Blacked Out Instrument Panel - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 06-15-2019, 06:02 PM Thread Starter
Date registered: Jun 2019
Vehicle: 1993 300D 2.5 Turbo Diesel
Instrument panel in my 1993 2.5 Turbo Diesel recently went dark. I replaced fuse 5 to no avail. Any ideas? I'm a very new Mercedes owner and am not quite sure how to proceed. Thanks!
scoleman is offline
post #2 of 7 (permalink) Old 06-15-2019, 06:50 PM
Date registered: Jul 2007
Vehicle: 95 E300, 91 300TE, 84 190D
Quoted: 16 Post(s)
The knob to the left of the speedometer resets the odometer when pushed, and adjusts the intensity of the dash lights when turned. Turn it clockwise and counter clockwise a few times to see if that helps.
ds190 is offline
post #3 of 7 (permalink) Old 06-15-2019, 06:51 PM Thread Starter
I tried that earlier, didn't do anything.
scoleman is offline
post #4 of 7 (permalink) Old 06-16-2019, 03:02 AM
plinker17722's Avatar
Date registered: Mar 2015
Vehicle: 1989 W124 260E
Quoted: 142 Post(s)
Then bridge the wires on the dimmer switch itself .But it will be bright all the time you wont be able to dim it . Replacement is easy remove screws reverse operation to fit back in place . The lights went off in my cluster . so i removed the pot . Only to find after i operated on it that the potentiometer had fallen to bits inside .Cleaned it and put it back, all is well with it now.
This is a retro ride .
plinker17722 is offline
post #5 of 7 (permalink) Old 06-18-2019, 08:25 AM
Robert Kyle's Avatar
Date registered: Feb 2018
Vehicle: 1994 e320 coupe (sold), 1990 300CE ($400 beater)
Quoted: 163 Post(s)
That will require a cluster pull, so get those hook things to pull it. It's not so bad. Just getting behind w/your fat, big hand to loosen/re-tighten the speedo cable is not that fun.
Robert Kyle is offline
post #6 of 7 (permalink) Old 06-18-2019, 01:15 PM
LeftCoastGeek's Avatar
Date registered: Jul 2011
Vehicle: 1993 300CE Cabriolet (mine) ; 1994 E320 Wagon (wife's) ; 1990 Benz 300E 2.6 (son's)
Quoted: 1309 Post(s)
keeping all the indicator bulbs sorted is a bit of a pain, too. i suggest labeling them the first time you pull the panel, as you remove each bulb+wire
LeftCoastGeek is offline
post #7 of 7 (permalink) Old 06-18-2019, 01:32 PM
Floobydust's Avatar
Date registered: Nov 2002
Vehicle: 2003 G500, 2000 SL500, 1995 E320 Cabriolet, 1980 TR8
Quoted: 93 Post(s)
I believe that there is a fuse in the back of the instrument cluster that "protects" the instrument lights. It looks like a bulb but in a red socket. I'll bet yours is blown.
Floobydust: a contemporary term derived from the archaic Latin miscellaneous, whose disputed history probably springs from Greek origins (influenced, of course by Egyptian linguists) - meaning here "a mixed bag." - National Semiconductor Audio Handbook
Floobydust is offline
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
