300E fuel pump relay question - Mercedes-Benz Forum
post #1 of 15 (permalink) Old 05-14-2019, 11:13 AM Thread Starter
Date registered: Apr 2010
Vehicle: 1982 240D, 1978 450SE, 1991 300E 4Matic, 1975 /8
Hey guys, I pulled the fuel pump relay off my 300E, I have attached a picture.
Can someone pls tell me if it looks like it's been repaired?
aanq is offline
post #2 of 15 (permalink) Old 05-14-2019, 06:26 PM
tuttebenne's Avatar
Date registered: Jul 2005
Vehicle: W124
Quoted: 463 Post(s)
I would say yes it has been repaired. When products are manufactured the QC process sometimes kicks a piece back because it fails final test and then it is repaired and presented to QC again. But this does not look like the kind of repair done at the factory. It appears the trace on the board was either damaged due to a failure or when someone tried to do some soldering they damaged the trace. The wire running from pad to pad in the horseshoe pattern looks like a repair by a previous owner or maybe some repair shop. MB would not allow a supplier to pass a piece with trace damage off as "new".
edit: (at least they wouldn't have passed this off as new back when the W124 was being produced; who knows what they do today)
'93 400E
'93 500E
'94 E320TE
'00 E320
'02 E320
'73 Alfa GTV
'77 308GTB
tuttebenne is online now
post #3 of 15 (permalink) Old 05-14-2019, 11:38 PM Thread Starter
Thank a lot for your help. It's time for a new relay.
aanq is offline
post #4 of 15 (permalink) Old 05-15-2019, 02:00 AM
plinker17722's Avatar
Date registered: Mar 2015
Vehicle: 1989 W124 260E
Quoted: 112 Post(s)
Are you sure its faulty ? What problems do you have .
This is a retro ride .
plinker17722 is offline
post #5 of 15 (permalink) Old 05-15-2019, 02:05 AM Thread Starter
Car randomly stalls. OVP is replaced with new unit. Mechanic says its the relay.
Plugs, wires, distributor and rotor were recently done.
aanq is offline
post #6 of 15 (permalink) Old 05-15-2019, 11:03 AM
tuttebenne's Avatar
Vehicle: W124
Quoted: 463 Post(s)
If the engine suddenly shuts off but easily restarts I would strongly suspect the relay. But you can verify this by listening for the fuel pumps to be running once the car stalls. Leave the key in the same position its in when it stalls and listen for the pumps. If the relay is the problem, the pump(s) will not run. Is there a date code on the suspect relay?
'93 400E
'93 500E
'94 E320TE
'00 E320
'02 E320
'73 Alfa GTV
'77 308GTB
post #7 of 15 (permalink) Old 05-16-2019, 01:38 AM
Quoted: 112 Post(s)
Might be the CPS . You can have the same symptoms with CPS It will start after its cooled down. But you can bridge the Fuel pump relay to rule it out . Once bridged it will run forever till the bridge is removed than it will proove if it is the FPR at fault or not. Just wrap a wire around no 7 and 8 on the base of the relay unit and pop it back in to its holder at the rear of battery.,dont leave this wire in there do remove it after you prove that the FPR is faulty or not.
post #8 of 15 (permalink) Old 05-16-2019, 02:43 AM Thread Starter
Hey guys, thanks for all the input. I got a few used relays from my mechanic to try out. New relay not available locally. The engine does suddenly shut off and then restarts without any trouble, I don't think I can hear the pumps, at this point I'm just trying to coast to the shoulder. I'm hoping the relays from the mechanic will be fine otherwise I will go the wire route to rule it out. I hope it's no the CPS.
I don't see any date stamps on my relay or the ones I got from the mechanic.
aanq is offline
post #9 of 15 (permalink) Old 05-16-2019, 03:02 AM
Quoted: 112 Post(s)
The relay your about to fit must have the same number as the one your taking out .
post #10 of 15 (permalink) Old 05-16-2019, 03:16 AM Thread Starter
My car currently has the 003 545 00 05.
I got four compatible part numbers from the EPC, screenshot attached.
aanq is offline
1997 E320 - Cranks but No Start alfun W210 E-Class 8 07-02-2015 09:23 PM
Fuel pumps Real1shepherd W124 E,CE,D,TD Class 56 06-29-2014 06:03 PM
87 Mercedes 300E fuel pump relay fuse saritak9 W124 E,CE,D,TD Class 6 01-29-2011 06:44 AM
1974 450SL Roadster/ No power to fuel pump rwag Vintage Mercedes-Benz 1 05-05-2010 11:10 AM
I experienced the dreaded fouled fuel pump over the weekend CCORLEY W163 M-Class 14 03-21-2007 04:39 AM
