95 E320 Cranks but No Spark - Page 2 - Mercedes-Benz Forum
post #11 of 26 (permalink) Old 06-06-2019, 01:22 PM Thread Starter
hinshelwood's Avatar
Date registered: Sep 2018
Ordered a crank sensor to test first. The no start condition started when I put the rebuilt/swapped engine in the car. The car ran well after the new wiring harness was installed and even ran when I first changed the head gasket on the old engine. Head gasket failure and to much machining is what eventually killed the old engine. The voltage on the coils is 11.8 V DC when the key is in accessory mode. When the starter turns the engine over this voltage drops to about 9-10 volts. What is interesting is that the car will almost start with a freshly charged battery and a 200 amp car starter. Also checked the ground connection on the bell housing and it seems clean and solid.
hinshelwood is offline
post #12 of 26 (permalink) Old 06-06-2019, 01:34 PM
miltiano32's Avatar
Date registered: Dec 2010
Vehicle: 1988 300CE
Quoted: 83 Post(s)
How is the condition of the voltage regulator? Its pretty quick to inspect and see the contacts on it
miltiano32 is offline
post #13 of 26 (permalink) Old 06-06-2019, 03:21 PM
Jayare's Avatar
Date registered: Jun 2005
Vehicle: 86 190E 2.3L 16V, 2 95 320TE's, 02 S500
Quoted: 1102 Post(s)
This will have no impact on the OP's no start issue.
Sent from my XT1710-02 using Tapatalk
Jayare is online now
post #14 of 26 (permalink) Old 06-06-2019, 04:23 PM
Floobydust's Avatar
Date registered: Nov 2002
Vehicle: 2003 G500, 2000 SL500, 1995 E320 Cabriolet, 1980 TR8
Quoted: 96 Post(s)
Originally Posted by hinshelwood View Post
. . The no start condition started when I put the rebuilt/swapped engine in the car. . . .
When you changed motors did you install the (known working) coil packs from your original engine into the new one?
Floobydust: a contemporary term derived from the archaic Latin miscellaneous, whose disputed history probably springs from Greek origins (influenced, of course by Egyptian linguists) - meaning here "a mixed bag." - National Semiconductor Audio Handbook
Floobydust is offline
post #15 of 26 (permalink) Old 06-06-2019, 05:53 PM Thread Starter
Yep made sure I used the known good coil packs from the first engine. Ordered a crank shaft sensor. Should be here tomorrow so I'll see if that fixes things.
post #16 of 26 (permalink) Old 06-07-2019, 01:25 PM Thread Starter
The plot thickens...Installed the new crank sensor and the car would still crank but not start. After installing the new sensor and cranking a few times I checked for diagnostic codes and counted 20 and 22 pluses. My car has the California built in button. When leaving the car key in accessory mode I can hear the throttle body whining a bit (not sure if it is stuck). I held the diagnostic button down for 45 seconds and cleared the codes but the car still would not start. Poking around online I found a manual that indicates codes 20 is "Speed signal not present" and 22 is "Camshaft position sensor signal defective". Not sure if a bad camshaft sensor would cause a no start condition. Out of curiosity I pulled out the batter and ECU to find that it has been reprogrammed by quickchips. At this point I have found an inexpensive ECU to test on the car. Maybe the reprogrammed version is messed up? I have not seen the codes 20/22 after clearing them however the check engine light does come on and off randomly.
post #17 of 26 (permalink) Old 06-07-2019, 01:52 PM
Walt'89300CE's Avatar
Date registered: Oct 2018
Vehicle: 1989 300CE & 1971 280SE; 73.5 911T
Quoted: 45 Post(s)
Always check the simple, cheap stuff first.
On the back of the alternator, perhaps behind a plastic screen, you will find two screws that fasten the voltage regulator to the alternator.
Remove the 2 screws and gently twist off the VR.
Examine the two brushes. If they are shorter than 1/2" in length, replace with a new VR- about $30.
There should be a part number on the side of the VR, which you want to match.
This is one of the most common causes of electrical/ignition failure.
And so easy & cheap to fix.
Walt'89300CE is offline
post #18 of 26 (permalink) Old 06-07-2019, 01:58 PM Thread Starter
I checked the voltage regulator yesterday. The brushes were longer than 0.5" and made solid contact with the rotor. The alternator is fairly new. My brother had replaced this about 2 years ago.
post #19 of 26 (permalink) Old 06-07-2019, 02:48 PM
Jayare's Avatar
This has nothing to do with the car being in a no start mode. For that matter, you could cut the serpentine belt and start the car.
Jayare
post #20 of 26 (permalink) Old 06-10-2019, 11:59 AM Thread Starter
Got the new(used) ECU in today. Installed it plugged up the battery. Turned the key on to accessory mode and waited 4 minutes for the ECU to initialize. Turned the key off then tried to crank the car. Unfortunately the car would still crank over but not start. At a loss as to the problem now. Anyone have some ideas?
