Transmission woes - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 05-20-2019, 05:05 AM Thread Starter
Date registered: Mar 2019
Vehicle: 1990 300E
Transmission woes
1990 300E in great shape, sat for two years, now running again when I bought it. I don't know the history other than it was apparently very well maintained. When I drive it doesn't want to shift out of second, I have to wind the gear out a little bit and then let off the gas and it'll shift into third. On the highway I'm doing 58mph at about 2500RPM, which feels a bit high, so perhaps it's not shifting into overdrive. I checked the ATF and it was still bright pink, although just a touch high. Would being slightly overfilled on ATF cause these odd shifting issues, or is my transmission just dying?
infinitenexus is offline
post #2 of 6 (permalink) Old 05-20-2019, 09:45 AM Thread Starter
Vehicle: 1990 300E
So from doing some reading, i've seen others having a similar issue. It wants to stay in second gear, and when it shifts it goes from third almost immediately to fourth. Replacing the K1 spring might help.
post #3 of 6 (permalink) Old 05-20-2019, 11:02 AM
Jayare's Avatar
Date registered: Jun 2005
Vehicle: 86 190E 2.3L 16V, 2 95 320TE's, 02 S500
Quoted: 1065 Post(s)
It could be a couple of things causing your shift problem. Check that the vacuum line from the shift modulator (driver's side of the transmission) isn't securely attached. Secondly, check that the Bowden cable is adjusted properly.
Report back and good luck
Jayare
Sent from my XT1710-02 using Tapatalk
Jayare is online now
post #4 of 6 (permalink) Old 05-20-2019, 11:18 AM
Robert Kyle's Avatar
Date registered: Feb 2018
Vehicle: 1994 e320 coupe (sold), 1990 300CE ($400 beater)
Quoted: 160 Post(s)
There's no overdrive in these 722.3 transmissions.
58mph doing 2500 RPM sounds right I think.
I have a 3.27 rear end and I'm pushing 3000 RPM at that speed.
Sounds very much like a vacuum modulator issue to me.
Robert Kyle is offline
post #5 of 6 (permalink) Old 05-20-2019, 11:21 AM Thread Starter
Vehicle: 1990 300E
I'll admit I'm pretty ignorant when it comes to automatic transmissions. Every other car I've owned has been a manual, so this is new grounds for me. I already ordered the new spring, at less than 10 bucks I figured it's hard to go wrong. I'll search around for this vacuum modulator issue and see what I can learn. Thanks guys.
Honestly I'm a little surprised at those high RPM at highway speed! I would think it would be a little lower, to feel a bit smoother. Glad to know that's correct though. The car shifts into third and immediately fourth so quickly, I think I was just assuming it was only shifting into third.
post #6 of 6 (permalink) Old 05-21-2019, 11:31 AM Thread Starter
Vehicle: 1990 300E
Okay, so after work this evening I'm going to try to find and adjust the throttle pressure cable. Fingers crossed, that'll help. After that, I'll try adjusting the vacuum modulator (any tips there?), and then once my new K1 springs comes in the mail and I actually find a place around here that sells Dex 3 ATF (Walmart doesn't) then I'll install that. Assuming one or all of these fixes my shifting issues, I'll be keeping the car for my wife. If not, I'll just sell it cheap. I don't have a lot of spare time or spare cash right now, so this car definitely isn't my best bet.
Handy ML Transmission Notes - Part A AC_ML W163 M-Class 6 10-09-2011 05:29 PM
Transmission problem (P0715) SLK_Kamil R170 SLK-Class 5 01-03-2009 01:02 AM
SLK Transmission Problem (P0715) SLK_Kamil R170 SLK-Class 0 10-17-2008 10:30 PM
Transmission Cooler clearchris W163 M-Class 11 11-12-2007 07:09 AM
Transmission advice to y'all roadsession W163 M-Class 4 12-12-2004 05:05 AM
