92 300E 4matic - help finding centerlink part - Mercedes-Benz Forum
post #1 of 13 (permalink) Old 05-04-2019, 10:53 AM Thread Starter
Date registered: May 2019
So, I'm really sorry, I know the pictures are not a lot to go by but I would be unbelievably appreciative if someone can manage to point me out to what Center Link I need.
My car is currently at the mechanic, and he sent me these pictures because he can't seem to figure out which part I need, he's ordered 4 different ones and none of them fit. As far as I know the car should have been stock save the head and brake lights.
I'm at a total loss as what to do and every day my car is at the shop it gets harder to get to work, you know? I appreciate any help at all!
Super bonus points if you can show or give me the information to be able to find that specific part on amazon or partsgeek or anywhere it's not a billion dollars, thanks so much guys!
https://imgur.com/a/WW0lflm
Zael Devyon is offline
post #2 of 13 (permalink) Old 05-04-2019, 01:16 PM
w201-16's Avatar
Date registered: Sep 2012
Quoted: 20 Post(s)
Shockabsorber for the steering??
Sent fra min H8324 via Tapatalk
w201-16 is offline
post #3 of 13 (permalink) Old 05-04-2019, 02:11 PM
tuttebenne's Avatar
Date registered: Jul 2005
Vehicle: W124
Quoted: 474 Post(s)
Its not really clear if you are talking about the center link or the steering stabilizer. Both of those parts should be available from Mercedes Benz.
'93 400E
'93 500E
'94 E320TE
'00 E320
'02 E320
'73 Alfa GTV
'77 308GTB
tuttebenne is offline
post #4 of 13 (permalink) Old 05-04-2019, 05:04 PM Thread Starter
No the centerlink. Sorry, I wasn't aware that was unclear, thank you!
post #5 of 13 (permalink) Old 05-04-2019, 05:06 PM Thread Starter
I was told the centerlink is what was broken by the mechanic. I honestly know nothing about cars. When I was under the car there was this bar that went across almost from wheel to wheel unless I'm remembering it poorly, and there was a little joint, knuckle thing that had way more play than it should have and it was causing my wheels to violently wobble when coming up to speed and stopping.
post #6 of 13 (permalink) Old 05-05-2019, 02:31 AM
plinker17722's Avatar
Date registered: Mar 2015
Vehicle: 1989 W124 260E
Quoted: 129 Post(s)
info
Is this your part . no-17 or 18 no 17= torsion bar no 18 = Rod . You will find it at Parts.Com
This is a retro ride .
plinker17722 is offline
post #7 of 13 (permalink) Old 05-05-2019, 09:41 AM
Real1shepherd's Avatar
Date registered: Jul 2009
Vehicle: '92 300TE 4matic 280,000miles, '92 300TE 4Matic 'Ice Blue Metalic' 101,000miles
Quoted: 481 Post(s)
You have to find a parts place that has OE parts for the 4Matic cars. I'm not impressed by your mechanic's 'guessing game'. If he can find the appropriate tie rods with the 'snake squiggle' ends, then he can find the center link.
First get the right MB part's number from a member who has EPC.....use your VIN #. You haven't told us a yr or car........like TE or sedan.
The 'bar that goes clear across' is a sway bar and on the 4Matics they have sealed ends that bolt back....not at all like the center link. You're causing some confusion here.
Kevin
Real1shepherd is offline
post #8 of 13 (permalink) Old 05-05-2019, 09:55 AM
Quoted: 481 Post(s)
This is for my car & yr....probably what you're describing, but it doesn't 'go clear across from wheel to wheel'....it's a center link that also accepts the steering shock damper.
https://www.partsgeek.com/catalog/19..._assembly.html
Scroll down to where is says 'Genuine'.
You can't cheap out on 4Matic parts....you try to go aftermarket on specific 4Matic suspension parts and you'll be in a world of hurt. I'm not syaing that's your best price, but go OE.
Kevin
tuttebenne likes this.
post #9 of 13 (permalink) Old 05-05-2019, 09:59 AM
w201-16's Avatar
Quoted: 20 Post(s)
A lot sell 4m parts, but when they come it's 2wd parts. For 4m parts will oem/om parts be safe.
w201-16 is offline
post #10 of 13 (permalink) Old 05-05-2019, 10:02 AM
Quoted: 481 Post(s)
Here it is on Amazon for a lot more:
https://www.amazon.com/s?k=Mercededs...c&ref=a9_asc_1
Kevin
93 300e 4matic question dimitrii_popov W124 E,CE,D,TD Class 10 08-12-2014 06:13 PM
1991 300E 4MATIC issues. audiboi2 W124 E,CE,D,TD Class 21 03-26-2014 06:34 PM
w124, '92 300E, help finding what this part goes to? From inside drivers door. lalan64 W124 E,CE,D,TD Class 5 01-01-2013 05:14 PM
1992 300E 4matic Part out LoveForBenz For Sale/Wanted/Trade/Giveaway 0 03-02-2010 03:19 PM
TIRE RACK'S AT italia type 8 on a 300e 4matic sach The Discount Tire Direct Tire, Wheel, Brake & Suspension 1 11-09-2005 07:18 AM
