
The quote for the head gaskets was around $4,000. If he did indeed need to source a new head, he said it could exceed $5,000.
While I don't doubt the cost for his time, I do wonder if it's even worth fixing that engine, or more worth it to source a used engine and have him swap it in, which he said could be done for around $2000.
I do have some questions about this though, unfortunately I don't know the exact model M119 the car has currently, but I do know that it is the distributed variant with the plastic oiler tubes.
- Does the engine I source have to be the exact same variant of the M119?
- Would it be possible to put a later variant with coil-over ignition into the car? (I always hated the distributors)
- Lastly, 5.0L variants seem to be much more plentiful near me, are there any inherent problems with putting a 5.0 in the car other than having to swap the computers?
Sorry if this isn't enough information, a little lost here and don't want to scrap the car, but I also don't see a lot of sense in putting over $5000 into a 25 year old car that might sell for less than that.
Any help is greatly appreciated.
