W124 220 E Air Con not working - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 05-25-2019, 03:53 AM Thread Starter
Date registered: Sep 2012
Vehicle: Mercedes W123 Mercedes W124
Quoted: 2 Post(s)
Smile W124 220 E Air Con not working
Hello everyone. I hope you'll are having a good day Need help on fixing my W124 AC. I started the car after almost a month and everything ran perfectly fine. However, when I powered on the AC, it didnt blow cool air at all. I later opened the hood and see the clutch engaged and fan running fine. When the AC is off, the fan stops and the Clutch disengages. What do you guys think is the problem here? Appreciate your help on this
ab.hyd is offline
post #2 of 5 (permalink) Old 05-25-2019, 06:28 AM
Vehicle: 1999 E430; 2005 ML500
Quoted: 114 Post(s)
If your refrigerant lines near the firewall are getting ice cold, the problem is likely with the blend door actuators in the dash.
Hirnbeiss is offline
post #3 of 5 (permalink) Old 05-26-2019, 03:36 AM
Jayare's Avatar
Date registered: Jun 2005
Vehicle: 86 190E 2.3L 16V, 2 95 320TE's, 02 S500
Quoted: 1103 Post(s)
If you have your own A/C manifold gages, it's time to use them. If not, take the car to a qualified shop and have them check the refrigerant.
Sent from my XT1710-02 using Tapatalk
Aero I likes this.
Jayare is offline
post #4 of 5 (permalink) Old 05-26-2019, 05:16 AM
Aero I's Avatar
Date registered: Sep 2008
Vehicle: 04 E500 359; 00 SL500 040/Pano; 99 SL500 366/Pano; 94 E420 744; 92 500E 481; 92 500E 199; 92 300CE
Quoted: 175 Post(s)
Agree with Jayare, the most common problem will be low refrigeration.
If you don't have gauges available to you, if your system has 134, just pick up a can and install it yourself, read the directions, not hard to do.
And if it works for a day or so and then stops again, you have a leak you need to find..
Did this on my wifes E420, after I figured out it was leaking, tried it the second time with dye. Unfortunately the green dye came out of the HVAC box, the dreaded evap leak.
I bit the bullet and had the dash taken out to get to the evap, expensive, but done for the life of the car. I remember Jayare posting years back about a sealer that worked for him on his 400..
Ms. Bornite
Daily Drivers:
06 Lexus GX470
94 E420-744
Seasonal Daily Drivers:
00 SL500-040/Pano
99 SL500-366/Pano
92 500E-199
92 300CE-199
Seasonal Week-End Warriors:
04 E500-359
92 500E-481/498
Retired:
99-SL500-040 (T-Boned Parts Car RIP)
94 Pathfinder - "Old Rusty" sold
81-380SL-735 (Sold & exported to China)
Aero I is offline
post #5 of 5 (permalink) Old 05-26-2019, 05:25 AM
Jayare's Avatar
I bit the bullet and had the dash taken out to get to the evap, expensive, but done for the life of the care. I remember Jayare posting years back about a sealer that worked for him on his 400..
Correct..It was ClipLight Super seal Pro that stopped the evap leak for over 5 yrs.
Aero I and Robert Kyle like this.
Jayare is offline
