Testing a starter motor 95 300D - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 06-15-2019, 07:59 AM Thread Starter
theblueprince's Avatar
Date registered: Dec 2008
Vehicle: E 300D 1995
Hello everyone. Recently it was really rainy and I went to start my car. Nothing. Battery's good - all signs vital. I'm thinking starter obviously - but I've heard of a starter switch and maybe some other things to look at before replacing the starter itself.
It did eventually start. I know that starters "start" to go before they actually die. Then the rain thing is curious. Maybe a bad connection somewhere? I don't know.
Can anyone assist out there?
Thank you.
TBP
theblueprince is offline
post #2 of 8 (permalink) Old 06-15-2019, 01:21 PM
rumb's Avatar
Date registered: Oct 2012
Vehicle: 68 250S, 91 300se, 98 SL500, 450SEL 6.9, 14 CLS550 Past MB's; 300SD, 300E, 300TE, 190E, ML420
Quoted: 831 Post(s)
Check and clean all connections and grounds
rumb is offline
post #3 of 8 (permalink) Old 06-15-2019, 06:46 PM
Kajtek1's Avatar
Quoted: 1979 Post(s)
Car/starter mileage?
MB starters usually outlast the car, so check other things before replacing.
1995 is W124 body, but with engine that was getting ready for W210.
I have not much knowledge what was put in the year of changes, but next year for sure had computer-controlled starter, who would not engage if computer sense questionable voltage.
Battery is hard to test item, but try to observe voltage during cranking.
Or home test is check the voltage with engine off and all the headlights + blower on.
Kajtek1 is offline
post #4 of 8 (permalink) Old 06-16-2019, 06:06 AM
Michael Pillay's Avatar
Date registered: Oct 2003
Quoted: 131 Post(s)
I enjoy this guy's videos. He may be a member here. Not sure but maybe this will help you:
Mike
Michael Pillay is online now
post #5 of 8 (permalink) Old 06-16-2019, 02:15 PM
miltiano32's Avatar
Date registered: Dec 2010
Vehicle: 1988 300CE
Quoted: 83 Post(s)
The starter in my old E300D was going out and would take a couple turns of the key to get going but my car did have 500K miles on it. I just lived with the problem till i got a replacement starter for it.
1995 E300D TOTALED. The rest sold...1993 190E LE, 1995 E320, 1989 300E, 1991 190e, 1988 260e.
miltiano32 is offline
post #6 of 8 (permalink) Old 06-17-2019, 05:04 AM
tuttebenne's Avatar
Date registered: Jul 2005
Vehicle: W124
Quoted: 483 Post(s)
The neutral safety switch will make the car act like it has a starter problem Google this part and you will find suggestions to try to start the car in neutral when it doesn't start in Park. This kind of step helps narrow down where the problem is.
boyd waugh likes this.
'93 400E
'93 500E
'94 E320TE
'00 E320
'02 E320
'73 Alfa GTV
'77 308GTB
tuttebenne is offline
post #7 of 8 (permalink) Old 06-18-2019, 08:16 AM
Robert Kyle's Avatar
Date registered: Feb 2018
Vehicle: 1994 e320 coupe (sold), 1990 300CE ($400 beater)
Quoted: 163 Post(s)
What's the symptoms?
No noise? Click? Anything?
If no noise, yes, try starting it in Neutral. My beater does that sometimes and I just throw it in neutral.
Next time I jack it up, I'm going to replace this thing:
https://i.ebayimg.com/images/g/~EMAA...QP/s-l1600.jpg
Robert Kyle is offline
post #8 of 8 (permalink) Old 06-22-2019, 11:04 AM Thread Starter
Thanks everyone for the messages and suggestions. Much appreciated.
Shane
