Rough idle stall when at operating temp - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 05-18-2019, 06:12 PM Thread Starter
Date registered: May 2019
My parents have a 94 E420. If you start it and go it runs great but as soon as the temp gague hits about halfway it has a rough idle and if you go into gear it hesitates and runs really rough and will stall if you don't feather the gas. Any ideas?
richmas99 is offline
post #2 of 7 (permalink) Old 05-19-2019, 09:53 PM
Robert Kyle's Avatar
Date registered: Feb 2018
Vehicle: 1994 e320 coupe (sold), 1990 300CE ($400 beater)
Quoted: 160 Post(s)
Bio harness upgraded?
Robert Kyle is offline
post #3 of 7 (permalink) Old 05-19-2019, 09:59 PM Thread Starter
Yup harness replaced. Fuel pumps replaced. Rotors caps and coils all replaced to.
post #4 of 7 (permalink) Old 05-20-2019, 11:11 AM
Jayare's Avatar
Date registered: Jun 2005
Vehicle: 86 190E 2.3L 16V, 2 95 320TE's, 02 S500
Quoted: 1064 Post(s)
Check the caps and rotors again. They have a propensity to cause problems. If the suppressor disk weren't replaced, they most likely need to be.
Jayare
Sent from my XT1710-02 using Tapatalk
Real1shepherd likes this.
Jayare is offline
post #5 of 7 (permalink) Old 05-20-2019, 11:21 AM Thread Starter
What are surpressor disks? Lol
post #6 of 7 (permalink) Old 05-20-2019, 12:08 PM
speed9644's Avatar
Date registered: May 2013
Vehicle: '94 E220
Quoted: 158 Post(s)
check the fuel pressure regulator
- Samir
speed9644 is offline
post #7 of 7 (permalink) Old 05-20-2019, 12:39 PM
Jayare's Avatar
The orange disk that sits behind the rotor. You have to remove the rotor bracket to replace them. It's a very simple job. In the meantime, pull the caps, clean them and spray them with some WD 40. See if that doesn't solve the rough running condition. This is a common problem on V8 models. Especially if they aren't driven daily.
tuttebenne likes this.
Jayare is offline
'82 230E, rough idle / no reaction from idle screw osprey W123 E,CE,D,CD,TD,TE Class 14 11-08-2015 11:34 AM
Summer temp up -rough idle gone??? darraghodonnell R129 SL-Class 0 07-12-2010 01:44 PM
89 420SEL rough idle, and stall at start up, economy gauge.... Hiendguy W126 S,SE,SEC,SEL,SD,SDL Class 0 07-05-2010 10:03 PM
Intermittent engine stall causes? 500SEL drcvd W140 S-Class 12 12-04-2009 09:26 AM
ROUGH IDLE, IDLE CONTROL UNIT LOCATION, TIMING & RPM verdejor General Mercedes-Benz 5 01-22-2006 08:41 PM
