Where did my AC Go? - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 05-01-2019, 04:14 PM Thread Starter
Beezersh's Avatar
Date registered: Jul 2018
Vehicle: 1993 300e 2.8
Quoted: 15 Post(s)
Where did my AC Go?
Last night I charged up my AC. Got it working nice and cool, drove around today and it was fine. Let me back up a bit though...
Prior to charging I jumped the low pressure switch to see that the compressor ran and received signals from climate controller. Initial gauge readings indicated no pressure in the system....so I pulled a vacuum, it held firm with no needle movement, then I charged the system. However, when I disconnected the high pressure line, some oil and dye sprayed out all over the area around my ps pump, hoses, etc. I did not put this dye in...it was PO.
So, today I took a mild detergent, squirted and scrubbed the area down and rinsed with very low pressure water stream. I dried everything off and blew out the area with compressed air including the compressor connector . I started driving it 15 minutes later and had no air. Also, with full AC on, the compressor wouldn’t allow me to jump it.
Did I just fry my Klima relay or some kind of fusible link? I know I got water on the compressor connector and read somewhere that that if the compressor grounds out, it will fry the klima. Thanks.....and it’s getting hot ��
Beezersh is offline
post #2 of 9 (permalink) Old 05-01-2019, 06:06 PM
tuttebenne's Avatar
Date registered: Jul 2005
Vehicle: W124
Quoted: 474 Post(s)
First thing to check is whether or not your belt tensioner is working properly. A slipping compressor pulley (due to a loose serp belt) will be sensed by the speed sensor on the compressor and the KLIMA will shut off the compressor It is designed to interpret a slowing compressor as one that is failing so it stops it to prevent further damage. Might not be your problem but like I said, its a first step.
'93 400E
'93 500E
'94 E320TE
'00 E320
'02 E320
'73 Alfa GTV
'77 308GTB
tuttebenne is offline
post #3 of 9 (permalink) Old 05-01-2019, 07:35 PM Thread Starter
Beezersh's Avatar
Quoted: 15 Post(s)
Thanks. I recently replaced the tensioner damper and serpentine belt. What should I look for other than that ?
Beezersh is offline
post #4 of 9 (permalink) Old 05-02-2019, 04:27 AM
tuttebenne's Avatar
Vehicle: W124
Quoted: 474 Post(s)
Determine whether or not the compressor tries to come on or if it doesn't do anything. Have an assistant turn on the A/C while you watch the compressor pulley.
'93 400E
'93 500E
'94 E320TE
'00 E320
'02 E320
'73 Alfa GTV
'77 308GTB
post #5 of 9 (permalink) Old 05-02-2019, 06:21 AM Thread Starter
Beezersh's Avatar
Quoted: 15 Post(s)
Strange, it came back on this morning. I wonder if the area just needed to dry out. Verified that compressor was also engaged as well....seems odd. I guess I just need to monitor it.
Beezersh is offline
post #6 of 9 (permalink) Old 05-02-2019, 08:29 AM
tuttebenne's Avatar
Vehicle: W124
Quoted: 474 Post(s)
When the A/C wasn't working was the blower working?
'93 400E
'93 500E
'94 E320TE
'00 E320
'02 E320
'73 Alfa GTV
'77 308GTB
post #7 of 9 (permalink) Old 05-10-2019, 02:54 PM Thread Starter
Beezersh's Avatar
Quoted: 15 Post(s)
Yes it was. AC still working though we haven’t had real hot days here.
Beezersh is offline
post #8 of 9 (permalink) Old 05-10-2019, 05:33 PM
tuttebenne's Avatar
Vehicle: W124
Quoted: 474 Post(s)
Yes it was. AC still working though we havenít had real hot days here.
Okay, this takes the spotlight off the ignition switch. Once it fails again, check the compressor/pulley to ensure the clutch is engaged and the pulley is spinning.
'93 400E
'93 500E
'94 E320TE
'00 E320
'02 E320
'73 Alfa GTV
'77 308GTB
post #9 of 9 (permalink) Old 06-03-2019, 03:36 PM Thread Starter
Beezersh's Avatar
Quoted: 15 Post(s)
So since this post we had one fairly warm day. Mid 80’s. The AC worked for a bit then stopped. The compressor was not coming on even with a jumper. I had a spare KLIMA relay...swapped it out and the AC was back. I’m thinking I should keep a spare in the trunk (along with other spares).
Robert Kyle likes this.
Beezersh is offline
