89 300e not charging - Mercedes-Benz Forum
post #1 of 22 (permalink) Old 07-11-2019, 12:14 PM Thread Starter
Realmikeyp's Avatar
Date registered: Jul 2019
Quoted: 2 Post(s)
I recently replaced my alternator after my car died however it is still not changing. The battery Is not very old and tests fine so I’m assuming it’s an electric issue. I’m not an expert so I was wondering if anyone had any insight on what could be wrong
Realmikeyp is offline
post #2 of 22 (permalink) Old 07-11-2019, 01:34 PM
LeftCoastGeek's Avatar
Date registered: Jul 2011
Vehicle: 1993 300CE Cabriolet (mine) ; 1994 E320 Wagon (wife's) ; 1990 Benz 300E 2.6 (son's)
Quoted: 1361 Post(s)
  1. first, when you turn the ignition on before starting the engine, does the ALT/BATT light on the dashboard light up? if that ligth doesn't come on, there's no D+ current, and the alternator won't work.
  2. if it does light up, now start the engine, does that ALT/BATT light go out ? if it stays on, something is wrong with the alternator.
  3. pretty much everything else requires a volt meter to test... borrow a digital multimeter if you don't have one, or get one, they are really cheap now.
  4. measure the battery voltage with the car switched off. if the battery is fully charged and has been resting an hour or so, you should see about 12.6 volts. start the car, and you should see at least 13.8 volts, if you, the battery should be charging.
  5. on the back side of the right hand spring tower, just forward of the battery, there's a 3 terminal connector block, 1 thin connector on the far right side, and a fat stud in the middle and left side (left vs right applies to the CAR, not to you as you face this from in front). ignition off, measure the voltage from that small stud to one of the ground bolts on top of the spring tower. should be 0 volts. turn ignition on without starting car, now you should read somethign around 5-9 volts at that smaller screw relative to ground. this is that same D+ circuit. there should be 2 not-very-fat wires going to that small screw, one comes from the dashboard 'battery' light, and the other goes to the D+ terminal on the actual alternator.
  6. with the car running, measure the DC voltage from the alternator body to the negative terminal of the battery, if that's more than about 0.1 volt, the alternator ground is poor.
LeftCoastGeek is offline
post #3 of 22 (permalink) Old 07-14-2019, 06:17 AM
TechGuru's Avatar
Date registered: Oct 2008
Vehicle: 1988 M-BENZ 300E | 1991 FORD PROBE GT TURBO | 2003 FORD EXPLORER 4x4
Quoted: 20 Post(s)
If you bought any alternator brand other than BOSCH you need to return it. It calls for the BOSCH AL165X but I believe the AL66X can also be used which is available at RockAuto.
TechGuru is offline
post #4 of 22 (permalink) Old 07-14-2019, 06:40 AM
Jayare's Avatar
Date registered: Jun 2005
Vehicle: 86 190E 2.3L 16V, 2 95 320TE's, 02 S500
Quoted: 1103 Post(s)
Not true.
Sent from my XT1710-02 using Tapatalk
Jayare is offline
post #5 of 22 (permalink) Old 07-14-2019, 07:07 AM
TechGuru's Avatar
Quoted: 20 Post(s)
Originally Posted by Jayare View Post
Not true.
You've always told me to only use OEM.
TechGuru is offline
post #6 of 22 (permalink) Old 07-14-2019, 07:14 AM
Jayare's Avatar
Again, not true Tech. I've told/suggested you not to use junk branded parts. Denso, Bosch etc are all top shelf. You may recall discussions of OVP relay's that sell for under $20 vs OE that go for about $60. There is a difference.
Seldom do these alternators fail. Most often, it is a voltage regulator problem.
Jayare is offline
post #7 of 22 (permalink) Old 07-14-2019, 08:52 AM
Floobydust's Avatar
Date registered: Nov 2002
Vehicle: 2003 G500, 2000 SL500, 1995 E320 Cabriolet, 1980 TR8
Quoted: 96 Post(s)
Realmikeyp -
When you say your car died, did it die while running or did it just not start one day?
If you can get a volt meter, verify that the non running voltage on the battery is on the order of about 12.6 volts. Then check to set if the voltage rises to something on the order of 13.6 to 14.2 volts after you start the car. If it does, the alternator is putting out. If it is putting out and the battery "tests" good, perhaps you have a parasitic current draw, either internal to the battery itself or through one of the external circuits in the car.
Floobydust: a contemporary term derived from the archaic Latin miscellaneous, whose disputed history probably springs from Greek origins (influenced, of course by Egyptian linguists) - meaning here "a mixed bag." - National Semiconductor Audio Handbook
Floobydust is offline
post #8 of 22 (permalink) Old 07-15-2019, 02:20 AM
plinker17722's Avatar
Date registered: Mar 2015
Vehicle: 1989 W124 260E
Quoted: 161 Post(s)
Did you check out post 2 -7 left coast geek parts no 1 and 2 ????? [ no light no charge ]
plinker17722 is online now
post #9 of 22 (permalink) Old 07-15-2019, 01:30 PM
tuttebenne's Avatar
Date registered: Jul 2005
Vehicle: W124
Quoted: 491 Post(s)
Okay, let's all pile on now (sarcasm). LeftCoastGeek covered everything this newbie needs to know at this point. Let's not confuse things with bad information.
tuttebenne is offline
post #10 of 22 (permalink) Old 07-17-2019, 12:55 AM
Anandyma's Avatar
Date registered: Nov 2017
Quoted: 2 Post(s)
in earlier i was so worry about my alternator.
i buy Bosch made in spain 90ah alternator and it works good 14.2 volt at first start. but after 2 hours ride with all electronic on, AC, head lights and everything, my ALT charging at 11.8 volt. and i try to search all of information about alternator charging. and it says the minimum voltage of alternator is 13 volt. if not, your alternator is faulty or bad. but finally i got info from professional G class mechanic, and he says 11.8 is normal and minimum is 11.2 volt.
and.... Sorry for my faulty grammar....
Anandyma is offline
