1987 300E just failed California Emissions Smog test - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 08-06-2019, 01:49 PM Thread Starter
Date registered: Mar 2011
Quoted: 6 Post(s)
Hello
I just failed the California Smog emissions test with my 1987 300E
HC and NO were high
see results below
any ideas on where to start, I just changed the plugs, wires, cap and rotor and an oil change before the test
fredzrez is online now
post #2 of 6 (permalink) Old 08-06-2019, 04:31 PM
Date registered: Dec 2012
Vehicle: 89 190E2.6- 5-speed Manual, 95 E320 Sportsline-sold, 2001 E320 4matic Wagon-sold
Quoted: 547 Post(s)
Send a message via Skype™ to dolucasi
You will need a new oxygen sensor and a catalytic converter as a start.
Those alone will bring down your values significantly (like 40% - 60% assuming the ones you have are shot, they look like it)
If it still does not pass the 15MPH but passes the 25MPH test that is because the CAT is not hot enough for the first test. Second one (25MPH) will always do better.
Find a test center that is willing to preheat the CAT before they start the testing. Basically you need to be on the rollers and do a dummy 15MPH test before they start the real testing sequence.
How much oil is this car burning?
dolucasi is online now
post #3 of 6 (permalink) Old 08-07-2019, 06:30 PM
Jetdude1010's Avatar
Date registered: Aug 2016
Vehicle: 1995 E300D
Quoted: 42 Post(s)
Isn't the car emissions exempt for the year?
In Texas cars older than 1994 are exempt along with all diesel models.
Jetdude
Jetdude1010 is offline
post #4 of 6 (permalink) Old 08-07-2019, 07:10 PM
LeftCoastGeek's Avatar
Date registered: Jul 2011
Vehicle: 1993 300CE Cabriolet (mine) ; 1994 E320 Wagon (wife's) ; 1990 Benz 300E 2.6 (son's)
Quoted: 1362 Post(s)
Jetdude
in California, its 1975
LeftCoastGeek is offline
post #5 of 6 (permalink) Old Today, 08:19 PM Thread Starter
Quoted: 6 Post(s)
Hi
Just got back from being out of town for a while.
I went through all my emission test records and made a spreasheet of results back to 2004. I actually have the results back to around 1998.
There were times when the HC was on the high side but passed.
See attached image
post #6 of 6 (permalink) Old Today, 10:06 PM
Quoted: 547 Post(s)
Will send you a PM Fredzrez. Pretty sure you will need a new O2 sensor and a Cat assuming the Cat is original and the O2 sensor has many miles on it and probably a lot of soot as well.
BTW your last test was botched. The CAT was not hot enough when the 15mph test was done. You can see how much better the 25mph turned out as the CAT warmed up. It would have failed no matter what though.
Currently Active Users Viewing This Thread: 6 (0 members and 6 guests)
