Looking at a '94 E420 with Bad Trans - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 05-22-2019, 11:23 AM Thread Starter
Date registered: Aug 2018
Vehicle: 1987 300D Turbo
Quoted: 23 Post(s)
Just looked at another V8 W124 that was cheap, but of course also in rough shape. This one doesn't currently move forward or backward at all. The seller says that when he bought the car it would drive, but slowly, like maybe just in 1-2 gear? Anyway, no it won't move at all, but starts right up and runs pretty good. It has 141k miles (verified with CarFax), very basic model, no ASR or heated seats, seems to have had very few factory options. It has rust (like every W124 in my area (Michigan, USA) and needs at a minimum transmission work or replacement. The seller has a used transmission (from a salvage yard) that supposedly works, but is not warranted either.
The upper engine harness is circa 2016 (I think), the distributor caps look new, wires also look newer, the screen on the MAF has a tear, I couldn't tell whether the ETA and lower engine harness had been replaced.
It might have newer shocks/struts, interior isn't great, but all but the driver's seat are restorable, the tires and wheels are decent.
The rust is concerning, but looks repairable (with some cutting and welding), it will need one replacement fender and the rust on the driver's door may warrant its replacement too.
Are the E420 transmissions prone to failure at this type of mileage or is it possible the existing transmission might be repairable? It just revs when put into gear, but you can feel the engine getting loaded (I think) but it does move at all.
The seller is asking $700 with a clean title and the spare used transmission included.
Smoky300D is offline
post #2 of 3 (permalink) Old 05-22-2019, 11:58 AM Thread Starter
Quoted: 23 Post(s)
post #3 of 3 (permalink) Old 05-29-2019, 04:13 PM
gsxr's Avatar
Vehicle: Buncha W124's
Quoted: 117 Post(s)
Any 124 you need to cut & weld... is a parts car. The only way this is worth it is if you have a ton of free time, no spare $$, the car is practically free, AND you have the skills to patch it up with rust-free sheet metal from a donor car.
The E420 uses the same 722.3 transmission as found in the 500E and also W140/R129 with M119 engine. They are robust transmissions, IF they are serviced on time. That's usually what kills them, nobody changes the ATF + filter on schedule every 30kmi. Properly maintained, they can go 200-300kmi easily before a rebuild, although they often need an external re-seal every 100-150k. Strange that you've come across two 124.034's that both have shot trannies.
Dave M.
Boise, ID
1997 E420 - 159kmi (
1994 E420 - 150mi (
1994 E500 - 115kmi (
1992 500E - 179kmi (
gsxr is offline
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W124 E,CE,D,TD Class > W124 V8 400E / E420 / 500E / E500 / E60
