Drive Belt Tensioner Version 1 to Version 2 Conversion? - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 05-07-2019, 05:55 AM Thread Starter
dtsdig's Avatar
Date registered: Feb 2011
Vehicle: 1994 Mercedes E320 Sedan 97K, 1995 Mercedes E320 Wagon 156K, 2009 VW EOS 45K (Wife's car)
Quoted: 104 Post(s)
Send a message via Skype™ to dtsdig
Does anyone know if it's possible to replace the earlier version of the serpentine belt tensioner system with the later automatic version found on the 95's? In the diagram it would be going from the whole mess in the left pic to going to the simple setup on the right. I wish I had my wagon around still to compare to.
I went to install my new belt last night and the tensioner system is completely botched up.
dtsdig is offline
post #2 of 7 (permalink) Old 05-07-2019, 11:53 AM
humblejoe's Avatar
Date registered: Feb 2007
Vehicle: 04 odyssey (265k) 1995 E320 wagon (295k)
Quoted: 329 Post(s)
Pretty sure you can, but you need the later fan bearing bracket I think.
"alte Schulqualität"
W124, One of the last great gifts of West Germany
humblejoe is offline
post #3 of 7 (permalink) Old 05-07-2019, 01:07 PM Thread Starter
dtsdig's Avatar
Quoted: 104 Post(s)
I just ordered the Febi kit and the Stabilus damper from FCP. Not crazy about it, but I need to be ready to go once I get the valve cover back for this car. I wish I knew someone who had done the conversion.
dtsdig is offline
post #4 of 7 (permalink) Old 05-08-2019, 03:26 AM
plinker17722's Avatar
Date registered: Mar 2015
Vehicle: 1989 W124 260E
Quoted: 146 Post(s)
Yes and me,, its a pain to change over the seerpentine belts on the 124 . This is a must do update if it is possible But once you do it its something you wont have to do again for a few years
This is a retro ride .
plinker17722 is offline
post #5 of 7 (permalink) Old 05-08-2019, 04:01 AM Thread Starter
dtsdig's Avatar
Quoted: 104 Post(s)
Have you done the conversion?
dtsdig is offline
post #6 of 7 (permalink) Old 05-08-2019, 09:13 AM
Quoted: 146 Post(s)
belt
No my friend.. But i have only just -well in the last 4 years replaced all these parts you posted about.And if you follow instructions from the manual its easy but time consuming .To make the job quicker you could do with the m2 auto adjuster .
post #7 of 7 (permalink) Old 05-08-2019, 09:31 AM Thread Starter
dtsdig's Avatar
Quoted: 104 Post(s)
Parts should be here tomorrow and I'll get it done.
Jayare likes this.
dtsdig is offline
torque specs for Drive Belt Idler Pulley & Belt Tensioner Assembly RJF3194 W204 C-Class 4 04-23-2016 10:36 AM
Belt tensioner failure within 8k miles w123fanman W201 190-Class 7 03-13-2016 08:02 AM
Mitchell1 Mechanical Labor Estimating Guide NEOKEN R129 SL-Class 26 02-18-2015 01:42 PM
Drive belt tensioner! Camsauce W201 190-Class 2 01-05-2014 06:08 AM
Drive Delt & Belt Tensioner MarJa W163 M-Class 1 04-21-2004 11:39 AM
