The Clock in the Instrument Panel - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 06-22-2019, 06:11 PM Thread Starter
Floobydust's Avatar
Date registered: Nov 2002
Vehicle: 2003 G500, 2000 SL500, 1995 E320 Cabriolet, 1980 TR8
Quoted: 93 Post(s)
Does anyone know if the clock in the instrument panel has a modern continuous movement or is it the old fashioned elctro-mechanical type that pulses a small solenoid/motor to wind a small mainspring?
I am asking because I am getting a periodic current pulse of about 20 mA (over the steady sate current draw of about 11 mA) every few seconds on fuse circuit 9. I've been trying to think of what it might be and the best I could come up with is that it might be the clock if it is the elctro-mechanical type. Does anyone have any thoughts as to what else it might be? Mostly just curious as all seems to be well with the car's electrical system.
Thanks!
Floobydust: a contemporary term derived from the archaic Latin miscellaneous, whose disputed history probably springs from Greek origins (influenced, of course by Egyptian linguists) - meaning here "a mixed bag." - National Semiconductor Audio Handbook
Floobydust is offline
post #2 of 8 (permalink) Old 06-23-2019, 02:36 AM
plinker17722's Avatar
Date registered: Mar 2015
Vehicle: 1989 W124 260E
Quoted: 142 Post(s)
You could pull out the nob that adjusts the clocks time, and put a scotch under the nob to stop the nob going back in this will stop it running then check you voltage drop. I know the clocks have a coil inside . And there is a way to repair them if they fail .
This is a retro ride .
plinker17722 is online now
post #3 of 8 (permalink) Old 06-25-2019, 05:48 AM
Real1shepherd's Avatar
Date registered: Jul 2009
Vehicle: '92 300TE 4matic 280,000miles, '92 300TE 4Matic 'Ice Blue Metalic' 101,000miles
Quoted: 486 Post(s)
I've wondered about this myself for yrs. It's a decent movement because they keep very good time. I've never had to adjust one for fast/slow problems.....I'm sure someone has a cluster lying around and could peek at it.
Kevin
Real1shepherd is offline
post #4 of 8 (permalink) Old 06-25-2019, 09:27 AM
Quoted: 142 Post(s)
clock
Kev go to you tube and in the search box put this - How to Repair a Mercedes W124 Electric Clock
Sorry no good at links .
Real1shepherd likes this.
post #5 of 8 (permalink) Old 06-25-2019, 03:55 PM
Date registered: Jul 2011
Vehicle: 1995 E320 wagon
Quoted: 65 Post(s)
It ticks...that probably answers your question
1995 E320 wagon <--Daily
1959 Austin Healey sprite <--Toy/project
1982 Olds Custom Cruiser LQ4 <--Dads beast/project
1974 Fiat X1/9 <--Moms toy
Im a Volvo nut with a german brick!
autocomman is offline
post #6 of 8 (permalink) Old 06-26-2019, 03:26 AM
Quoted: 142 Post(s)
FLOBY did you check the clock out on youtube?
post #7 of 8 (permalink) Old 06-26-2019, 07:47 AM
tuttebenne's Avatar
Date registered: Jul 2005
Vehicle: W124
Quoted: 483 Post(s)
Yes they are the pulse type.
'93 400E
'93 500E
'94 E320TE
'00 E320
'02 E320
'73 Alfa GTV
'77 308GTB
tuttebenne is offline
post #8 of 8 (permalink) Old 06-26-2019, 12:49 PM Thread Starter
Floobydust's Avatar
Quoted: 93 Post(s)
Yes, I just did and you can see the pulse solenoid in the mechanism. Thank you!
