1995 E420 - deja vu chug chug chug... - Page 2 - Mercedes-Benz Forum
post #11 of 17 (permalink) Old 08-10-2019, 08:43 PM
magicbigdaddy's Avatar
Date registered: Dec 2006
Vehicle: 1989 560 SEC - V-8 Kompressor - 95 E320 Estate
Quoted: 334 Post(s)
Originally Posted by tuttebenne View Post
Maybe you don't have a lot of M119 experience? Dust shields are a huge issue these days on M119s. You can get away with it on an M103 or some others but not on a 20+ year old M119.
My experience with m119 ranges from w124, R129 and w140. This along with my local indie that worked for MB dealership in Seattle area when these cars were new is what I have experienced. Again an ultra low mileage m119 the chances that the insulators would be more suspect than a original eco junk wiring harness would not be the recommended next step to cure this issue. If all the insulator dust shields failed at 30-40k miles I think this issue would have been brought up many years ago. The OP has spent way too much money repeating the same chaotic advise from techs that do not know m119. If the wiring harness is fresh and the issue still occurs I would definitely change the insulators as the next step. I honestly believe if this post was on the 500e board that OP would receive this same advise. Mike
1989 560 SEC Supercharged - 317+ rwhp - H&R lowered - OZ 3 piece staggered wheels - upgraded brakes - AMG Tri-Y's - Bergwerks FGS - a true Euro Rod
1981 500SE euro AMG
1985 euro 500SEC
1986 560 SEC
1985 500SEL
1989 560SEC
1990 560SEL
1987 euro 560SEL 300hp 822 engine option
magicbigdaddy is offline
post #12 of 17 (permalink) Old 08-11-2019, 11:46 AM
tuttebenne's Avatar
Date registered: Jul 2005
Vehicle: W124
Quoted: 491 Post(s)
Granted, the build date on the harness should be verified to rule it out or in. That is just good long term insurance and maybe, just maybe, it will fix this problem.
However, the car has been to two Benz dealers and neither brought up the harness as an issue. Since its the biggest issue with a 124 of this era, I would think a Benz dealer tech would start with the harness issue and work his way down the pecking order of potential issues. Sure, the quality of a dealer tech could be a discussion point but we are talking about two dealers and at least two techs. But as you say, it should be checked just to be sure.
Having said all this, my recommendation was based on the following in the opening post (as well as the fact that the problem went away each time the caps were changed):
"Car develops a bad miss that gets progressively worse. If she is driven every day there is no noticeable problem. If I skip a day I can expect that she will start up beautifully, and drive beautifully until about 15 minutes in and at the next redlight it will begin - chug chug chug. "
Obviously we both have our opinions on what will resolve this and hopefully the OP will let us know. Conventional wisdom (here, on the 500e board, and elsewhere) indicates the description by the OP is a classic description of an insulator issue. If it were a harness issue, it would be a significant "reach" to explain how the engine ran fine, without problems, for months upon months following replacement of the caps and wires - and it did this twice.
Jayare likes this.
tuttebenne is offline
post #13 of 17 (permalink) Old 08-11-2019, 06:11 PM
Quoted: 334 Post(s)
One item we all can agree upon is to NOT buy the insulators from the dealership but from the link "tuttebenne" provided earlier in this post. I checked with the dealer a couple years ago and they quoted over $230 for each insulator.
1981 500SE euro AMG
1985 euro 500SEC
1986 560 SEC
1985 500SEL
1989 560SEC
1990 560SEL
post #14 of 17 (permalink) Old 08-13-2019, 10:14 PM
luckymike's Avatar
Date registered: Mar 2010
Vehicle: 1989 560SEC, 1989 560SEL, 1995 E420
Quoted: 581 Post(s)
I just bought a set from fcp per tuttebenne's suggestion. Sure hoping they'll help my '95 E420. Stay tuned.
luckymike is online now
post #15 of 17 (permalink) Old Yesterday, 03:11 AM Thread Starter
Date registered: Jul 2012
Vehicle: 2014 E350 4Matic Coupe
So you are having the same problem
With yours???
Dillinger is offline
post #16 of 17 (permalink) Old Yesterday, 10:01 PM
luckymike's Avatar
Quoted: 581 Post(s)
With yours???
Idle is too high. Car stumbles but is driveable. Sometimes it runs fine. Fairly new caps/rotors, rewired ETA. But as far as I know the insulators are original at almost 200,000 miles.
Codes don't seem to be too helpful. What could a neutral safety switch code have to do with poor running?
post #17 of 17 (permalink) Old Today, 03:25 AM
sbaert's Avatar
Date registered: Jun 2007
Vehicle: '95 E300 DIESEL, '91 600SEL, '92 600SEL
Quoted: 1859 Post(s)
High idle is a dead giveaway of a bad throttle body and/or module.
I have zero faith in rewired throttle bodies. They just don't hold up the long run.
And always make sure to install a new gasket whenever R&R'ing the throttle body to avoid a vacuum leak.
tuttebenne likes this.
sbaert is offline
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
