console - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 07-12-2019, 09:06 AM Thread Starter
Date registered: Jul 2019
console
New here; how is the center of the console removed on a 1990 E300 sedan? I need to get access to the power window switches. Thanks much.
Jerry B is offline
post #2 of 3 (permalink) Old 07-12-2019, 02:05 PM
Date registered: Feb 2009
Vehicle: 1995 e320ce. 1993 230 TE. 1987 Kit car with 260e running gear.
Quoted: 85 Post(s)
2 screws and lift up and pull backwards.
The 2 screws are at the bottom of the return end , narrow end.
If you have an open tray between the seats you should be able to see the 2 screws if you pull out the small piece of carpet that lines the bottom of the tray.
If you have a locking box between the seats then I am sure you will need to remove it first.
boyd waugh is offline
post #3 of 3 (permalink) Old 07-12-2019, 03:09 PM Thread Starter
Thank you very much.
JB
Jerry B is offline
