HVAC question... - Mercedes-Benz Forum
post #1 of 15 (permalink) Old 05-19-2019, 09:57 PM Thread Starter
Robert Kyle's Avatar
Date registered: Feb 2018
Vehicle: 1994 e320 coupe (sold), 1990 300CE ($400 beater)
Quoted: 159 Post(s)
HVAC question...
When the button is set to blow air to your feet, does some air still blow through the defrost?
I can see the Pod move from the different settings, but some still go through the vents as aforementioned.
Would the Pod be needing replaced? If I force the lever more, no air gets through.
Robert Kyle is offline
post #2 of 15 (permalink) Old 05-20-2019, 04:58 AM
tuttebenne's Avatar
Date registered: Jul 2005
Vehicle: W124
Quoted: 474 Post(s)
My understanding has been that there is not a setting for footwell only. There is "footwell and defrost " and "footwell with less deftrost"
Jayare and Real1shepherd like this.
'93 400E
'93 500E
'94 E320TE
'00 E320
'02 E320
'73 Alfa GTV
'77 308GTB
tuttebenne is offline
post #3 of 15 (permalink) Old 05-22-2019, 05:18 PM Thread Starter
Quoted: 159 Post(s)
Hmm...so this is normal?
post #4 of 15 (permalink) Old 05-22-2019, 10:32 PM
Real1shepherd's Avatar
Date registered: Jul 2009
Vehicle: '92 300TE 4matic 280,000miles, '92 300TE 4Matic 'Ice Blue Metalic' 101,000miles
Quoted: 481 Post(s)
On the TE's because there is so much glass, which is a bad thing in the summer......we found that the button second from the left allows some defrost air, which is actually cold air with the AC on. This helps in dispelling some of the heat coming through the windshield, especially sitting in traffic. Button third from the left does not allow 'enough' defrost air to hit windshield. Now the 'economy' button I'd have to play with to give you an answer there, but I don't think it gives 'enough' defrost air to do anything and it bypasses the AC. If memory serves....anytime the windshield is starting to cloud (like on rainy days), you have to retreat back to the second button from the left.
I've always found the HVAC control switching a very strange functioning array on the 124's. Logical yes, but poor ergonomics. And as your pods wear, the system gets downright funky.
Kevin
Real1shepherd is offline
post #5 of 15 (permalink) Old 05-23-2019, 05:18 AM Thread Starter
Quoted: 159 Post(s)
I prefer NO defrost air on any settings except the far left button.
Dries my eyes
post #6 of 15 (permalink) Old 05-23-2019, 05:28 AM
Aero I's Avatar
Date registered: Sep 2008
Vehicle: 04 E500 359; 00 SL500 040/Pano; 99 SL500 366/Pano; 94 E420 744; 92 500E 481; 92 500E 199; 92 300CE
Quoted: 175 Post(s)
Just general info on the vacuum pods that may be useful.
Check out this link, a thread in another forum specifically on 124 vacuum pods for the HVAC system.
https://www.500eboard.co/forums/inde...-update.10906/
Spoiler alert - as you read through the tread you will see that in the last 2 years several of the pods are NLA.
I was reading this thread in real time 2 years ago, and decided to source new pods for all 4 of my 124's, and I was able to get them all, including the parts to rebuild the center vent pods.
I haven't done anything with them yet, they are all sitting on the shelf for when I get more time.
I need to change out the pods in the 94 E420 first, at least 3 of them are not working right, and the center pod on my 92 Bornite 500E isn't working.
Hopefully Mercedes may do another run of these critical parts some day, or a aftermarket company will.
I'm still in favor of the old fashion controls that used manually operated cables to operate the flaps. They never break and will out last the car. I really don't need a thermostat to maintain temps, easy enough to manually set controls. The last car/truck I seen with manual heater/AC controls on was my old 94 Pathfinder, they worked perfect, never failed and if a cable was to ever fail, any old generic choke cable could be modified to fit.
All these USA Mercedes features are nice until they stop making replacement parts for them.
Ms. Bornite
Daily Drivers:
06 Lexus GX470
94 E420-744
Seasonal Daily Drivers:
00 SL500-040/Pano
99 SL500-366/Pano
92 500E-199
92 300CE-199
Seasonal Week-End Warriors:
04 E500-359
92 500E-481/498
Retired:
99-SL500-040 (T-Boned Parts Car RIP)
94 Pathfinder - "Old Rusty" sold
81-380SL-735 (Sold & exported to China)
Aero I is offline
post #7 of 15 (permalink) Old 05-23-2019, 07:49 AM Thread Starter
Quoted: 159 Post(s)
Okay, thanks for the info on the pods, but I still need confirmation on what the OEM behaviour is.
The far right buttons (not including the Off button), one is STILL to get air coming out of the defroster vent?
I feel like stuff a rag in those vents to keep my eyes from drying out.
post #8 of 15 (permalink) Old 05-23-2019, 08:14 AM
luckymike's Avatar
Date registered: Mar 2010
Vehicle: 1989 560SEC, 1989 560SEL, 1995 E420
Quoted: 548 Post(s)
Section 83-600 of the manual describes how the system is designed to work. You should find your answer there.
I tried to attach it but it's too big. Available on this site, though.
luckymike is online now
post #9 of 15 (permalink) Old 05-23-2019, 08:56 AM Thread Starter
Quoted: 159 Post(s)
From this, it looks like there IS supposed to be "enough" air coming out of the defroster vents from those last two right buttons:
post #10 of 15 (permalink) Old 05-23-2019, 09:06 AM
luckymike's Avatar
Quoted: 548 Post(s)
Yes, but apparently only when the system is heating. Is that how yours is working?
HVAC box rebuild and install 91 SEC alydon W126 S,SE,SEC,SEL,SD,SDL Class 16 08-09-2014 05:14 AM
HVAC ctr vent and controller question Gungatim R129 SL-Class 3 05-31-2011 04:55 AM
The Question of God by Steve Martin Nightbird Off-Topic 8 11-28-2010 01:41 PM
Introduction and a question Porschescum W163 M-Class 5 07-19-2006 12:09 PM
President Bush authorized the leak MBZ300CD Off-Topic 79 04-10-2006 08:48 PM
