My new baby w124 300e won't start - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 07-16-2019, 10:25 AM Thread Starter
Date registered: Jul 2019
Vehicle: W124 300e 1991
Hello, I'm new here, and also new in the Benz World.
I bought my first Mercedes last week.
Very cheap one and I want to learn how to fix it.
I love fixing cars during my week-ends.
My car (W124 300e from 1991) won't start, she starts right up with Start Pilote, and also there seems to be a good fuel pressure out of the fuel regulator.
I have to turn the jetronic adjustment screw?
Thanks a lot !
(I put new gas in it)
Jérémy Mestre is offline
post #2 of 8 (permalink) Old 07-16-2019, 12:08 PM
Date registered: Jul 2007
Vehicle: 95 E300, 91 300TE, 84 190D
Quoted: 16 Post(s)
Factory Sevice Manual
Since you are new to your car, take time to explore the Sticky: 124 DIY Thread section. Many helpful write ups on how to repair these cars, and the Factory Service Manual is there online.
ds190 is offline
post #3 of 8 (permalink) Old 07-16-2019, 12:12 PM
LeftCoastGeek's Avatar
Date registered: Jul 2011
Vehicle: 1993 300CE Cabriolet (mine) ; 1994 E320 Wagon (wife's) ; 1990 Benz 300E 2.6 (son's)
Quoted: 1361 Post(s)
it takes fuel, compression, & spark to start an engine..
so, did this car run when you bought it, or did you buy a broken non-running car ?
absolutely do NOT mess with the jetronic mixture screw, thats not what would prevent it from running unless someone previously messed it way far out of whack..
LeftCoastGeek is online now
post #4 of 8 (permalink) Old 07-16-2019, 04:44 PM
Jayare's Avatar
Date registered: Jun 2005
Vehicle: 86 190E 2.3L 16V, 2 95 320TE's, 02 S500
Quoted: 1103 Post(s)
Welcome to the 124 forum Jeremy and congrats on acquiring the car.
As mentioned, don't start turning any screws...You said the car would run with starting fluid. If that's the case, you have a fuel delivery problem. Inop fuel pumps would be a good place to start your investigation. Check your fuses, in fact, get rid of all the aluminum ceramic ones and replace with copper ceramic type. Make sure you hear the pumps prime up when the key is initially turned to position 2.
Report back
Again, welcome
Jayare
Sent from my XT1710-02 using Tapatalk
Jayare is online now
post #5 of 8 (permalink) Old 07-16-2019, 05:59 PM
Real1shepherd's Avatar
Date registered: Jul 2009
Vehicle: '92 300TE 4matic 280,000miles, '92 300TE 4Matic 'Ice Blue Metalic' 101,000miles
Quoted: 498 Post(s)
Fuel filter, fuel hoses, fuel pumps.....check the pressure going into the fuel distributor. I'd check out all those first and then we can give you some more ideas.
It could be a lot of things but sounds like you have spark.
Kevin
Real1shepherd is offline
post #6 of 8 (permalink) Old 07-16-2019, 06:31 PM
they say there's nothing more expensive than a cheap mercedes....
post #7 of 8 (permalink) Old 07-20-2019, 03:48 AM
plinker17722's Avatar
Date registered: Mar 2015
Vehicle: 1989 W124 260E
Quoted: 161 Post(s)
Spot on left coast geek, and i know how it is because my car was a gift . And after 4 years i am just about finished replacing and making it as good as new . Repair one item ,and end up with more things to put right . The parts are old and plastic is brittle it snaps off with a click . You have to work on the plastic as if its about to explode .
plinker17722 is online now
post #8 of 8 (permalink) Old 07-20-2019, 10:57 AM
well, the plastic on my various 124's is in a lot better shape than the plastic in my last couple contemporaneous Volvos, so....
I do note that tan interiors seem to be much more brittle than grey or black.
