EHA weeping, Crack in Valve Cover - Mercedes-Benz Forum
post #1 of 39 (permalink) Old 05-07-2019, 11:21 AM Thread Starter
drayper's Avatar
Date registered: Sep 2015
Vehicle: 1991 300ce
Quoted: 37 Post(s)
Greetings you Ole Benz lovers!
The Benz got through another winter! She ran great....but
Spring finally here, last snow fell a couple weeks ago, now it's time to dig into some new issues.
Part 1
1st - While changing the spark plugs, I noticed a hairline crack in the valve cover right in front (pic attached) I got a feeling the cracks going to run. Anyone seen this before? Should I start looking for a replacement? If so anyone know of any sources where I can get one?
2nd - I changed from premium unleaded gas with ethanol to premium unleaded without ethanol because I heard it was better. Shortly after I started experiencing hard starts. Coincidence? First thing in the morning car would start right up, after driving, then it sitting maybe 1/2 hour, come back and it acted like vapor lock, just crank and crank without starting. Finally start after pumping or holding pedal down and run great. Sit a couple hours or over night, same thing, start fine, then repeat scenario. Fuel pump, filter, accumulator, o2 sensor, fuel injectors, etc. all been changed within a year.
Could it have something to do with the crack in the valve cover or....
3rd - Noticed my EHA valve was weeping gas a bit around the edges. Didnt really smell gas, but could visibly see it. Replaced the seals, retightened 3 + .5 nm that didnt help. Is it shot?
These are my main issues right now. As usual I appreciate you guys support and feedback...
ID:	2510704   Click image for larger version
Love My Benz!!!
Dray
drayper is offline
post #2 of 39 (permalink) Old 05-07-2019, 01:01 PM
Robert Kyle's Avatar
Date registered: Feb 2018
Vehicle: 1994 e320 coupe (sold), 1990 300CE ($400 beater)
Quoted: 160 Post(s)
EHA shot.
$250+ brand new.
May help with your hard starting, but you may need to adjust your mixture after install. I.e. whack off the top of the tower to access the 3mm hex screw.
I'm still having dirty starts after replacing my EHA, however I can always get it to start with 3-4 cranks. I'm suspecting fuel pump(s) (not your issue however).
Robert Kyle is offline
post #3 of 39 (permalink) Old 05-07-2019, 01:29 PM
Jayare's Avatar
Date registered: Jun 2005
Vehicle: 86 190E 2.3L 16V, 2 95 320TE's, 02 S500
Quoted: 1063 Post(s)
As mentioned, if the EHA is weeping, it's done.
As for the valve cover..if you have access to a pull yard, get one. If not, you may be able to get a local welding shop to patch it up. Looks to me it was over torqued at some point in hopes of stopping the front corner from leaking. Either way, get a new gasket.
Jayare
Sent from my XT1710-02 using Tapatalk
Jayare is offline
post #4 of 39 (permalink) Old 05-07-2019, 02:10 PM
Date registered: Feb 2009
Vehicle: 1995 e320ce. 1993 230 TE. 1987 Kit car with 260e running gear.
Quoted: 79 Post(s)
Might be cracked but I don't see any leakage.
Clean it up with the wheel of death and lay a bead of 2 part epoxy glue, loctite, araldite etc.
boyd waugh is offline
post #5 of 39 (permalink) Old 05-07-2019, 05:01 PM
Jayare's Avatar
I haven't seen an EHA that was leaking be repaired by new O rings or some sort of adhesive. I would avoid the adhesive.
Check for moisture at the weep holes on the back side of the EHA. Every bad one I've seen, leaks from there. Don't clean anything, just use a strong light to inspect it..
Jayare
Jayare is offline
post #6 of 39 (permalink) Old 05-07-2019, 05:12 PM
Quoted: 79 Post(s)
Adhesive was for the valve cover Jayare
post #7 of 39 (permalink) Old 05-07-2019, 05:23 PM
Jayare's Avatar
Thx Boyd..just didn't read it that way.
boyd waugh likes this.
Jayare is offline
post #8 of 39 (permalink) Old 05-07-2019, 05:35 PM Thread Starter
drayper's Avatar
Vehicle: 1991 300ce
Quoted: 37 Post(s)
Originally Posted by Robert Kyle View Post
EHA shot.
$250+ brand new.
Thx Robert, I ordered an EHA, I'll tweak the duty cycle after the install..
Love My Benz!!!
Dray
drayper is offline
post #9 of 39 (permalink) Old 05-07-2019, 05:44 PM Thread Starter
drayper's Avatar
Vehicle: 1991 300ce
Quoted: 37 Post(s)
Jayare
No pull yards in this area that have w124's, and the closest one has only one ravaged 320. I don't no where all the w124's went when they were in this area. If anyone runs across any at their local yard, let me know. Otherwise, I'll look into a welding shop
Thx J
Love My Benz!!!
Dray
drayper is offline
post #10 of 39 (permalink) Old 05-07-2019, 05:48 PM Thread Starter
drayper's Avatar
Vehicle: 1991 300ce
Quoted: 37 Post(s)
Thx Boyd,
But what is a "Wheel of death" lol, what is that a grinding tool?
Love My Benz!!!
Dray
drayper is offline
Need a new EHA(Electro hydraulic actuator) Jevo2 W124 E,CE,D,TD Class 77 02-02-2017 11:26 AM
Where is a good place to get an EGR delete kit? gregp1962 W123 E,CE,D,CD,TD,TE Class 39 11-10-2014 09:16 AM
Help! Breather cover crack on driver side Valve cover. Pin2 W210 E-Class 7 10-03-2012 07:02 PM
Leaking Valve Cover Gasket - Replaced NewMBOwner W201 190-Class 4 07-10-2006 09:02 PM
