Door lock vacuum line size/part number - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 05-16-2019, 11:24 AM Thread Starter
Date registered: Jul 2011
Vehicle: 1995 E320 wagon
Quoted: 65 Post(s)
Heyoo, Im trying to find the part number for the yellow vacuum line in the lock system. Its bigger than the standard 1x4mm stuff, Im prettty sure its something like 3x5mm or something like that...I cant for the life of me find part numbers
1995 E320 wagon <--Daily
1959 Austin Healey sprite <--Toy/project
1982 Olds Custom Cruiser LQ4 <--Dads beast/project
1974 Fiat X1/9 <--Moms toy
Im a Volvo nut with a german brick!
autocomman is offline
post #2 of 9 (permalink) Old 05-16-2019, 05:59 PM
LeftCoastGeek's Avatar
Vehicle: 1993 300CE Cabriolet (mine) ; 1994 E320 Wagon (wife's) ; 1990 Benz 300E 2.6 (son's)
Quoted: 1296 Post(s)
A0001581435 Piping from (lots of places) to (lots of places) Order by the meter.
FROM DISTRIBUTOR ON LEFT MAIN FLOOR TO VACUUM ELEMENT ON LEFT FRONT DOOR 1900 MM
FROM DISTRIBUTOR ON LEFT MAIN FLOOR TO VACUUM ELEMENT ON LEFT REAR DOOR 1150 MM
FROM DISTRIBUTOR ON RIGHT FRONT FLOOR TO VACUUM ELEMENT ON RIGHT FRONT DOOR 1900 MM
FROM DISTRIBUTOR ON RIGHT MAIN FLOOR TO VACUUM ELEMENT ON RIGHT REAR DOOR 3150 MM
FROM DISTRIBUTOR ON RIGHT MAIN FLOOR TO DISTRIBUTOR ON LEFT FLOOR 1750 MM
FROM PUMP TO DISTRIBUTOR ON MAIN FLOOR , RIGHT 1050 MM
FROM PUMP TO DISTRIBUTOR AT FILLER NECK FLAP 1500 MM
plinker17722 likes this.
LeftCoastGeek is offline
post #3 of 9 (permalink) Old 05-17-2019, 07:29 AM Thread Starter
Quoted: 65 Post(s)
Thats the 4mm vacuum pipe, The door locks were 5mm i thought?
post #4 of 9 (permalink) Old 05-17-2019, 11:29 AM
thats the only tubing shown in the whole locking system on the ISPPI diagram for a 124.092 320TE/E320 wagon.
post #5 of 9 (permalink) Old 05-18-2019, 08:59 PM Thread Starter
Quoted: 65 Post(s)
Cool beans, sounds good, thanks!!
post #6 of 9 (permalink) Old 05-19-2019, 07:36 AM
Real1shepherd's Avatar
Date registered: Jul 2009
Vehicle: '92 300TE 4matic 280,000miles, '92 300TE 4Matic 'Ice Blue Metalic' 101,000miles
Quoted: 482 Post(s)
You can buy silicon tubing in all the metric sizes from Amazon....just keep it on hand....that's what I did.
Kevin
Real1shepherd is offline
post #7 of 9 (permalink) Old 05-20-2019, 03:27 AM
plinker17722's Avatar
Date registered: Mar 2015
Vehicle: 1989 W124 260E
Quoted: 136 Post(s)
Ok as long as you dont use it in the engine depot for fuel . Even the small pipe that runs in to the valve cover from regulator goes brittle over a period of time . But for short tearm use i would think it could be used but keep a eye on it .
This is a retro ride .
plinker17722 is offline
post #8 of 9 (permalink) Old 05-20-2019, 06:14 AM
Quoted: 482 Post(s)
I was talking about only for vacuum....not fuel.
Kevin
post #9 of 9 (permalink) Old 05-24-2019, 04:36 PM Thread Starter
Quoted: 65 Post(s)
This is for a vacuum door lock rehose job on a W108. The car is a complete custom, but the vacuum door locks im upgrading to the W124 style with the electric pump, so keyless entry can be had easily. After some time lookin at the parts, its just as easy as swapping the vacuum out for electric actuators, but part of the sweetness of the old benz is the pneumatic door locks. And we all know the W124 door lock system is pretty bullet proof, seems like a no brainier to me
Relationship between intake manifold, PSE pump, and air vents todd_raleigh W210 E-Class 45 01-20-2019 10:37 AM
Auto Climate Control on 1981 500SLC MikeSpeer R/C107 SL/SLC Class 10 09-28-2015 07:14 PM
Blue Vacuum Line? mramay W126 S,SE,SEC,SEL,SD,SDL Class 16 08-12-2014 04:34 AM
Vacuum FUN Chuckler3 W126 S,SE,SEC,SEL,SD,SDL Class 4 12-16-2012 06:18 PM
W123 280E central locking is out of puff (vacuum) Guest (MBNZ) W123 E,CE,D,CD,TD,TE Class 7 02-14-2004 06:15 PM
