w124 94' e320 weatherstrip part number help - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 06-18-2019, 01:55 PM Thread Starter
Date registered: Jun 2019
I've got this problem where the weatherstrip that connects with the bottom of the car doors and the body of the car has come loose. I believe it might be called a Rocker Molding Seal but am unsure. It is a rubber lining that is inserted just above the wheel jack holes.
I have also highlighted the area in the attached image for a better look at what I am talking about.
Does anyone have a clue what the part number might be or what this is called exactly?
Thanks for your help!
Shmeid is offline
post #2 of 3 (permalink) Old 06-18-2019, 09:33 PM
Date registered: Nov 2011
Vehicle: 1993 300D 2.5 "Elsie"
Quoted: 92 Post(s)
I just posted about this same thing not too long ago. I believe the rubber strip is part of the rocker panel cover and not available separately. The general consensus seemed to be to either remove it completely, since it is really just a cosmetic thing to cover the screws that hold the rocker cover, or put some adhesive in there. The goopy black silicone sealant should hold it at least for several years. You do have to pull out the rubber part and clean everything thoroughly first. I went through a lot of Simple Green and paper towels.
1993 300D "Elsie"
chuckh0308 is offline
post #3 of 3 (permalink) Old 06-19-2019, 01:05 PM Thread Starter
Hey @chuckh0308 , thanks for the identification and advice. The car is definitely too old to warrant a new rocker panel cover. Simple Green and paper towels it is!
Shmeid is offline
