My starter motor? I don't think so but I'm not sure. - Mercedes-Benz Forum
post #1 of 22 (permalink) Old 06-15-2019, 09:58 AM Thread Starter
theblueprince's Avatar
Date registered: Dec 2008
Vehicle: E 300D 1995
Question My starter motor? I don't think so but I'm not sure.
Hey all. Yesterday my car wouldn't start up. I'm in a 95 300D. This is the first time this has happened and the battery's good. To my knowledge everything was running fine.
Details are as follows: totally rainy night and morning. super humidity. When I turned the key everything functioned as normal except that it wouldn't turn over. When I say that I mean there was nothing at all after the glow plugs went out and I put the key into the last position. Nothing. Then after a little bit something happened. It just worked somehow. I'm not sure what I did. I messed with fuses but none of them looked messed up anyway. Tis a mystery.
Haven't had a problem since, and nothing led up to this either. It just happened that one incredibly rainy morning. I feel like it's got to be related to the moisture but it might not be also. Any suggestions or similar stories would be appreciated. Is there something I can check to see what's what in there? I'm headed on a long journey next month and don't feel getting stranded somewhere. I've heard things about alarm stuff getting in the way of cars starting but my alarm didn't go off... Baffled.
Thanks to all.
Shane
theblueprince is offline
post #2 of 22 (permalink) Old 06-15-2019, 06:59 PM
Jayare's Avatar
Date registered: Jun 2005
Vehicle: 86 190E 2.3L 16V, 2 95 320TE's, 02 S500
Quoted: 1102 Post(s)
Hi Shane
The number one suspect is your neutral safety switch (NSS). You didn't mention the mileage on the car/transmission, but regardless, the NSS controls starting. It also controls your backup lights. Make sure they are operational.
Is your shift lever firm from notch to notch or is there play in the shaft? Worn shift linkage bushings can also cause intermittent start failures. If the problem happens again, place the transmission in neutral and try starting. If it fired off, it's one or both of the above.
Is it your plan to diy this project?
Jayare
Sent from my XT1710-02 using Tapatalk
tuttebenne likes this.
Jayare is online now
post #3 of 22 (permalink) Old 06-15-2019, 08:38 PM Thread Starter
Jayare - the mileage is 192,000. There's no play. It's a solid movement game. I'm gonna go and try the reverse light thing and thanks for the neutral starting info. That's great. I didn't think of that or know of it. My gut says it is not the starter. Something else was happening.
This will be a DIY.
Thanks again.
post #4 of 22 (permalink) Old 06-15-2019, 09:05 PM Thread Starter
Reverse lights work fine by the way... Maybe it is the starter starting... I was parked on a slight incline the morning of it not working. Any way to test if the starter is failing?
Thanks again to anyone out there.
post #5 of 22 (permalink) Old 06-16-2019, 05:32 AM
Jayare's Avatar
It is very, very rare that one of these starters fail. Again, the likely suspect is the NSS. We have tones of threads on this...the search tool will show you a bunch.
Jayare
post #6 of 22 (permalink) Old 06-16-2019, 06:41 AM
Real1shepherd's Avatar
Date registered: Jul 2009
Vehicle: '92 300TE 4matic 280,000miles, '92 300TE 4Matic 'Ice Blue Metalic' 101,000miles
Quoted: 498 Post(s)
Starters go bad on these cars usually when an owner has a fuel/ignition issues and cranks their car for long periods to start.....any starter in the world would fail under those circumstances.
Otherwise, they're very durable.
Kevin
Real1shepherd is offline
post #7 of 22 (permalink) Old 06-18-2019, 08:23 AM
Robert Kyle's Avatar
Date registered: Feb 2018
Vehicle: 1994 e320 coupe (sold), 1990 300CE ($400 beater)
Quoted: 164 Post(s)
If it starts in Neutral, get a new one of these:
https://www.ebay.com/itm/For-Mercede...72.m2749.l2649
Robert Kyle is offline
post #8 of 22 (permalink) Old 06-22-2019, 11:06 AM Thread Starter
THanks everyone for the suggestions. Much appreciated. Seems like a NSS.
post #9 of 22 (permalink) Old 08-15-2019, 04:16 PM Thread Starter
Question
It's been awhile since I've had any starter issues or NSS issues. I'm wondering if we need to have a NSS at all. Anyone know the answer there?
Thanks everybody
post #10 of 22 (permalink) Old 08-16-2019, 02:21 AM
plinker17722's Avatar
Date registered: Mar 2015
Vehicle: 1989 W124 260E
Quoted: 161 Post(s)
So that your engine wont start in drive or reverse .
plinker17722 is offline
